Question about Mitsubishi WT-46805 46" Rear Projection Television
IC parts We were told we need part numbers 275P452040 and 275P241010 for our rear projection 46" Mitsubishi television, but the store couldn't find them. Do you know of a company/website where they might be available so we don't throw away a television that was $3000.00?
  • Mitsubishi Master
  • 5,138 Answers
I tryed posting you information on your set STK392-560 is what i think yours are but you have number on these Parts they are big black ICs use the same number on them 1-800-223-3205 for Parts.
Posted on Jan 10, 2009
I have an older 200x model Mitsubishi 1080i 46" rear projection TV that no longer turns on. When first powered up the power light on the front blinks in sequence to note that I have a bad power supply or...
Parts for older Mitsubishi are difficult to find. If you give me the complete model number I can check if the part is available online.
In the meanwhile please, try the two websites below.
Encompass Parts Distribution
PartStore.com
Feb 10, 2010 | Mitsubishi WT-46807 46" Rear Projection...
Panasonic pt-53wx53g vertical output ic
IC451 (Vertical Output) LA78045 part number is C1AA00000521
Available in Part Store.
Above info are taken from related service manual and an image of s.manual is given below...
Jun 19, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Mitsubishi ws 55809
Its a STR-G6632 the mitsubishi part number is 267P151010
Oct 24, 2008 | Mitsubishi WS-55809 55" Rear Projection...
TV is Ghosting
if convergence problem color would be bowed and off. If it is the convergence replace ic stks there are 2 inside tv if you could solder and good at this stuff. parts cost is 30.00 . if you are going to get fixed cost is 300.00 . www.part store.com has parts just give them model number .They can tell you part number.I would pay someone to do this it is trickey.
I think ghosting is ground problem on cable connections check connections and replace cable wire.
thanks doctor video
May 18, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi part signal pcb nla 930b881001
That part is no longer available however you can go to this link and they will rebuild your board and provide full warranty. Heres the link You just need to list what your part number is. I am one of the techs that rebuild the boards. They are completely reconditioned and guaranteed. Heres the link.
http://servicemanuals.vstore.ca/
Mar 31, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Where to puchase STK392-570 ic
· http://www.mouser.com/index.cfm?handler=home
· http://www.mcmelectronics.com
· http://www.bdent.com
· http://www.electronix.com
Feb 01, 2008 | Mitsubishi WT-46809 46" Rear Projection...
MITSUBISHI WT-46805 No Volume
Sounds like audio output IC is bad.Hope this helps. It is on the center circuit board on a little heat sink directly in front of the large Convergence heat sink. It is referred to as IC3E01 and the part number is LA4663. Hope this helps. Let me know if i can assist you further.
Nov 05, 2007 | Mitsubishi WT-46809 46" Rear Projection...
MItsubishi WT 46809- not staying on when turned on
One or more fuse devices open==caused by convergence IC
shorted. Solution==replace fuse(s) and STK I.C.(s).
Oct 08, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Convergence circut
Usually there are 2 convergence IC's, labeled STK392-110. Each IC has 3 channes. Each color needs to be corrected 2 ways, vertically and horizontally, so 6 channels are needed. usually one IC does red, red and haf of green while the other IC does the other half of green, blue and blue. If the red colors are off, change the IC closest to the red jack. If the blue is off, change the IC closest to the blue jack. If the green is out, you have a 50/50 shot at replacing the correct IC. It is recommended to use the STK392-150 when replacing the IC's so it might not be a bad idea to go ahead and replace both with the newer numbers.
Apr 11, 2007 | Hitachi 46UX24B/25K 46" Rear Projection...
Mitsubishi WT-46805 46" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
