Question about RCA F27650 27" TV
Tv screen is stretched too wide
Comin back from a week vacation, i turn on my rca f27650 to play xbox and i realize that my screen has been stretched out of proportion! i cannot see sides of the proper picture. i swith it to tv mode and the channels on the top left only show half of the first number! after trying to play around wit the menu settings to see if anything can be done to play wit the parameters! i went on my xbox 360 because i knew that there were settings in there to change screen fittings! what i found as a success (somewhat) was that when i changed the xbox screen format from normal to widescreen, the picture was formatted and actually fit the screen....kind off! the screen was no longer stretched and i was able to see the whole screen. even wit this somewhat succes, unfortunately the corners of the image were warped and appear compressed to fit format! i have tried troubleshooting from online but i have been most disappionted.
~ i have kept it unplug for hours / days to try a reset.fail
~ i have researched on how to acces the service menu for my model so i can adjust it but i seem to be finding only instructios for the generic rca service menu! the steps:
hold menu, press release power, press release vol up, release menu
i havent been able to get to the service menu at all!
i thought that i might have already activated it but the screen jus didnt let me see it so i went and tried to acces this generic service menu on my other rca tv! it was a truflat rca model f20t10 ! similar guidpluss menus and all but i believe a bit newer! even on the rca f20t10 i was still unable to acces any service menus!...if you got any info on how i can fix an fit my screen please please let me know! thanks in advance
  • braswela Jan 21, 2009
    I have the same problem. The screen is stretched too wide (horizontally); but other than that, the picture quality is fine.
3 Suggested Answers
  • 905 Answers
SOURCE: RCA 27F520 Shutdown after a few seconds
you have lost the vertical ic and maybe resistor or capacitor.
but you also maybe loosing the horizontal ic
you will also have to check the voltages on the flyback transformer that go to those circuit's to see if they drop or are correct
Posted on Dec 22, 2008
t5mustang
  • 3 Answers
SOURCE: RCA HD27F754T picture color and screen size.
check your hook ups, sounds like you have a component hook up conected to a composite jack.
Posted on Mar 09, 2009
PICTURE TO BIG AT THE SCREEN.CAN NOT SEE THE PICTERS MARGIN AT THE SCREEN.HOW TO ADJUST(REDUCING PICTURE SIZE ON SCREEN)?
1) Power your wide-screen TV on and turn to a channel that is displayed with bars on the side. You need to leave this channel on to ensure you have properly adjusted your wide-screen TV.
2)
Find in your TVs settings where you can "stretch" the picture. Refer to your wide-screen TVs owner's manual for specific instructions. Some TVs may not refer to this adjustment as "stretch." You will be able to find all the information your looking for in the owners manual.
3) Adjust settings back to normal if you want to watch a program shown in 16:9 format. Keeping the screen "stretched" will cause programs shown in 16:9 format appear zoomed in, making the picture look really different.
Aug 14, 2010 | Televison & Video
XBox 360 freezes and gets red checkered screen
make sure the display adapters are properly plugged in and that you have the switch set to either hd or tv on the back of the xbox....also make sure the connection from the rca's to the tv are secure
Apr 25, 2009 | Microsoft Xbox 360 Console
Horizontally Outstretched
Hello Toasty07,
This problem is called blooming it is caused by poor high voltage regulation. To fix this problem I would suggest that you take the TV to a TV repair shop because the section requiring the work contains very dangerous voltages and a great shock hazard exists. Just tell the TV repair person that you believe the Tv has a HV regulation problem and to concentrate on the HV section of the TV.
Thank you,
Shuttle83
Jul 23, 2008 | RCA F27650 27" TV
52 in RCA
The RCA needs a flyback if its an ITC222 chassis which is waht the D52W20 RCA is. You can get a replacement flyback at the following link with free tech support so you can do the repair yourself which is a very easy repair. You need flyback number 259296. As far as the XBOX you should never play any video games on a rear projection TV as it can cause burn in on the CRTs if it is paused. video games are best played on a direct view, plasma or LCD TV. Rear projections like the RCa is not a good idea because of the possible burn in. heres a link to your flyback 259296
http://servicemanuals.vstore.ca/
May 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Wide screen
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made.
For example:
A Motorola Cable box needs to be set up to go to a wide screen or zoom when an analog signal is detected.
Some Dish Network boxes have Size buttons on their remotes and also in their main menu.
The name of the button on the remote is called format.
It's difficult to determine the repair without knowing the types of the peripherals.
Hope this helps.
Jan 18, 2008 | RCA F27650 27" TV
Model F27650 RCA Entertainment Series
I have a RCA Entertainment Series 32' Model Number F32650Y01E024C226E just stopped working. no picture, just a chirping loud noise that came from the back of the tv.
