Question about Aardvark Direct Pro Q10 (bundle) External Sound System
Aardvark Q10 with no drivers/cd
I recently got the aardvark Q10 off ebay ...guy said in description drivers included...didn't happen...I am looking for the whole driver cd for installing this. Also I have a motu 2408 interface can this be run into this unit somehow for additional inputs???
I am running Win XP Sp2
  • Anonymous Feb 08, 2009
    You need to have sp3 for xp to run the Q10. The drivers are available on the net, they are from 2002, the company went belly up. Good luck
  • 4 Answers
You can use it with sp2. just make sure you have disabled any other sound cards on your computer in the hardware device manager. you can download the drivers here...make sure you use the 7.13 version
http://www.michaelchagnon.com/aardvark/download.html
Posted on Mar 02, 2009
  • 4 Answers
I seem to be a great test case for running Aardvark cards in a modern quad-core system on Windows XP SP3. I've got an Intel Q9550 quad proc, Gigabyte GA-P43-ES3G v1.1 mobo, an Aardvark Q-10, & an Aardvark 24/96.
After reading the forums below, I have a good idea of what I need to do. I'm going to summarize those ideas below & cite sources, but first I'd like to submit my theory explaining why Aardvarks work so badly starting with XP's Service Pack 2.
XP's SP2 & Win2000's SP4 introduced a 36-bit addressing system called PAE, which was designed to support more than 4GB of RAM (never quite worked right), as well as the use of Data Execution Prevention (DEP). SP2 installs the capability & automatically turns it on, just to screw with us. This was done after the Aardvark drivers were written, & even ProTools had problems with PAE; lots of stuff did.
Fortunately, PAE can be turned off. This is what worked for me, in my c:\boot.ini file:
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="WinXP Pro Corp SP3" /NoExecute=AlwaysOff /fastdetect
To check to see whether it is really off (after rebooting), open the System Control Panel, and check on the General tab. If it says "Physical Address Extensions" anywhere under the Computer heading (usually on the 4th line, under the line that says how much RAM you have), PAE is enabled.
If it's still running PAE, try one of these in the boot.ini file instead.
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="WinXP Pro Corp SP3" /NoExecute=AlwaysOff /NOPAE /fastdetect
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="WinXP Pro Corp SP3" /NoExecute=AlwaysOff /NOPAE /KERNEL=ntkrnl.exe /fastdetect
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="WinXP Pro Corp SP3" /execute /fastdetect
(it's different in Vista so if you're crazy enough to try using the Aardvark in Vista, read this: http://thehunk.blogspot.com/2007/06/disabling-physical-address-extension.html)
sources
http://duc.digidesign.com/showthread.php?t=130383
http://www.msfn.org/board/topic/80046-help-do-not-enable-pae/
http://forums.overclockers.com.au/showthread.php?t=398765
http://msdn.microsoft.com/en-us/library/ff557134%28VS.85%29.aspx
general approach to using an Aardvark in Windows XP SP3 on a multi-core computer
1) It helps to know the *rest* of your hardware works right. With the Aardvark cards not installed in the computer, run Memtest86+ for 24 hours with no errors.
2) Install Windows XP. (Do not install any drivers, even motherboard chipset drivers or graphics card drivers. Also, keep it off the network since it's unpatched & unprotected.)
3) Disable PAE & DEP by modifying boot.ini.
4) Disable the computer's internal sound card in the BIOS if you can, and/or in Device Manager.
5) Run the Prime95 blend stress-test for 24 hours each with no errors. If you get errors in these tests you have to fix that issue first.
6) Use Acronis or Ghost to create an image of the partition exactly as it is now, before installing any drivers or system updates. This way, when it crashes, you can reset to this safe point quickly.
7) Physically install the Aardvark cards into the machine.
8) The order in which you load drivers matters. If your first attempt doesn't work, try doing things just slightly differently the next time. Write everything down to keep track of what you try and what happens. First attempt, try loading the motherboard chipset drivers first, then the display adapter, network card, etc & finally the Aardvark drivers, version 7.13.
9) Aardvark drivers 7.13 and 7.14 support hyperthreading and multi-core processors; 7.04 does not, but some people have success with 7.04 so don't assume anything. (7.04 crashes my new computer hard, but seemed to work better on my Athlon 3000+)
10) You may have to try switching which PCI slot the card is plugged into, or try to assign the IRQ in the BIOS or in Windows Device Manager.
