Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
HE3t Sanitize light does not illuminate at end of cycle
I purchased an HE3t from Sears in October 2008.  After using the machine for a bit, I noticed that the blue "Sanitized" light did not illuminate after completion of a cycle that included the "Steam Treat" option with "Steam Sanitize" selected as the wash temperature.  I contacted Sears and 8 service calls, 3 replaced boards (CCU twice and the Keyboard Interface once), multiple calls to the factory, Sears, etc. later, I finally have a washer that performs as detailed in the manual.
Ultimately, it turned out that the problem was a software bug and replacing the CCU board the second time corrected the problem. Meanwhile, I lived through a trail of service personnel, one even suggesting that the manual was incorrect and the light was not intended to illuminate.
Has anyone else had this problem?  It's hard for me to believe that my 2008 version of this washer was the only one with this software bug.
  • 15,935 Answers
It appears your controller board has failed in this instance. There was a bad part used in the controller - and has been replaced. If your controller was replaced with one from NOS... it will have the same problem.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
My Kenmore Elite 3T washer has a loud whistling noise in the spin cycle. ??? Thanks!
Hi.
When that happens it is often because the drum bearing is starting to go. The first symptom is a loud high pitched noise during the spin part of the cycle. As problem gets worsening you will notice that the drum will be a bit wobbly if you spin it by hand.
Here parts and diagrams.
Regards.
Ginko.
Mar 10, 2011 | Kenmore HE3T Washer
Moter switch bad in new washer
if you used sears for the repair i believe they will fix it for c.o.d. and than sell you an extended warranty on the whole machine if you want to.
Jul 29, 2010 | Kenmore HE3T Washer
Washer stop and flashes 20 F
this sounds like the hose to drain is cloged or the pump is blocked up in back of washer were drain hose is at remove back the hose that drains from tub to drain needs to be checked remove clamps and flush hoses,than look in pump and remove debri,and put back together take cloths out and sanitize machine remember use bleach and hot water or use pool shock a eighth of a cup and add in detergent desp. and let it sit his well be more powerful and get rid of meldew,i hope this helps
Dec 22, 2009 | Kenmore HE3T Washer
Kenmore he3t washer: clothes come out hot even on cold rinse. How do I turn off the steam/sanitize?
You will have to check your owner's manual for that. Now that's for the steam/sanitize. If you turn that off and it still does it, it's most likely a fault in the fill valve.
Dec 16, 2009 | Washing Machines
My dishwasher has the sanitize option but at the end of the cycle the sanitize light is not on. It is about 3 years old. When does the sanitize happen during the cycle so I can open the door and measure...
Check your owners manual to see when the light should come on. If it comes on due to high temps, then the heater element may be bad. Run it, then see if element is hot (be careful !)
Sep 27, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Smelly Clothes...yuck!
Well, hope you avoid a lawsuit.
Putting the machine in perspecive....It uses water, soap, movement, and drains.
So, you start at the source water, and GUARANTEE that it is clean and pure (same as all other sources in your home) No cheating, take it off and run water into a 5 gal bucket, EACH hose.
Then, witness the drain volume, Pull the hose and observe while draining. the most likely issue is water is restricted from exiting the machine by some foreign material...
Typically, the machine would not loose efficiency without something being broken....
Sep 20, 2009 | LG WM2688HWM TROMM SteamWasher
Kenmore Elite HE3t Steam Front loading Washer
It appears your timer/main controller/CCU has failed in this instance.
Jan 25, 2009 | Washing Machines
Water not going into machine
The repair guys are right.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 14, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore elite HE3t 2004 washer quits during spin with f11 code
Under the bottom panal (after you remove it) look to the left towards the middle and you will notice a white box looking part, this was our problem and sears ended paying 100% of parts which run about $215 before labor, this is a very easy fix and my husband replaced that and also our control buttons all werent working which sears also paid for 100% after much bickering over the phone and the service man taking care of it for me! it took him about 20 min to do both parts and our washer is working like a pro again! Our washer is the HE 4T and was flashing the F 6 AND F11! this is a lemon machine and sears should realize it and actually take care of its customers! i did notice a class action law suit on this machine and i have emailed the attorney taking care of it,
Nov 19, 2008 | Kenmore Elite 45986 Front Load Washer
Flashing F6 Error Code
motor controller board in bottom
Nov 11, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
63 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
