Simple comfort 3001 stay 85 degrees
My ac turn on and i set the thermostat to 68 degrees. the digital adjust but to 68 degrees then goes up to 85degrees and stay to 85 degrees.
  • 330 Answers
SOURCE: won't cool down
automatic temperature switch out of order
Posted on Jul 03, 2008
  • 61 Answers
SOURCE: thermostat issue with comfort zone II.
Is this an electric or gass furnace - Eather of these can can have this problem its most recomendable that you call a seviceman .
in the case of electric furnace you may requier a new heat sequencer. And in the case of gass you may requier a new relay.
Posted on Feb 19, 2009
motor1258
  • 6674 Answers
SOURCE: I have a comfort control 2200 thermostat. I
May be the location of the thermostat. Try another thermometer right beside wall thermostat & see what it reads.
Posted on Jul 19, 2009
  • 74 Answers
SOURCE: thermostat reset???
after you changed the battries did you check the set point. it is also possible that the batteries have ruined the stat
Posted on Aug 30, 2009
  • 22 Answers
SOURCE: Carrier Comfort Zone II Smart Control in one zone
sounds like your zone control tstat needs calabrated or maybe replaced,in owners manual there should be a section on calibration if not you may have to replace it
Posted on Sep 15, 2009
WHY DOES MY FURNACE SHUT OFF BEFORE REACHING TEMP
Hi Demetrio
Furnaces turn on and off based on what they're told by your thermostat. The thermostat, in turn, will control the furnace based on:
  1. The temperature AT the thermostat.
  2. What the internal heat sensor thinks the temperature of the air is.
So, if your idea of 68 degrees is what the thermostat thinks is 71 degrees (thermostat reads three degrees high), then when the air by the thermostat gets to about 65 degrees (by your account), it'll think it's 68 degrees and shut the furnace off.
Also, if the thermostat is, say, near a source of local heat, like a lamp, a big piece of electronics, a fireplace, or that place that you habitually set down your coffee, then the air right next to the thermostat may be warmer than the rest of the room, and fool it into thinking it's at it's target.
The sensor is usually inside the housing for the thermostat. If it hasn't been dusted in a while, then it can be hard for air to get inside to affect the sensor, though this would generally cause it to lag on readouts and run the temperature higher than you wanted.
If you have a digital readout, and the system is saying , hey, target is 68, and the readout gets to 66 and the system cuts off the furnace.... my only other guess is that the unit may have features that are trying to prevent overshoot - i.e. by the time the temp at the thermostat actually gets to 68, most of the room is more like 73. That'd depend on your particular thermostat. At that point, you may want to call customer service with the manufacturer and tell them the issue. There may be ways to adjust the unit to get behavior closer to what you seek.
Good Luck!
DH
Jan 25, 2016 | Heating & Cooling
How do i adjust AC temperature variance on a Honeywell TH5220D1003 thermostat
If you are talking about the difference between heating mode and cooling mode and the room setpoint, you can not change it. It comes from the factory with a 3 degree difference. In other words if you raise the heat setpoint until it is within 3 degrees of the cooling setpoint, for every degree you raise the heat setpoint the cooling will raise a degree.
About all you can do is increase the distance between the heat and cooling setpoint. To do this either lower the cooling setpoint to 3 degrees higher than the heat setpoint you want and then increase the cooling setpoint the desired setting. For example heat and cool setpoints are 67 and 70 respectively, and you want 65 and 73. Lower the cooling setpoint to 68 and then raise the cooling setpoint to 73. Now your heating will come on 3 degress lower than 68, the 65 you wanted and cooling will come on at 73. Remember, the thermostat new setpoints will turn on the cooling at 75 and turn back off at 73 and heat will turn on at 63 and turn off at 65.
You can perform the same using the heating setpoint, just have to look at it backwards. If you need to lower the difference I recommend a 8000 series thermostat. They are the most functional thermostat that Honeywell makes, be in mind they are about 3 times more expensive and many of the setting require a well trained tech to interpret and set properly.
Hope this helps.
Aug 24, 2014 | Honeywell Th5220d1003 Non-programmable...
Simple comfort thermostat
most thermostat are plus or mines 5 degree for turn on or off
Jan 29, 2018 | Cars & Trucks
Refrig part got up to 68 degrees inside. Freezer still stayed cold. Why would this happen?
