Question about LG Optimus E610
I have a small type running across the upper right side of my phone. It has
It has red and green lines at the top of the message that come and go. says something like system server sensord, com.android.systemui, and several other things all in very small print
  • 166 Answers
Hey nancy,
First of all i assume that your phone is not rooted and is still in stock rom.
SystemUI.apk is the package file that provide statusbar for your phone. This file may be damaged or resource files may be missing.. So try to update your phone. The company may have already released a fix for it..
The above method is the safest method.
Now if you are running custom rom or you phone is already rooted then follow these steps at your own risk. This is because doing these may loose your warrenty or brick your phone. I am not responsible for the damaged caused by the operations given below:
1.Get root access for your phone
2.Download new statusbar app SystemUI.apk for your phone(only meant for your phone). You can get it from google search or from xda-developers.
3. Either using SystemPackageInstaller app, install it or use root explorer to replace current SystemUI.apk with new one.
Again i warn you that this may damage your phone. So stay only with company updates.
Posted on Nov 27, 2012
A horizontal band of green and red lines across the screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 17, 2015 | Panasonic TC-P46C2 - 46 Inch 720P Plasma...
1 inch red and green lines in a strip across top third of tv
Id start by replacing the tcon board, its the small board generally at the top of the set. sometimes under a metal cover
Nov 27, 2017 | Vizio Televison & Video
Location of the usb pins on the mainboard
http://www.matsonic.com/Computer-Desktop-Support/Models/ms9307c%2Bseries.php
Go to the small list on the left side, under the bold black subheading - Matsonic Motherboard Manuals (PDF)
Left-click on - MS9307C
When the small window comes up on the right, make SURE there is a Green dot, in the small circle to the left of - Save File.
IF not left-click in the small empty circle to the left of Save File.
Now go below, and click on OK.
A small window will come up on the left. Allow the file to fully download. Then DOUBLE-click right on the file name.
Go to the far left side, and click on Extract all files.
Then click on Next, Next, and Finish, at the bottom of the next three small windows.
In the last small window DOUBLE-click right on the file name, next to the red Adobe PDF icon.
There is the motherboard manual.
Go to Page 14 of the Adobe Reader page number. (Top header)
Actual manual page number is 10.
Motherboard installed in computer case, USB1 header is at the bottom right corner. It lays Parallel to the bottom of the motherboard.
5 pins across the Top row, 4 pins across the Bottom row.
USB2 header is right above the top white PCI slot. (PCI 1 slot)
5 pins across the Top row, 4 pins across the bottom row.
Pinout for the USB headers is on Page 22 of the Adobe Reader page number. Page 18 for the actual manual page.
Regards,
joecoolvette
http://pinouts.ru/Slots/USB_pinout.shtml
Oct 23, 2012 | Matsonic MS9307C+ (810884003185)...
Instructions how to text from 5230 nokia cell phone
Firstly open the menu by pressing the white button which is in centre of red and green button then click on messaging then click on New message and then click on the line which is written after To just like this To:_________ and then type the number of the person whom you want to text then click on the green tick mark which is on the top of the screen then click on the lines which are below To:_________ and then type your text and then click on the green tick mark on the top of the screen and at the end click on the options and select send... you text will be sent
Nov 05, 2011 | Nokia 5230 Cell Phone
Thin vertical red & green lines in upper right of 42 in sanyo lcd
More than likely your control board. Available at www.partstore.com Cost could be between $130 and $200. Not that complicated to install if you can use a screwdriver and are careful. Let me know how this works out.
hardrocko
Feb 01, 2010 | Sanyo DP42848 LCD TV
Mitsubishi WT-42413 Blue Green and Red Line
there is a section in the tv working just to keep the screen fitting top to down (vertical section) some capacitors are dry now in that area. this one has not to be a expensive job in the workshop. Try estimates
Apr 14, 2009 | Mitsubishi WT-42413 42" Rear Projection...
Red and green fuzzy waves across the screen
my screen just became distorted (red picturer to the upper right & green picture to the bottem left ? can you help me ? wuzuphippie55@yahoo
Sep 08, 2008 | Philips Magnavox 9P6034C 60" Rear...
Red/green drooping L top corner
i have found when samsangs convergence are out of range perfect focus will fail. if the are out of range a technician will try to adjust the set in service mode. store these values and then this will be the base for the perfect focus. If the set has a bad convergence cuircit then they have to be replaced.
Nov 05, 2007 | Samsung HCN653W 65" Rear Projection...
LG Optimus E610 Logo
107 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
