Question about Zanussi Washing Machines
Zanussi zwi1125 noisy drum&spin
When spining the machine very noisey
  • 13 Answers
SOURCE: Drum noisy when spinning
main wash bearing fail parts for this £48 if you are mechanicaly minded then its a 3hr job if you have all the tools appliance doctor
Posted on Feb 02, 2007
  • 883 Answers
SOURCE: noisy washing machine
the agitator transmission may be the noise source because it turns with the drum during spin. may need a new transmission just to stop noise.
Posted on Nov 20, 2007
  • 101 Answers
SOURCE: zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Posted on Apr 23, 2008
  • 57 Answers
SOURCE: noisey drum, can bearings be replaced on zanussi zwf 1421 w
Yes they can. Search for a service manual for instructions, on the net. Parts are not usually exspensive, Repairmen are. I did mine in less than an hour.
Andy
Posted on Nov 09, 2009
miket756
  • 2702 Answers
SOURCE: Hotpoint aquarius WMF740 (1 year old) - noisey spin
its the drum bearings there worn out try opening the door and lifting the top of the drum with your fingers if there is any life and the drum drops back when you let it go its them bearings,, then spin the drum by hand is should grumble or growl,,,if it dont do any of this, it could be the "spider" broken off, its an ally part that holds the drum bearings and the drum up,
Posted on Mar 07, 2010
Hi my Zanussi ZWG 1120M washing machine has stopped spinning, no error code is displayed, what could this be?
First check if the water remaining in the drum?
If it is, then the fault is in the drain phase (drain pump,filter...etc.) before the spining cycle.
Otherwise, faulty is motor, belt, electronic....etc.
By the way, model is unknown to me.
Dado
Jan 11, 2015 | Zanussi Washing Machines
MY zanussi, ZWI1125, FRONT LOADER, now makes such a noice on washing and spinning. the plumber has relevelled it but it still makes a noice esp on spinning. Why?
This could be something stuck in the drum ie ,A bra wire or could be bearing trouble an engineer could tell you within seconds.
Oct 30, 2013 | Zanussi Washing Machines
Noisey drum, can bearings be replaced on zanussi zwf 1421 w
Andy
Nov 09, 2009 | Zanussi F1045W Front Load Washer
When my zanussi aquacycle 1200xc is on the fast spin cycle the spinning drum seems to be getting noisier of late.
Probably the main bearings are going, spin the drum by hand, there should be little or no noise at all, if it feels rough, or noisy, then bearings are failing.
Please rate my solution.
Thanks.
Oct 10, 2009 | Zanussi F1245W Front Load Washer
Washing machine noisy when on a spin
  • If a washing machine is very noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on many washing machines due to water getting into them if the drum bearing seal fails. (Hotpoint and Zanussi in particular in my experience) To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings may have gone. There should be a constant rumble all the time the drum is revolving.
  • Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure can be a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) although this patch is not always present. There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust if water has got into the bearings.
  • Aug 28, 2009 | Zanussi ZWF1430W Front Load Washer
    Hotpoint wt960 ultima, very noisey when on spin
    Remove lower rear panel of washer, remove belt and spin drum by hand, if it is noisy or feels rough, then main drum bearings have failed.
    If no noise, then look elsewhere for prob..Could be noisy motor, or loose concrete balance wieght.
    Thanks.
    Aug 27, 2009 | Washing Machines
    Hotpoint Aquarius Model WD61 Washer Dryer working but it's noisey
    If you've just installed it for the first time ensure that transporting locks been removed (big screws under usualy yellow or white plastic covers at the back side of the machine)
    Make sure that machine is standing flat on the floor with no swinging whe you try to move it, this can be achieved by adjusting four legs of the machine (one at each corner).
    If neither of those helps than you need to identify when the noise appears what machine is doing at that moment. If the noise appears when it's draining, pumping water out, than your machine's pump is wearing out, or if it's noisy when spining (final spin) than bearing of the drum is wearing out.
    Update me about your progress
    Good Luck
    May 19, 2009 | Hotpoint Aquarius WD63 Front Load...
    Burning smell and loose drum
    If it is really noisey when it spins then this can only mean one thing.... the drum bearing are shot, its a complete strip down job, not an easy job for a beginer. Sorry
    Dec 23, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
    Washing machine noisey on final spin
    this isn't a problem usually every washing machine is very noisy on a final dry its normal
    Oct 15, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
    Noisy spin cycle
    Hello your problem is the the drum.. To be more precise its the drum bearing.. theses wear out and can be replaced on the zanussi id suggest that you get an engineer out.. its about £100 to get it done
    Dec 15, 2007 | Zanussi F1045W Front Load Washer
    Washing Machines Logo
    118 people viewed this question
    Top Zanussi Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
