Question about AOC 19LVWK LCD Monitor
Aoc 22lvwk blank screen
I have an Aoc 22lvwk that comes on for about 5 seconds,flickers and makes a humming noise and then goes out untill I turn it off and then back on.
4 Suggested Answers
SOURCE: screen goes blank after few seconds
My screen goes black after a few seconds and will not come back on unless I turn it off. When I turn it back on it does the same thing. I can not get it to come on at all.
Posted on Nov 14, 2008
jaymac007
  • 42 Answers
SOURCE: the screen goes blank after 5 seconds
Make sure you have the correct drivers install for you video card. Also, check to make sure your resolution is not set to high for you video card. To get to resolution; right click on Desktop > click Properties > press Settings Tab, from there you can move the slider to change your screen resolution (try different resolutions until it doesn't shut off anymore).
Let me know.
Posted on Jul 09, 2009
SOURCE: My AOC screen goes black after about a few seconds after booting.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Posted on Jul 26, 2010
Laptop making a high humming noise that comes and goes
It sounds as if your hard drive is starting to go, either that or your cooling fan. These would be the only two things I can think of that would cause a "humming" sound. I'm also guessing hard drive due to the fact that the drive spins until the program is loaded into your RAM then lets the RAM take over so it gets quiet again. Just a thought, it doesn't cost anything to open the bottom and listen closely. Good luck!
Jan 13, 2013 | Alienware PC Systems Alienware...
What makes a computer monitor lose backlight
There are two reasons, the inverter transformer, "usually more than one" is the most likely to break down, the second issue that crops up is the backlight, "again more than one" do go on a occassion.
Apr 24, 2012 | AOC 22LVWK Monitor
How to change resolution LCD monitor 22LVWk to 1680 x 1050
Open Control Panel - Display - Settings tab then in Screen resolution move the slide to get the screen resolution 1680 x 1050.
If this resolution is not available the the graphics card cannot support this resolution and you need to set it as close to 1680 X 1050 as possible or upgrade to a better graphics card to get this resolution.
Mar 17, 2012 | AOC 22LVWK Monitor
Hi, i have viewsonic 1940w. When i turn it on it makes buzzing sound and after 5-30 seconds it goes in stand by mode(orange light). Sometimes screen flickers to. If you turn off monitor and on again you...
I fixed this same Viewsonic problem by replacing the electrolytic caps on the power board and re-soldering the power transformer joints. The noise is coming from the transformer, if you torque it the noise stops. Cold solder joints must have been the cause (large posts did not heat up enough during construction). The bad joints might have caused a cap to overheat too, not sure but one was swollen and leaking and after replacing them the squealing was stronger and allowed a longer running time to locate the cold joint.
Oct 23, 2010 | Computers & Internet
AOC 22LVWK Monitor - Souond Problem
re install your sound driver (mother board and utilities)
Oct 05, 2009 | Computers & Internet
My tv screen keeps flickering on and off
  1. Need Model # of set and the brand so I know if its a plasma, LCD, or CRT set keep me posted
Aug 23, 2009 | Televison & Video
The screen goes blank after 5 seconds
Let me know.
Jul 09, 2009 | ViewSonic VG900b 19" LCD Monitor
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
AOC 19LVWK LCD Monitor Logo
141 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