1. Check the setting on the frig. 2. Thermostat on frig may be broken and frig goes to near room temperature.
Sep 01, 2011 | Refrigerators
I turned my thermostat down this morning to 68 degrees. I came back about 2 hours later to increase the temp to 70 degrees but when I push the ^ arrow instead of showing the increase to 70 it just flashes...
Since it's within 2 degrees of your setting it could be one of two things. Most furnaces run longer (pass your setting) to maintain the setting you made. Which really not a problem. However, your thermostat may need calibrating. To test this theory, place a regular wall thermometer next to your furnace's thermostat and see if the two temps match when the furnace cuts on and then when it cuts off.
If the temps are both the same, the furnace thermostat is fine.
If you're turning it down to 68, because no one will be at home during the day, just set it 2 degrees cooler than 68 degrees. You will then wind up with 68 degrees.
Feb 09, 2011 | Heating & Cooling
I have a Honeywell CT500A thermostat. I set it at 68 degrees. the room temperature is 62 degrees. The unit cycles on and the "flame" icon shows on the screen, but then the unit goes off ( the...
Here is a simple way to tell. Remove your thermostat from it's mounting plate, locate the wiring, the red and white are low voltage control wires. Disconnect them from the base and join the two together if the furnace runs you need a thermostat if not it is in the controls to the furnace.
Dec 27, 2010 | Honeywell CT500 Digital Heat / Cool Manual...
I have never used central ac before - how do I set it? If it is on 75 will that cool the house? If I want it cooler, do I put it lower? like 65?
As to your question 'will 75 cool the house?' The answer is 'yes' - if the outside temperature is low enough. Typically speaking you can expect your central AC to cool a properly insulated house to a down to a temperature of about 20-25 degrees lower than the outside temperature. For example - if the outside temp is 95 degrees. You could expect to get your house down to 70-75 degrees. If the outside temp is 110 degrees then you could only expect to get the house to 85 or 90 degrees.
So .. as you can see - your 'inside' temp will be directly affected by the 'outside' temperature.
As to the operation of central air; it is very simple.
I would suggest that you not pay 'too much attention' to what you have the thermostat set on. A comfortable temperature - is a personal thing - so - I would set it somewhere - say 72 and see how I (and others in the house) was handling that setting.
If you want it 'cooler' just 'notch' it down a degree or two - if you need it a little warmer - turn it up a degree or two. Do this "fine adjusting" till you have the temperature setting you are comfortable with.
Usually the more you can leave your thermostat alone the better off you will be from a comfort position and an electrical useage standpoint. Obviously, the higher you have your thermostat set the 'less' it will cost you on your electric bill.
How high you set the temperature is a balance you have to come to based on how comfortable you want to be - matched with how much you want to hold down the electric bill.
hope this helps
Aug 14, 2010 | Honeywell Heating & Cooling
Open Questions:
vulcan bonaire comfort control External natural gas electronic ignition 2004. ISSUE: Fan blowing only cool air continuously. Forced to kill power to stop it. model is one of the following. MB514E,20E or 30E. Going by mech drawing parts list. i can confirm what type of sensors i have cleaned with very fine sandpaper. flame sensor PN 5441603SP and IGNITER ELECTRODE PN 5441602SP The fault code i see is described as the following. There are x4 LED's. Sequence Left to Right. LEGEND: 1 Flame Sensor 2 Pressure switch 3 OverTemp 4 Diag. R Red G Green S Solid Colour B Blinking LED Behaviour. In order 2RS & 4GS Until i hear ignition. 2RS & 3RB Duration: split second 2RB,3RS & 4GB Duration: split second 3RS & 4GB Duration: Until it has completed blinking x4 times. 3RS Duration 4 seconds Repeat last two mentioned behaviour. in my own opinion, as a safety feature, the unit thinks that it has overheated or is about to. so kills the gas and force feeding cool air to heating components to save it from frying. Does this mean i have fault 04 if so does this mean i may have a faulty igniter or flame sensor or maybe a faulty as described in the mech drawing SWITCH OVER TEMPERATURE 120 degrees celsius. Am i correct here? Is this the over temperature cut out switch? if no one can really pinpoint which part requires replacement, can you at least, in sequence advise which parts to purchase? so then ill just try my luck. i wonder how to properly test if flame sensor, igniter, over temp etc is faulty with a multimeter. do i just perform a continuity test. I wonder what other parts can i test related to this fault im getting.
Jul 22, 2018 | Vulcan Heating & Cooling
Heating & Cooling Logo
93 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
