Question about Fossil Stella Topring Watch
Fossill rubber band ph5025 adjustment - Fossil Stella Topring Watch
SOURCE: How to adjust the watch strap
I just bought the o-ring watch by Starck, and it looks to have the same style of strap. If you look on the side of the clasp, you will see a pin on both ends. You have to remove these retention pins first (which may require tools that are unavailable to you). First, stabilize the watch on its side on a soft mat - I used the back of a mouse pad. Then, use a thin, stiff piece of metal tool to push the pins out slightly. I used a crafting tool. Once the pin sticks out enough, you can use a fine set of pliers to pull them the rest of the way out. (If this does not make much sense at this point, you may be best off going to watch shop.) Once you remove the pins, the clasp can be removed from the strap simply by lifting the clamp. You then trim the strap with a pair of sharp scissors to the appropriate length - make sure you see exactly what the end looks like, because the shortened strap will need to have the same apperance. After trimming, reclamp the clasp onto the strap, and reinsert the pin. You may need a small hammer to get the pins seated completely. Then, you're done. So obviously intuitive, why would anyone need directions, right? Honestly, Fossil did not make this one easy at all. Kind of irritating.
Posted on Aug 09, 2008
SOURCE: How to remove links from Fossil metal band?
I've had a Fossil before, but forgot how easy it is. Thanks for the refresher.
Posted on Jan 14, 2008
escapement
  • 2334 Answers
SOURCE: purchased fossil ladies watch am4183
Check the sides of watch band and you will see the pin ends. They are holding all links together. If there are arrows inside the watch band, they are pointing the way the pins must come out.
To shorten the band you have to:
Extract the pins.
Take link(s) off.
Join the rest of band together and drive pins back.
Posted on Jan 02, 2009
slp11508
  • 43 Answers
SOURCE: remove links from fossil metal band
The links most likely need a tool that will push the pins out so you can adjust the bracelet. This can be easily done by any jeweler or watch store. You can also order these types of tools online to do it yourself at home. Please do not attempt to remove links without the proper tools as you will not be able to remove them and you will also damage both the bracelet and the pins.
Posted on Jan 14, 2009
SOURCE: wrist band adjustment on a fossil watch
Just take a tiny little jewelery screw driver small enough to fit in the pin hole and tap it with anything that you can find. Then pull out other end. Look for arrows indicating which way to remove pin and go in that direction Some pins are like a hairpin and have a split at one end. Replace solid end first opposite of arrow direction. If there are arrows in both directions on the same link; like Fossil for instance, that means that it doesn't matter which direction the pins are removed or replaced. They are solid and they can go back either end first. It's easy. To get the pin in all the way I just used the little screw driver and tapped it in. Good luck.
Posted on Apr 30, 2009
Hi there I'm desperately looking for a replacement black rubber strap for my Fossil/Starck O Ring watch. Please let me know if you have any advice for me. thx Greg
Go to their web site "fossil.com" and at the bottom of the page there is a menu.
Click on "customer care" and you will see another page with a menu on the left.
Click on "order links and bands" and follow instructions.
May 24, 2011 | Fossil Watch PH1085
How to adjust band on starck ph5031
You can get instructions for your watch from the Fossil web site.
Go to "fossil.com", go to the bottom of the page and you will see a
menu, click on "customer care", and then look under "Product Info" on
the left and you will see "watch instructions". Click in this and then scroll down until you see Stark watch instructions.
There are two sets of band instructions, hopefully one of them is is relevant to your watch.
Apr 20, 2011 | Fossil Watches
Ihave a fossil blue watch, and need links for the band. where can I locate some?
Contact Fossil customer care and they should be able to supply them. Here is their web address:
http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html
Aug 01, 2010 | Fossil Watches
How do I adjust my watch band?
If you want to deuce the size of your band then I have found some instructions on the Fossil website and since most watches are very similar you can try the method described there.
If you need to replace links then you can get them for Skagen (free!).
Go to "fossil.com", go to the bottom of the page and you will see a menu, click on "customer care", and then look under "Product Info" on the left and you will see "watch instructions"
Go down the list to the bottom and under "Phillipe Stark" there is an item "bracelet instructions"
Feb 14, 2010 | Skagen 355LGSC Wrist Watch
Remove links from fossil metal band
Jan 09, 2009 | Fossil Arkitekt watch
Purchased fossil ladies watch am4183 at Macy's, stainless steel band is too big, is this band adjustable, if so how.
Extract the pins.
Take link(s) off.
Jan 01, 2009 | Fossil JR8096 Wrist Watch
Fossil watch band adjustment
throw the ******* thing away
Dec 26, 2007 | Fossil AM3695 Wrist Watch
Wrist band adjustment on a fossil watch
Dec 24, 2007 | Fossil CH2331 Wrist Watch
How to adjust band
My best suggestion to you is to take it to a Fossil store (they will do it for free!), or go to a jewelry or department store (Dillards, Foleys) to get it sized right.
The problem with doing it yourself is if you do not have the correct tools you can scratch the watch or bend the pins easilly. Especially with the black band like you have.
If you go to a jewelry repair shop they will charge you. I have seen them charge anywhere from $2.00 to $15.00. Unlike Fossil or a few other big department stores.
Dec 12, 2007 | Fossil AU4003 Wristwatch
Fossil Stella Topring Watch Logo
18 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Fossil Watch Expert? Answer questions, earn points and help others
