Question about Rockford Fosgate Punch P325.1 Subwoofer Mono Amp - 175W Punch Series 325W @ 2 Ohms Remote Punch Ba... Car Audio Amplifier
Amplifier has no sound
There's power going to the amp but no sound
  • Rockford Fos... Master
  • 637 Answers
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Your amp is clipping.
A thumbs up would be greatly appreciated if this answer is helpful to you. amplifier has no sound - amplifier-no-sound-peeu4x5nsxvd53n2rwetiqa4-3-0.jpg
Posted on Dec 19, 2014
  • 55 Answers
The ground will not be the problem here as if it is grounded incorrectly the amp will NOT power up. Check the speaker cables to make sure there are no breaks. also check the rca cables for the same and make sure they are plugged in all the way. couldn't hurt to take a look at the remote wire. if you want to test the subs to make sure they are not blown try taking them out and hooking them to a home receiver you should be able to make sure they are carrying frequency that way. if so then check the head unit settings. Sometimes the wires inside the woofer box shake loose take one sub out and check if they are connected properly. Hope this helps.
Posted on Mar 08, 2009
    Problem Solver:
  • 4 Answers
For one... is the protect LED on?? Check the ground cable and make sure its on right, and check ur speaker wire from the amp to the box, and the box to the amp... red is positive, black is negative
Posted on Jan 10, 2009
Why does my car audio amplifier power on but has no sound?
This is a sign that the amp is being overtaxed by a subwoofer or other speakers to the point where it simply can't provide enough power. In home audio setups, clipping is typically caused by an underpowered amp or inefficient speakers, but loose or burnt wires can introduce similar problems in cars.
Nov 01, 2017 | RCA Car Audio & Video
No sound from subs
You need power to the amp. If the light on the amp is not on then your amp is the problem. Get power to it.
Nov 10, 2013 | Phoenix Gold Xenon-400.1 Car Audio...
I got a cadence q 4000 and i what a the bass to sound louder
the Q4000 only funs 400 max and thats at 4ohms bridged 2x200 if you need high powered amps i would look at soundstream or MTX and you would need atleast 1 secondary battery cause to max a amp out you need to have constant 14.4 volts going to power the amp.
Jul 31, 2010 | Cadence Q200 2 CHANNEL POWER AMPLIFIER...
My turntable connect to Carver Preamp, I bought a
If you can hear music with the volume up, but like it was turned down low (from the power amp), then yes there is something up with it. If it's the same on both left & right channels, then it's something common to both. For instance the power supply, or an IC that has both channels going in it.
If however the power amp does produce sound normally with another device, then either the turntable has a fault, or the pre-amp has, perhaps on the pre-amp inside it for the cartridge.
Dec 16, 2009 | Yamaha P-2500 Amplifier
Speakers are connected to pre-amp or power-amp? pls explain connections , what connects with what , between cd player + pre amp + power amp + speakers.
Do this, CD audio out jacks to the PRE-AMP INPUT jacks, then PRE-AMP OUT jacks to AMPLIFIER INPUTS then from AMPLIFIER to speakers, This will work similiar with any sound source unit ie. Radio Tuner, Tape deck, etc. Just think of it this way, a PRE-AMP is BEFORE the AMPLIFIER, all the AMPLIFIER is going to do is AMPLIFY the sound to your speakers, HOPE THIS HELPS!
Feb 03, 2009 | Audio Players & Recorders
No power no sound
this may be because there is no signal going to the RMT terminal on the amplifier. try connecting a +12v line, this line tells the amp to turn on. it is normaly connected to the header unit of the car so that it will turn on the amp when the unit is powered on.
Dec 27, 2008 | Boss C550 Car Audio Amplifier
Rockford Fosgate P3002 Amp
what are the color of the lights that stay on.red= protect/ green=on.if the amp has little sound it probably still working,check deck output volume(rca)
Aug 22, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
Amp not putting out any sound
Check you pre amp RCAs and make sure they are holding a voltage...this is where the Amp takes that signal and amplifies it...without this connection the amp will not produce any power.
Jan 31, 2007 | Sony Xplod Amplifier XM-SD51X - Class D...
NEW AMPLIFIER WILL NOT LIGHT UP OR POWER UP
It sounds like your saying that you have two identical amp, that both are on the same power wires and remote wires and sam grounds? Well if thats the case then you did ok as One amp sounds like its blown. First tghing is check the main fuse. If its good and the unit still dosent resond then the power supply in the amp is blown as theres a switching supply that increases the 12 volts to get power to drive the Mosfet output devices. Was it ever working?? yes then the amp needs service. Do you know how to work on solid state elctronics down to componet level?? No?? Ok contact these folks at the addy im posting for you or take the amp to your local servicer. Good Luck. AudioSupport@VisonikCarAudio.com
May 07, 2006 | Visonik VB212PKG Car Audio Amplifier
Car Audio & Video Logo
446 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