11) If it absolutely won't run in your system using XP SP3, try XP SP1 (clean install, not a roll-back). Keep your machine off teh internets for gods sake (or you'll get wormed in 30 seconds & your computer will be a spambot).
12) Set the "timing master" in Sonar or similar programs to your last set of inputs. If you have an Aardvark Q10 in your system, this would be 9/10. (In my case, I think it will be my second card's last outputs, so it's my 24/96's 5/6 inputs.) Also, disable any read & write caching.
sources
http://www.fixya.com/support/t1516728-aardvark_q10_no_drivers_cd
http://www.fixya.com/support/t4047907-installed_xp_hot_fix
http://www.fixya.com/support/t1716701-problems_aardvark_q10
http://www.fixya.com/support/t3260184-aark24_installed_computer_windows
http://www.michaelchagnon.com/aardvark/software_sonar.html
http://www.sweetwater.com/sweetcare/ts/detail.php?Index=25505&Keyword=Aardvark&Archive=showarchive
http://www.sweetwater.com/sweetcare/ts/detail.php?Index=28034&Keyword=Aardvark&Archive=showarchive
Posted on Jul 24, 2010
I use a Q10 with XPSP3 currently.I used to have freezing problems but I discovered that the Order I loaded the drivers for all devices in my computer [Fresh Install of all including the OS]made all the difference.All my freezing went away.As we all have different systems I can only suggest change the order of driver install,not be more specific.
Posted on Dec 14, 2009
I have 7.13, use it with guitar tracks pro 3 from cakewalk. Q10 crashes a lot though and causes me to restart my pc. Any resolution to this? I have XP sp3 and intel pentium 4. 1gb ram.
Posted on Nov 29, 2009
Problems with Aardvark Q10
you can use it with sp2. just make sure you have disabled any other sound cards on your computer in the hardware device manager. you can download the drivers and manual here...make sure you use the 7.13 version
Feb 26, 2009 | Aardvark Direct Pro Q10 (bundle) External...
Os10 mac drivers for aardvark q10 pro
Jun 29, 2008 | Aardvark Direct Pro Q10 (bundle) External...
Aardvark Direct Pro Q10 wont intall with windows xp
I NEED A AARDVARK, DIRECT PRO Q10 INTERFACE (CONNECTOR) HOST TO BUY. CAN YOU HELP ME FIND ONE?
THANK YOU,
BRIAN MCBEAN
Feb 17, 2008 | Aardvark Direct Pro Q10 (bundle) External...
Aardvark q10
you can set the driver signing warning to 3 levels, ignore - warn - block. Yours are set to block. If the driver is not "official" according to microsoft's lists, the OS will not allow it to be installed. I know this because Roland doesn't get their drivers signed, and give specific instructions on how to change the setting.
control panel/system/harware tab/driver signing. Make your setting.
Jan 27, 2008 | Aardvark Direct Pro Q10 (bundle) External...
Smapls missing in kernal32
Go to C:\Program Files\Aardvark\ Aarkthk.dll and remove this file. It is an old file from win98 that didn't get removed when installing on winXP. Restart computer and you're good to go.
Dec 07, 2007 | Aardvark Direct Pro Q10 (bundle) External...
Aardvark q10 repair
Try Brentz music in Fort myers florida. brentsmusic.com
Sep 13, 2007 | Aardvark Direct Pro Q10 (bundle) External...
Drivers for windows vista???
this manufacturer no longer exists and only XP drivers can be found, no Vista i'm afraid
Aug 24, 2007 | Aardvark Direct Pro Q10 (bundle) External...
Aardvark Problem
You are looking for: "6' length, custom 25 pin shielded cable" Try on shopping.com or Amazon...: http://www.shopping.com/xFS?KW=custom+25+pin+shielded+cable&FD=0 You will find it there.. Good Luck. K.
Sep 10, 2005 | Aardvark Direct Pro Q10 (bundle) External...
Aardvark Direct Pro Q10 (bundle) External Sound System Logo
1,873 people viewed this question
Top Aardvark Computers & Internet Experts
David Payne
David Payne
Are you an Aardvark Computer and Internet Expert? Answer questions, earn points and help others
