Question about Lexmark C510n Laser Printer
Have a Lexmark C510N laser colour printer. The print quality has become streaky and poor. Have only used genuine toners
Vertical streaks on pages
You probably need to replace the photodeveloper cartridge.
Also check the fuser, they sometimes get sticky and pull the toner off the paper. Look for anything stuck to the fuser's rollers. Also check the print outs by rubbing them to see if the toner is stuck to the page well, if not, it's the fuser.
Both need to be changed every once in awhile,with heavy use they need to be changed more often.
Posted on Nov 28, 2012
  • Hannu Aho Dec 02, 2012
    Checked the Fuser Unit and the print stickiness. All OK. Tried swapping Cartridges but no change.It is mainly the left of the page which doesn't get printed in about 1-2 centimeters and the background print is all streaky. I wonder if replacing the Photodeveloper Cartridge would fix this problem? Don't really go down the path of spending $100's and not fixing the problem
  • William Money Dec 02, 2012
    Probably the photodeveloper
SOURCE: vertical streaks
The toner forms small lumps and get stuck on the doctor blade of the cartridge. Where there are the lumps it blocks the toner from getting on the roller. Removing the doctor blade and cleaning it with a soft cloth and alcohol can solve your problem.
Send me a mail at ecoworld@myt.mu if you need further help in doing it.
Posted on Mar 01, 2008
crayzeetrayn
  • 837 Answers
SOURCE: Lexmark E321 Laser Printer
Check pages 76-80
Posted on Dec 07, 2008
  • 320 Answers
SOURCE: Lexmark t520 suddenly prints poor quality, i.e.
this sounds like you have a fuser problem look at the fuser and see if it has toner build up on the rollers ghost printing can be caused by the toner cartridge or the fuser. this would indicate that your fuser isnt maintaining enough heat for complete fusing. is you take the rear covers off and run your print job. look to the far left side of the fuser and you will see the heat lamp lit up. this light should cycle on every 1 1/2 pages or so. any longer than that and it wont keep up with the print job
Posted on Nov 01, 2009
  • 320 Answers
SOURCE: I have a Lexmark Optra T614 and when I print
the problems that you have discribed can all be create by a fuser that is worn. pull the fuser cover which is located in the top cover with a flash light you can inspect the hot roller. from what you have discribed you will find the hotroller to be discolored and every 2 inches or so you will see wear marks from the detack assembly fingers riding on the roller. also the center 3 inches of this roller will brownish colored with lines that will match up to you poor print problem change the fuser and it will fix your problem
Posted on Dec 07, 2009
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: Very poor colour printing quality.
    If you have tried all that the only other thing that I could think of is the cartridge being defective. You can call Lexmark @ 1-800-332-4120 they may be able to help you replace the cartridge.
    Posted on Jan 21, 2010
    Canon irc4580i print dark problem
    In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
    The common print quality problem Canon IRC-4580 printer
    Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
    However, we can not avoid the damage of some components of the printer when used.
    In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
    After viewed artical, you know:
    - How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
    - How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
    - How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
    - How to fix (repair/solve) Light image in Canon IRC-4580 printer
    - How to fix (repair/solve) Ghost in Canon IRC-4580 printer
    1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
    This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
    Description:
    - Vertical line and band: On the printed image appear some straight thin black vertical.
    - Vertical white line: On the printed image appear some white vertical voids.
    Error location:
    - Surface of the charge roller
    - OPC drum
    - Cleaning blade
    - LSU unit
    - Developing roller
    Cause of error "Vertical line" on the printed page:
    - May be surface of charge roller scratched or dirty by toner powder.
    - May be have some grooves on the OPC drum.
    - May be cleaning blade is damaged.
    - May be LSU window or LSU lense has dirty.
    - May be surface of developing roller has scratched.
    How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
    - Replace the charge roller of toner cartridge.
    - Replace the OCP drum.