Any suggestions?
Jan 06, 2008 | RCA 32F531T 32" TV
Tv turns black and white
No, the tube is not bad. There are a couple of very small surface mount components mounted by the main microprocessor that could be causing what you are seeing. They are very small and quite hard to unsolder and replace without losing them. The set should be serviced by a qualified tech familiar with the new RCA chassis.
Aug 21, 2007 | RCA F27650 27" TV
RCA F27650 27" TV - Snow Bursts
The model you listed, F27650 uses the new ATC113 series chassis, which is only about 3 years old. The ATC113 chassis is not known to have snowy issues, but if yours is then I would suspect that a solder joint is loose in the tuner. If your set is actually around 9 years old, then it might perhaps have the notorious CTC175 - CTC187 series chassis, which went snowy all the time due to cracked solder joints on the shield grounds around the tuner and microprocessor. In either case, some good quality resoldering should cure your trouble. If you have never done fine solder work on PC boards with small surface-mount parts, allow a qualified tech to handle it for you.
Aug 08, 2007 | RCA F27650 27" TV
Rca f27650 27"tv w/vport
The hdmi port is for high definition multimedia interface. You should be able to send standard video through the Vport to your set. (RCA phono jack and plug) Stargazer
Apr 21, 2007 | RCA F27650 27" TV
yes it could ba the cable itself even, but i suspect more the tuner circuit or tuner itself may have bad solder connections. Here is another test for you to try, plug another dvd or vcr, or xbox etc. into the back, using one odf the inputs. See if this works like the built in dvd. if so it will be more likely bad connections in the tuner or surrounding circuit. good luck.
Dec 17, 2006 | RCA HD52W56 52" Rear Projection HDTV
Open Questions:
Letterboxing: The top and bottom of the screen are cut off I originally obtained this TV from my Bro who passed away from cancer at age 31 a few years ago & I was never able to find out what he did with the manual. However, I was able to find a manual online but after viewing it, I still wasn't able to find the info. that I am trying to obtain for the correct settings to get rid of these black margins at the top & bottom of the screen. I am trying to find out what video output format is supported by this TV model, as far as the resolution and output format, specifically for a Cisco or AKA Scientific Atlanta 500GB HD-DVR through Cox cable? My available settings with Cox cable & the DVR I have( Cisco or Scientific Atlanta 500GB model)are the following-Resolution:480i, with output format of either:Zoom 16:9 Pic or Letterbox 16:9 Resolution:480p standard, with output format of either:Zoom 16:9 Pic. or Letterbox 16:9 Resolution:480wide, with either output format of:Stretch 4:3 Pic, Preserve 4:3 Pic or Sidebar 4:3 Pic Resolution:720p wide, with output format of:Stretch 4:3 Pic, Preserve 4:3 Pic or Sidebar 4:3 Pic and finally, resolution:1080i wide with output format of:Stretch 4.3 Pic, Preserve 4:3 Pic or Sidebar 4:3 Pic? Everything worked fine with the screen size when I had a 160GB Motorola HD-DVR with Cox under the video output settings of:resolution:480i and video output of:Zoom 16:9 Pic until, I grew tired of constantly running out of space & had them switch me to a 500GB HD-DVR. They were supposed to install another Motorola HD-DVR but just with 500GB version but when the Cox maintenance employee showed up to swap them out and install the 500GD HD-DVR, he only had a Cisco/Scientific Atlanta 500GB available on his truck, which is I guess what they use for the Contour service but he attached a filter to the back of the coxial cable to make it a regular HD-DVR without Contour(even though they tried charging me extra for contour for 3 months before I finally got that straightened out since the maintenance workers & billing dept. are often not on the same page as I found out at Cox. I have tried calling Cox for support & they say that I need to find out & know my TV's video output settings. I explained to them that it worked perfectly fine just weeks ago with 480i resolution and output format of Zoom 16.9 Pic before they switched to the Cisco/Scientific Atlanta HD-DVR from the Motorola DVR and that I didn't have the manual and I stated why and they basically said, too bad, figure it out yourself. Can someone please help me out? I have the TV set up for the correct zip code, cable box-Yes, the cable box output channel-video 1/Aux (since that is what the TV manual I read online said to use if you are using the 3-color coded cables instead of the coxial cables to plug in from the TV to the HD-DVR) & I have the Cable box remote control code set to code 008 (Scientific Atlanta) that I verified to be correct by checking it through the TV's automated code search. The serial # for the TV is:C306B2084 and the Chassis # is:ATC113BB1 and its the 27" RCA Entertainment Series Guide Plus Gold Gemstar that is X-Box ready. Thanks so much, Todd
Feb 26, 2017 | RCA F27650 27" TV
RCA F27650 27" TV Logo
851 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
