Question about Kyocera Mita Office Equipment & Supplies
Km 4030 printer offline
Printer in offline mode
2 Suggested Answers
n25an
  • 622 Answers
SOURCE: Kyocera-Mita going offline
it sounds like there is an ip conflict... you may need to reserve an ip address just for the copier or failing that change your copiers ip address to one below the ip range... if it still has problems then I would check the network cables.... and see if you get any error codes... copier can go offline if 1. the print card is loose... bad mounting socket on the main board... ip conflict... someone else has the ip address... poor network traffic... the signals over the network cables are degrading too fast... so the copier gets a corrupt file or unfinished file and bombs out... power surge... this causes firmware corruption and the thing just starts shooting wierd error codes... I think I have given you enough to think about...
Posted on Dec 07, 2009
How can I replace the developer unit of Kyocera KM 4030 copier?
Did you install new developer powder into the new developer unit?
Jun 02, 2014 | Kyocera Mita Km-4030 Laser Copier Works...
Error 6000 kyocera 4030
This is a fuser problem , and with any luck you will be able to reset it. Do this: in the copier mode press yellow reset button, then press 10871087 in rapid prosession. Scroll to u 163 ( fuser reset,) and press start button to enter mode . Press execute and wait till mc asks for a restart. Swich the main power of, wait a few seconds and restart. If this does not work you will need to contact your service agent
Feb 17, 2013 | Kyocera Mita KM-5035 Printer
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
Mar 08, 2011 | Kyocera Copystar CS-5035 Copier
KEOCERA MITA photocopier KM4035 have problem. My Machine is showing error code C6000. How to tackle this proble. Please help me as soon as possible.
KM/CS 2530, 3530, 4030, 3035, 4035, 5035
C6400 is a fixing unit error.
To reset -
Try this, enter "10871087" from keypad, You should now be in maintenance mode.
Enter "163"press "Start / Print" key.
You should see a screen that says "Execute".
Press EXCUTE on the touch panel. It is displayed in reverse.
Press "Start / Print key.
The machine will turn off and then back on then come back to ready. If not then you need to replace the fixing unit.
Feb 02, 2011 | Kyocera Mita KM-4035 Printer
It states that the printer is offline. i have this machine for my company so how am i able to put it back online?
If you are getting an error message that states USER INTERVENTION REQUIRED or USE PRINTER OFFLINE, the printer driver may have become disabled. Please follow the directions below to resolve this issue.
Please note that the printer must be in an online state/Print mode.
WINDOWS 95/98/ME/NT/2000
1. Click on START, SETTINGS, and PRINTERS.
2. Highlight the icon of your printer with a single click.
3. Click on FILE.
4. The only check mark showing should be beside SET AS DEFAULT.
5. Ensure that there is no check mark beside PAUSE PRINTING or USE PRINTER OFFLINE.
6. Simply click on the check marks to remove it.
7. Try printing.
WINDOWS XP
1. (a. Click START select CONTROL PANEL and click on PRINTERS AND FAXES.
NOTE: If you cannot locate PRINTERS AND FAXES, Follow 1(b..
1. (b. Click START select CONTROL PANEL double click PRINTERS AND OTHER HARDWARE, and click on VIEW INSTALLED PRINTERS AND FAXES.
3. Click on FILE.
7. Try printing.
Jan 13, 2011 | Kyocera Mita KM-5035 Printer
Can't operate operate scanner of my copier (km-4030)
Does it have the scanner module fitted? If it does then the Scanner button will display the scan screen.Also check that you have another network port above the print board.If not then you do not have the scan board fitted.If you do have the scan board fitted,please be more precise with the errors that you are experiencing.
Aug 15, 2010 | Office Equipment & Supplies
Admin code on kyocera-mita km4030 not working
try formatting the hard disk.(hit the black system counter button..
also go into service mode by hitting 10871087..(than search for initialize memory..
Mar 26, 2009 | Kyocera Mita KM-5035 Printer
Kyocera 4530 is reading offline
I would check the usb connection cable - maybe try a different one. 'off line' normally means that the computer can't communicate with the printer. Silly thing - check that the printer has power. I'm not trying to insult your intelligence, but sometimes it's the simple things that get missed.
Feb 12, 2009 | Kyocera Mita KM-5035 Printer
Try an updated driver from the manufacturer or see if they have any know issues with 2003 sp2 and the driver.
Hope this helps!
Nov 27, 2007 | Kyocera Mita KM-5035 Printer
32 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
AAAA262430
Level 1 Expert
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
