Code E3 My wasing machine will not work and keeps showing the code E3. What does E3 mean?
  • 8,197 Answers
The Machine control is attempting to drive the motor but is not seeing any tachometer response or motor action. It could have a failed tachometer/hall sensor which is part of the motor, failed motor or machine control. It could be a loose wire connection at the motor or at the machine control board. This type of failure will require a technician to diagnose and repair your washer. I recommend calling a service technician.
Posted on Jan 10, 2009
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
What does E3 error code on Janome MO 200 sewing machine mean?
If you do not have your user's manual, you can purchase another one at several sites for a nominal charge, and download it immediately. I would recommend that you have one, and keep it near or under your machine.
You can also contact Janome customer service, either by email or phone, and here's the link: Janome Contact Us
Sep 13, 2014 | Sewing Machines
Maytag laundry neptune front loader washer MAH6700AWW. It is showing a E3 code error. what can we do for that
Hi, the E3 error means that the control board is detecting current going to the motor, but the motor won't turn properly. If the error code comes up all the time as soon as you press the power on button, then it means your control board is bad and reading incorrectly. If it only happens during a cycle, then you need a new motor unfortunately.
Jun 16, 2011 | Maytag MAH6700AWW Neptune Front-Load...
The machine does not make copies showing an error E3 which i can not see where i can find it
yep!
e3 means a machine error and it need a service technician to fix it.
furthermore may i ask what e3 code displays on the screen (you might see something like this e3 10 , e3 40 , e3 01 etc)
i can still help you if it is e3 10
Jan 04, 2010 | Panasonic FP-7735 Black and White Copier
We are getting error code E3. What does this mean
Looks like you have either a stuck drum (does not spin) or an electrical fault that make the washer think the drum is not moving.
From a 2006 Technical Bulletin:
E3: Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Specifically, it could be:
1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause.
2. Hall Sensor (integral part of motor) fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Unless you are really overloading your machine you likely have an electrical fault, or a failure in the drive train--especially if the problem is intermittent. Probably time to call in a technician.
Aug 13, 2009 | Maytag Neptune MAH9700 Front Load Washer
E3 keeps poping up
Hello leggettelect,
The e3 code has to do with the Hall Sensor. This is a sensor that looks at motor RPM. There have been some issues with the wire harness or the harness connectors being loose. You can also get the code if the sensor itself is loose and cant read the motor RPM. Here is a link to a tech bulletin from Maytag explaining it in more detail and has some pictures so you can see what to check. Hope this will fix your problem.
http://www.servicematters.com/maytag_library/docs/TDL-0078A-B.pdf
Thanks,
edgin96
May 12, 2009 | Washing Machines
E3 error code will not wash, what does this error code mean?
i have a maytag washer and it says E3 and it will not work,does anyone know what that means please let me know...thanks
Apr 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
E3 code showing sometimes on Neptune MAH-3
“E3” code – Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Possible causes of ‘E3’ codes: 1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause. 2. Hall Sensor fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Hall Sensor – PCB that is located on the back of the motor that senses motor rpm. It is not a separate part, but rather an integral part of the motor.
Mar 11, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
232 people viewed this question
Top Washing Machines Experts
