Question about Maytag Washing Machines
Maytag neptune super stack sl 3 won't do spin cycle
aborcass
  • 2651 Answers
SOURCE: Maytag Neptune Series MAH5500BW loud noise during spin cycle.
very loud in spin cycle can mean a bad rear bearing, not something a homeowner would want to try to replace, parts would exceed 6-7 hundered dollars. you may have some extended part warr through the manufacture. still probly gonna be a 5 hundred when the labor is added in
Posted on Dec 06, 2008
SOURCE: maytag neptune MAH5500B spins 2 minutes and shuts
It's probably because you have a unbalanced load. I bet you are hearing the washer banging around. Take a few items out as the most common cause is you filled the washer with too much clothing.
Posted on Mar 27, 2009
Krazytech
  • 725 Answers
SOURCE: E3 code showing sometimes on Neptune MAH-3
“E3” code – Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Possible causes of ‘E3’ codes: 1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause. 2. Hall Sensor fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Hall Sensor – PCB that is located on the back of the motor that senses motor rpm. It is not a separate part, but rather an integral part of the motor.
Posted on Sep 23, 2009
  • 311 Answers
SOURCE: My maytag neptune MAH3000aww washing won't go into
most common issue with these is the door lock assy. You need to remove the control panel and check the R11 resistor on the board most likely it will be burnt. This was a common issue a few years back. If the R11 resistor is burnt you need to replace the door lock AND control board or your problem will occur again.
Hope this helps _MJ_
Posted on Jan 31, 2010
  • 153 Answers
There is 2 possible problems. 1. Pump will make noise as soon as the drain and spin starts. 2. Rear bearing this noise usually starts later in cycle as the drum gets up to final speed. The rear bearing of coarse is the most expensive of the two as it is part of the outer tub.
Posted on Mar 05, 2010
Washers empties water but wont ring out clothes
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design. Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Transmission or clutch assembly not engaging due to going out or slipping.
Sep 28, 2014 | Maytag Neptune Washing Machines
Put detergent
MLG2000A - Maytag Neptune Super Stack SL-3
1 - Select Wash/Rinse Water Temperature
2 - Select Options (Max Extract, Extra Rinse, Signa)
3 - Select Cycle
4 - Load the Clothes Washer (add detergent on top of the load in the tub, and additives [fabric softener, bleach] in their dispensers).
5 - Start the washer.
This is according to the owner's manual I have. Has worked for 14 years for me.
Jan 14, 2014 | Maytag Neptune MLG2000A Front Load Stacked...
Start button want stay on
this is most likely to be upper control board/located in the top of dryer
Feb 18, 2013 | Maytag Neptune Washer
Maytag Stack MLE2000AYW Washer Timer Won't Advance
If manually turning the timer allows it to spin and drain, then I would say the used timer installed was also defective. Try a new timer. You will save money if you get it online or go to an appliance parts store like "Mid-America Appliance" rather than Sears or the likes. Hope this helps.
Jul 06, 2012 | Maytag Neptune MLG2000A Front Load Stacked...
We just moved and the house came with a Maytag Neptune TL which won't spin if there are clothes in the cylinder. It will spin empty. Please help! Thanks.
Washer bangs around in spin cycle and throws a DC or UC unballance code with cloths in the wash basket is that correct?
If so it's a Clutch issue.
If you want read more about what I feel is your issue read this post Maytag Neptune load unbalance
Sep 08, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Detergent goes where?
3 - Select Cycle
This is according to the owner's manual I have. Has worked for 9 years for me.
Jun 28, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
