Canon iR2270 showed an error code E000024-0000.the solution you gave was to check if the developing unit is fixed.now I can't locate were the developing unit is.
2 Suggested Answers
  • 1335 Answers
SOURCE: my canon pixma mp830 shows error code 5010. what
The scanner lock switch may be in the locked position. Lift the cover and check the slide switch located on the top front left. If this is not the problem, you will have to have a service center look at the problem.
Posted on Dec 19, 2009
Error E000110-0001 copier Canon ir2270
this error code is related to the scanner motor faulty..check the laser unit or DC controller..you should also check the wiring
Mar 17, 2017 | Canon Office Equipment & Supplies
My canon ir2270 is saying code error e000020-0000 please help me understand this
that error indicates that there is an obstruction between the toner hopper and the developing unit .
Feb 16, 2016 | Canon Office Equipment & Supplies
How to fix the Canon Image Class Printer 4750 error code e001-0000
Canon IR2270/IR2870/IR3570/IR4570/IR5070/IR5570/IR6070/IR6570
Enter the service mode (Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again).
Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here you can reset all error codes on by one.
for more details : www.mytechtime.com/2011/10/canon-error-e001e002-e003-e007.html
Jan 04, 2015 | Canon Office Equipment & Supplies
E000024-0001
Hi
The first thing I tend to do with any fault on a computer or related hardware, is to turn it off, unplug it from the power supply, turn off and unplug the rest of the system components. Wait for a few minutes, plug the equipment back in and turn all components on and then reboot the computer.
If you have already done all this then I suspect that from the error code your machine is a Canon in the iR range. For the purpose of a reply I have used the iR2270, but the error code can occur on other models.
Description:- The developing assembly connector is disconnected.
The connection detection signal is absent continuously for 100 msec.
Remedy:- Replace the developing assembly toner sensor. Connect the connector. Replace the DC controller PCB.
This can be seen on this webpage where you can change the model number to your particular machine by using the drop down menus along the top of the page:
Error Codes Canon iR2270 Code E024 0000
You can also obtain a full service manual from this site.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 13, 2014 | Office Equipment & Supplies
HOW CAN I CLEAR THE ERROR CODE 0001 IR2270 COPIER
Ther's an error in your heather,Check the heather lamp,thermalswitch and thermal fuse.After replacement of the damaged part,you have to clear error in service mode
Jul 25, 2014 | Canon IR2270 COPIER FOR 220 VOLTS ONLY
Error code E00024-0001 for canon ir2270
Clean DP unit (developer unit) and install toner manually Press- additional Then 2,8 ,additional press Copier ,function ,install toner ,ok if not then Replace DP censer or toner hopper censer
Nov 06, 2013 | Canon imageRUNNER C3200 Copier
IN CANON IR2270 SHOWS ERROR CODE E0049001
there might be something jammed in it like paper so check all the compartments or the ink section if thats not hte case then get it checked out by a professnial
May 20, 2009 | Canon imageRUNNER 2270 Copier
143 people viewed this question
jasbo
jasbo
