Question about Panasonic DMR-E85H DVD Recorder
Panasonic dmr85 Put the hard drive in my pc as you suggested but it wanted to format it.  I stopped as you said but what do I do now.  Thanks for your help.
  • 1 more comment
  • drloughney Jan 10, 2009
    Changed the capacitors as required - c1270 and c1271.  I now get past the "please wait" problem but the unit is frozen.  It was suggested to take the hard drive out and put it in a pc to retrieve the video material.  I put it in as you suggested but now it wants to initialize the disk.  Your comment was to cancel and ask.  So I am asking what can I do to retrieve the dvd data that is on the hard drive.   Thanks much.
    That is what I did, remove it from the dvd player, look up the instructions on the samsung drive, put the pin in the slave drive position and put it into my pc as the second hard drive.  With all that said, it still wanted to initialize it.  What am I doing wrong?  Again, thanks for taking the time.
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    can you remind me of the original problem please
  • Panasonic Master
  • 4,806 Answers
What you need to do is take the hard drive out of the machine and plug it to another computer as a slave device to get the data
Posted on Jan 10, 2009
  • Lee Hodgson
    Lee Hodgson Jan 11, 2009
    Don't initalize is as you will end up formatting the drive and loosing data, you will have to use a data recovery program on the computer to get the data.
    I recommend you use "easy recovery pro" if you use a torrent client download it from a torrent site and use it to recover the data
    Kind regards
Want to format hard drive
to format hard drive you either have a utility disk that will let you log into DOS and then run Format command. Or, if you have an operating disk like Windows(?), where you insert it and when it tries to install it will ask you to format hard drive? you allow this to run until it has reformatted hard drive. THis will put your version of Windows on the pc hard drive and have wiped whatever else was on the drive before.
if you just want a wipe of drive take it out of PC chasis and run a magnet all over it. or put it in another pc drive bay and run dos Format command on that drive letter (E:) or whatever letter is assigned to it.
more info about what or why you want to do something helps us to give you the best answer(solution) to your questions.
Feb 02, 2013 | Gateway Dx4831-01e Desktop Pc With 20"...
Had vista i removed with a boot disk and formated the harddrive now wont see hard drive
If the hard drive has been formatted it will not boot unless you install an operating system. If you had wanted to format and leave the disk able to boot the correct command is Format "Disk Letter":/S
Aug 22, 2010 | Panasonic CF30 Notebook
FORMAT hard disk with PEN DRIVE
First you need to have the system files to format the harddrive and the process is to simply right click the pen drive and say Format . An option pops up select copy system files and format.then boot the system and it boots via pen drive type in the prompt Format c: /s/Q the disk will get formated.
Regards.
Feb 08, 2010 | Computers & Internet
How to reformat verbatim insight hard drive
Reformatting your drive will wipe it clean ,so save any programs ect you want.On your PC go to Start,right click on My Computer and select Manage. Under Storage click on Disk Management and find your hard drive in the list and right click on it and select Format. If you want to put files of more than 4GB I suggest you choose NTFS. To do so ,under File System change the Answer to NTFS and leave the Allocation Unit to default.Click on Perform Quick Format if you want,and confirm that your OK with losing all data on the drive and your done.
Regards Bill
Jan 12, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
I have problem with my harddisk. I have it in external box, and when I turn it on it works just for cca 15 seconds and then it stops, meaning I can't access anything and windows is saying "not responding"...
It seems that the hard-drive is "dying", and that the "root" of the file-directory on the disk-drive is "corrupt".
Look online for a "File Scavenger" program -- it reads a disk-drive, sector-by-sector, hoping to "stitch-and-sew" together sectors into files, so that you can "recover" files, and copy them to your 'C:' drive.
Yes, it sucks that your warranty has expired.
Does your credit-card company "double" the warranty for items purchased on your credit-card?
Nov 14, 2009 | Western Digital Caviar SE WD2000JS 200 GB...
My HD is being detected by my pc but when it is inserted windows wont boot. i tried reading it thru an enclosure but as soon it was detected the windows stopped responding and when i remove the enclosure...
Depending on what kind of files you need to recover, Recover My Files is an excellent product for recovering the most common file types. If you want to do full data recovery, try Get Data Back for NTFS or FAT32. It is an amazing piece of software.
Hope this helps!
Aug 25, 2009 | Seagate Momentus 5400.2 (ST9808211A) 80 GB...
Pc problems
Why do you want to format your hard disk for? Do you wish to install a new operating system on your PC, or do you want to format a second hard disk.
If you want to install a new operating system, then you will need to install a CD drive or an external CD drive and then you can format your drive and install a new operating system.
Use a floppy disk, This must be a boot disk with operating system files. Suggest you use Windows ME.
Apr 18, 2008 | IBM ThinkPad T23 Notebook
Sandisk Micro SD Card stops after 108 songs
If you formatted the card first, you should have had a true value of the Size.
Even a true 1 Gig card, only has a capacity of 960mb.
As the card has to allow for a valid boot-block to be written to it.
This is so the read/write device, can recognise the drive/cards format i.e FAT/FAT 32 et,c.
I,d suggest that you have a 512mb card, that has a 1 gig sticker on it.
The chinese have a way of doing this with MP4 Players. they sell them as 4 gig, when you format them, they,re actually 1 gig or smaller sometimes.
I,d suggest backing up yhe card, and formatting it, to see it,s true size. And that your also using the correct Format.
Mike @ compurepair.
Mar 14, 2008 | Electronics - Others
Panasonic DMR-E85H DVD Recorder Logo
195 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