    - Replace the cleaning blade
    If printed page are not improved
    - Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
    - Replace new axis developer and try to print
    2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
    Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
    Error location: toner cartridge or fuser unit
    Cause of error "Dark Image or black" on the printed page:
    When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
    How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
    With this error, you should replace toner cartridge or fuser unit to fix it.
    3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
    Description: The printed page has one half light and one half clear.
    Error location: Toner cartridge, transfer roller, springs, doctor blade
    Cause of error "Uneven Density":
    - The pressure force on the left and right springs of the transfer roller is not even.
    - May be toner low also causes this error
    - Doctor blade has bent
    How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
    - Replace springs and transfer roller.
    - Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
    - Replace doctor blade.
    4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
    Description: The printed image is all light and no Ghost.
    Error location: Toner cartridge, Developer, HVPS board
    Cause of error "Light image" on the printed page
    - Enabled toner save.
    - Toner cartridge is low
    - OPC drum may be faulty by strong light intensity
    - Temperature in room is below than 10*C
    - Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
    - Abnormalities output from the HVPS
    How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
    - Disable toner save by change in printer driver.
    - Replace the OPC drum.
    - Replace developer.
    - After printer is power on, wait 30 minutes then start printing
    - Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
    5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
    Description: Ghost occurs intervals of the OPC drum or transfer roller.
    - OPC drum has fauty.
    - The life of the transfer roller has been expired
    - The high voltage terminal is contaminated by toner powder or
    - Replace OPC drum
    - Replace transfer roller
    - If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
    - Replacce HVPS board.
    Oct 29, 2016 | Canon Office Equipment & Supplies
    Tip
    Hi, We have had this problem before while taking the economical route of adding...
    After refilling the toner the print out is very bad please suggest a solution.
    on Aug 11, 2008 | Samsung SCX 4521F All-In-One Laser Printer
    Streak along edge of paper, Canon MF8380Cdw
    Print quality issues on these models is usually if not always down to the cartridges used. I bet you are using compatible cartridges. If so just buy a set of genuine ones and I bet the quality will be perfect again.
    Jun 01, 2016 | Canon imageClass MF8380Cdw Wireless Color...
    I have a Samsung CLX-316N multi function colour laser printer. I am getting very poor print quality when trying to print photographs, using laser photo paper. The printed photos have vertical streaks of...
    Dear This is the Quality issue.
    can be solved by replacing black developer in imaging unit.(better solution)
    Alternate is change the Imaging unit(costly solution).
    Dec 06, 2010 | Samsung CLX 3160fn All-In-One Printer
    I have a Lexmark Optra T614 and when I print mostly black pages such as large dark graphics, I get streaky vertical lines at 3" and 5" from the left side of the portrait oriented page, and a lighter...
    You need to either call a repair tech and have the printer serviced for routine maintenance or order a maintenance kit from Lexmark to do the job yourself.
    Just curious, what is the page count on the printer? When was the last time the entire print cartridge was replaced?
    Don
    Oct 19, 2009 | Lexmark Optra T614 Laser Printer
    Samsung CLP-300 poor print quality
    black developer on drum worned out,need changing.
    May 05, 2009 | Samsung CLP 300 Laser Printer
    Lexmark C510
    try to clean the toner from tissue paper or if you want good quality you replace the toner or copen the cover of printer toner and clean is there any ink powder is there. bye
    Sep 21, 2007 | Lexmark C510 Laser Printer
    Vertical streaks
    Sep 11, 2007 | Lexmark C500n Laser Printer
    Incoming fax quality
    Are you using genuine Brother supplies? Generic supplies are the main reason for print quality issues. Have you ever changed thr drum unit ? Expensive! You can buy a new machine and get a new drum and toner for a little bit more.
    Oct 22, 2006 | Brother IntelliFAX 2800 Laser Fax
    Lexmark C510n Laser Printer Logo
    73 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
