Question about Zanussi Washing Machines
Zwd16270w1 displaying fault E66
Washer and dryer won't work on any programme. Displays Err. Fault E66
5 Suggested Answers
SOURCE: dhe fault code
condenser blocked
Posted on Dec 16, 2007
SOURCE: Zanussi zwf1237w washing machine
Won't spin at full speed. It just goes around slowly.
Posted on Mar 06, 2008
SOURCE: Bosch washer/dryer
I also have the same washer and same problem, and it is not due to clogged filters nor due to low pressure!
Any solutions so far?
I wish I had read these posts before buying it. :(
Posted on Nov 01, 2008
  • 8 Answers
I had the same problem my 3 yr old had been playing with the buttons and the whole thing just locked up and displayed ERR no amount of unplugging turning off would fix it.
Till ...........
  • Take off the top
  • Unscrew front panel and remove,
  • Then remove circuit board from panel,
  • Desolder the square battery,
  • Leave to stand around 15 Min's, (would recomend longer to be sure)
  • Re-solder Battery refit circuit board and refit panel.
This discharges the program memory chip and resets to default.
Hope this helps it's not so hard as it sounds just take care with the battery. DON'T put to much heat on it use a screwdriver on the small connections to act as a heatsink.
Posted on Dec 03, 2008
My dryer keeps giving an E 14 error code. Even after resetting it, it runs for about two minutes & flashes the code again. How can I fix this?
Bosch Washer Dryer ' Neff ' Siemens ' Integrated ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3312-bosch-neff-s...
Jan 16, 2012 - Bosch, Neff and Siemens integrated washer dryer error codes and ... The error codes in this article pertain to integrated washer dryers ... E14 ...
how to mend it .com - error code E14?
howtomendit.com > Household Appliances, Washing Machines
Bosch washer/dryer wvti3240 stops wash and displays error code E14. Can anyone help please ? also a full list of the error codes applicable to this machine ..
Nov 03, 2015 | Dryers
AEG Lavamat 11842 Error code E66
http://bastlman.wz.cz/2010/08/AEG-Lavamat-error-codes.html
Feb 23, 2013 | AEG Washing Machines
Samsung Model WF220 won't spin after it fills with water. It displays Error code 3E.
This video will help you diagnose the fault on Samsung Model WF220 3e error codes and the video will help you solve the problem
Sep 08, 2012 | Washing Machines
Maytag washer displays d7 where the time should be and won't run.
Possible suspect is the program controller unit. You need to switch off the washer for sometime and remove the panel , check the connections to the board, check all connectors. If there is not fault on the connections then the board is the suspect.
Jun 26, 2012 | Washing Machines
When start is pressed ERR LOC displays, door
You can try clearing the code and then running the machine. Try colding down the pause and clear button simultaneously for three second s and the faul should clear Or try turning the knob around 9 times to clear the fault.
Jan 08, 2010 | Frigidaire ATF6000ES Front Load Washer
Blinking 'err' message What are potential causes? The repair is quite expensive and I want to avoid a repeat
I've got the same blinking "Err" message on the top screen of my Kodak DCS SLR/n. And camera don't working at all (menu displays only)
I was thinking that is mechanical fault. But in service centre (not official because I living in Russia and there`s no official service centre that would help me) engeneer tell me that mainboard was broken and replacement cost will be about $700. So I'm buy new one.
If you live in the USA you can contact official Kodak service. I believe that cost of repair won't be more than half of new one.
Dec 14, 2009 | Kodak DCS Pro SLR/n Digital Camera
Bosch washer/dryer
Mar 27, 2008 | Washing Machines
Hotpoint wf840 displays "test"
Try This - It works for the Washer Dryers so it May work on your Washer.
  1. Press the Start/Cancel button until all the console Led's Illuminate
  2. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  3. Default screen should return and you can select a new programme
Hope this Helps.
Mar 12, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Jan 14, 2008 | Zanussi FJ1254W Front Load Washer
Washing Machines Logo
57 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
