Switch the Printer OFF and ON again and wait for the initialization. If the Error code continues to appear, switch the Printer OFF. Remove the EIO Card (if installed) and make sure that the Hard Disk Drive is installed correctly by pushing it firmly inwards and checking that the two installation screws are completely tightened. Switch the Printer ON again. If the error codes 09Axxx or 09Bxxx appear then replace the Hard Disk Drive. If the Error Code disappeared after removing the EIO Card, then switch the Printer OFF and reinstall the EIO Card, making sure that the two installation screws are completely tightened. Switch the Printer ON again. If the Error Code reappears, then the EIO Card could be faulty. Replace the EIO Card. If Error Code 09Cxxx appears after initialization, then replace the Electronics Module. Once the Error Code has been solved, print an Internal Demo Print to make sure that the Hard Disk Drive is functioning correctly. If the Error Code reappears, then use the above information to troubleshoot the problem.
Put flash in then go to start go to my files and find the flash and copy to it if you don't know which one is the flash while in my files pull flash out and put back in should disappear and then reappear
I think the problem is because mounting problem of the logical drive .In this case to access your data in the drive you just need a macbook hard drive recovery tool .Remove the drive from your pc install the drive in some other mac pc and start it in target mode .Install this recovery tool and start recovering files but save it in different healthy drive .I am suggesting this tool because it works good for my missing partition problem.But purchase the full version to get good results.The demo version link is here...
Which icons are disappearing and reappearing? If you're talking about the Dock (The quick-launch and management area at the bottom of the screen by default), that may have been set to hide it's self, only showing when the mouse is at the very bottom of the screen.
Other icons that come and go are ones that represent volumes such as external hard drives, memory sticks, network places, CDs/DVDs. What icons are being problematic?
Hope that helped, please clarify problems if not!
Oh and by the way - iMac is just that particular type of computer. The Operating System is known as Mac OS. Knowing this will make getting help easier in the future :)
if you HP 1050C Plus display System Error 04CXX Try the following Steps to resolved an error:
1.)Press
ENTER and switch the printer OFF. Remove the Hard Disk Drive (if
installed) and make sure that the EIO card is installed correctly by
are completely tightened. Switch the printer ON again. If this error code continues to appear then replace the EIO card.
2.)If
this Error Code disappeared after removing the Hard Disk Drive, then
switch the Printer OFF and reinstall the Hard Disk Drive, making sure
Printer ON again. If this Error Code reappears, then the Hard Disk
Drive could be faulty. Replace the Hard Disk Drive.
3.)If
this system error continues to appear after replacing the EIO card or
the Hard Disk Drive, then replace the Electronics Module...
System Error: 04Cxxx
Problem
Description:
EIO Accessories (EIO Card/Hard Disk Drive) Error.
Corrective Action: Try the following:
n Press ENTER and switch the printer OFF. Remove the Hard Disk
Drive (if installed) and make sure that the EIO card is installed
installation screws are completely tightened. Switch the printer
EIO card.
n If this Error Code disappeared after removing the Hard Disk
Drive, then switch the Printer OFF and reinstall the Hard Disk
Drive, making sure that the two installation screws are
completely tightened. Switch the Printer ON again. If this Error
Code reappears, then the Hard Disk Drive could be faulty.
n If this system error continues to appear after replacing the EIO
card or the Hard Disk Drive, then replace the Electronics Module
System Error: 0000D8 XXXXXXXX (Non-Continuable)
Problem
Description:
External Library Error.
Corrective Action: Refer to System Error Code 070100
System Error: 070100 XXXXXXXX (Non-Continuable)
Problem
Description:
Firmware Error.
Corrective Action: Power the Printer OFF and ON again to see if the System Error
disappears.
If the Error Code reappears, then report the error to the HP response
Center or the nearest HP Support Office, stating the following
information.
n Model and Serial Number of the printer.
n Which firmware revision the printer is using (See Note below).
Check firmware in Utilities / Statistics / Code rev.
n The complete error number (See Note below).
n The Service Configuration Print þ
n The Current configuration sheet.
n Which software application the customer is using (name, version, etc.).
NOTE When reporting the System Error Code, make sure that you
supply the full Error Code (including the last 8 numbers where
applicable) and the firmware version. Without this information,
HP Support Personnel cannot help you.
System Error: 09xxxx (Non-Continuable)
Problem
Description:
n Switch the Printer OFF and ON again and wait for the initialization.
n If the Error code continues to appear, switch the Printer OFF.
n If the Error Code disappeared after removing the EIO Card, then
n If Error Code 09Cxxx appears after initialization, then replace the
Electronics Module
n Once the Error Code has been solved, print an Internal Demo
the problem sounds like you either lost the IDE channels on the MOBO or the chipset was updated with corrupt files.
run everest home and see if there are current updates for the northbridge chipset. if you have 2 ide channels on the board switch the primary and secondary ribbons and see if the hard drives are there. if your cdrom's are ide and after switching ribbon cables they disappear and the hard drives reappear your mobo lost an ide channel, you would need to replace the board.
Me too, i bought a LaCie BigDiskExtreme+ (1tb) and it keeps giving me Device removal error. I'm running Mac OSX Leopard. Worked for 5 minutes, now everytime it turn it on it goes away and comes back up, always giving me the error message. Any advice ?
