Question about Victor 1208-2 Calculator
Forgot how to load paper for a victor 1230-2 calculator
How do I load this....
4 Suggested Answers
SOURCE: loading paper into a 1205-3 Victor calculator?
I just got the same calculator without a manual. Fold over one corner of the tape so it almost goes to the other edge of the paper, making a 45 degree angle. Insert the tip of the tape into the slot at the back of the calculator and push it ahead until the corner goes under the black plastic part. I had to push it ahead a little more until it was starting to come upward on the other side. Push the arrow button at the top left corner of the keypad to advance the tape.
Posted on May 29, 2009
  • 40 Answers
SOURCE: Please help me to load
Feed the paper through the slot located just under where the roll is sitting. Once you have fed it through as far as you can, press the arrow button (the up arrow) on your calculator until it catches the paper & feeds it through the machine.
Posted on Feb 10, 2011
  • 566 Answers
SOURCE: have a victor 1230-3 calculator
1. Set the [GT OFF/GT ON/ TAX SET] switch to "TAX SET" position to select set mode for the tax rate.
2. Press "5"
Posted on Jun 18, 2011
Clear paper jam
1. Turn ON calculator and set the slide switch P/NP/IP switch to P position.
2. Remove the paper roll from printer.
3. Use a business card and insert into the printer slot
4. press the feed key to feed the business card to clear the paper jam
Jan 19, 2015 | Victor 1260-3 Calculator
How do I load the tape in the Victor 1297?
f319ovy15l9xaaaaaelftksuqmccPPress the ARROW button on the top left side of the printer. Watch the direction of the feed roll and then push the paper into it,
Apr 11, 2012 | Victor 1297 Calculator
How to load the tape in the Victor 1297
Push the ARROW at the top left side and watch for the feed roller movement. Push the paper into it and it will feed it through.f319ovy15l9xaaaaaelftksuqmcc
Paper won't feed in Victor 1460-3. Calculator works fine otherwise.
There appears to be something in the way as the paper bunches up when I start to feed it through.
Is there some way of taking the back off this calculator?
Aug 17, 2011 | Victor 1460-3 Calculator
Have a victor 1230-3 calculator / adding machine and my 2 year old grandson erased the tax and i cannot figure out how to get the 5% tax rate back in it.
2. Press "5"
Jun 17, 2011 | Victor 1230-2 Calculator
Please help me to load paper into the victor 1208-2 calculator
Feb 08, 2011 | Victor 1208-2 Calculator
Printing is very faint. How to change or add ink printer device.
This is most likely a ribbon impact system. Any office supply store should have the ribbon you need, with information on compaitability on the package.
Remove the paper roll and gently but firmly pry on the bezel surrounding the paper exit path. Examine the sides of the ribbon casing for any clips or fasteners.
May 22, 2009 | Victor 1280-5 Calculator
Loading paper into a 1205-3 Victor calculator?
Jan 25, 2009 | Victor 1205 Calculator
Victor 1520A Calculator
Coleman and other companies have repalcment add rolls parts, Some are generic and some are original..
Apr 03, 2008 | Office Equipment & Supplies
Load new reel of paper
Assuming that you know where the paper gets feed in, I usually use this trick to start a new roll of paper.
First, tear off the end of the new roll so that there isn't any glue stuck on the paper.
Then, fold the tip of the paper like an arrow. > (Fold one side to the middle and the other side to the middle so both sides meet in the middle.
Then, place the paper into the slot where the paper feeds in.. (Usually goes under the printer assembly) and then hit the PAPER FEED button at the same time. If the paper is in the correct slot, the paper should start feeding the paper all the way through.
Hope this helps.
Have a good day.
M =)
Feb 10, 2008 | Victor 1230-2 Calculator
Victor 1208-2 Calculator Logo
163 people viewed this question
Top Victor Office Equipment & Supplies Experts
Greg Cann
Greg Cann
David Burbee
David Burbee
Are you a Victor Office Equipment and Supply Expert? Answer questions, earn points and help others
