Question about Williams 2509612 Ceramic Mid-Size Heater
I have the williams wall mount & it shuts down after awhile..
The flame burns great for awhile then the yellow starts to show up along the back, eventually the unit shuts off..What's happening?
  • Williams Master
  • 8,220 Answers
Probably needs to have the burners blown out. The yellow is a sure sign of rust and stuff inside the burners disrupting the formula of air to gas ratio. Just needs a good blowing out.more
Posted on Feb 09, 2009
Pilot light goes out when you relase the gas controll valvue
your gas heater needs cleaning
you can do it yourself
shut gas off to heater
disconect line going to pilot
and the other end into valve
get a straw and blow into line and where it conects
also use vacuume on the end where pilot flame comes out
clean the end of thermcouple( where flame hits)
put it back together BE SURE CONECTIONS ARE TIGHT
dont want gas leaks
Oct 10, 2013 | Williams (5009622) Ceramic Gas Wall...
My gas wall heater is giving off a nasty oder and is setting off my CO2/Smoke detector. what may cause this?
you may have a plugged heat exchanger. please have this checked before using anymore. you may have excess heat coming from the burner compartment,if open flame, and yellow flame in color that would be floating not stable and blue in color
Jan 05, 2011 | Williams (5009622) Ceramic Gas Wall...
Williams 3003622 Wall Mounted 30,000 BTU The pilot light goes out when the main flame shuts down. The pilot light will stay lit for days when heat is not called for but when heat is called for the furnace...
I'm having the same exact problem... At first we thought was the vent... but the way the flames goes out... it seems that there is "not enough oxygen" more than "blown out by the wind"... right after both main & pilot goes out, I can't even light any external flame inside the chamber... and it doesn't feel like the outside cold air coming in... it just feel like there is some sort of gas in the chamber that's so strong, it prevents flame... and the only thing I can think of is that it doesn't have enough oxygen, but too much natural gas, and flame can't sustain.
Nov 02, 2010 | Williams 3003622 Ceramic Wall Mounted...
William forshaire 435 runs well for awhile until
Try cleaning your thermocouple,and resetting it where was, which is located at the pilot flame. this should solve your problem.
Feb 23, 2010 | Heating & Cooling
Williams debonair wall heater + pilot light problems
THE flame from the pilot should shoot past the thermo-couple and heat this up and make a small amount of mili- amps to prove the pilot light is lit. ..So if the flame doesn,t go past the thermo-couple it won, make mili-amps or its tme to change out the thermo-couple, They only cost lest than $8:00 and you can change it!
Dec 22, 2009 | Williams 3003622 Ceramic Wall Mounted...
Pilot adjustment on Williams wall heater
The insert sounds like the cap covering the adjustment screw. Pin hole is for cap removal. Wondering why flame is so high?! Shouldn't have orange flame. If heater doesn't light with lower flame... thermocouple (thing that the flame heats up) may be bad.
Dec 02, 2008 | Williams 2509612 Ceramic Mid-Size Heater
Troubleshooting reddy heater 115,000btu
runs for awhile shuts down with a big puff of smoke comes out poured diesel 911 thought i had water in diesel fuel cans nothing help need solution ASAP
Oct 30, 2008 | Desa International ReddyHeater® R115DT...
Williams wall furnace, top vent.
I've replaced a Williams wall gas heater non-electric. The thermostat is connected right and mounted on the wall. But, there's a thick black copper wire on the side of the furnace tagged thermostat. I don't know what to do with it? Where do you connect this wire? When it touches the top screw of the three screws running vertically(where the other wires are connected). The burner lights up and stays on, even if you play with the wall thermostat. Touching the other two screws doesn't do anything. Now, the manual talks about connecting it to the venting wires? Extra wires coming from the top or maybe somewhere else in the wall? I've left it connected to the first screw, ran the heater. But, it never turns off? Any suggestions? Thanks
Dec 13, 2007 | Heating & Cooling
Williams 2509612 Ceramic Mid-Size Heater Logo
100 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
