Tlevision is dead
WHEN I PLUG THE SET IN THE GREEN LIGHT IS ON AND THE SCREEN VERY DIMMLY FLASHES EVERY TEN SECONDS.SET WILLNOT RESPOND TO ANYTHING I DO.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
To even try to help I would need to know brand and model.
Posted on Dec 22, 2012
5 Suggested Answers
  • 12 Answers
SOURCE: Losing Picture
It sounds like the tv is dieing but since it is rear projection you may be able to fix the problem by replacing the bulb in the tv
Posted on Jun 20, 2007
Slinteriors
  • 8617 Answers
SOURCE: flashing green timer light, no image on TV
4 capacitors on the DM board causes this they are 1000uf @35 volts replace these capacitors and that should take care of your problem
Posted on Mar 19, 2008
TEVA Guru
  • 65 Answers
SOURCE: what the error code means
Reference this:
Mitsubishi TV Codes
Hope this helps
Posted on Oct 02, 2009
Ecollier2012
  • 3459 Answers
SOURCE: Set will not turn on. I replaced the fuse and
On this model there is a common failure with some capacitors and fuses. Its a simple fix if you know which parts to use/avoid and how to do the repair. You can get complete instrucitons and parts for your model from www.TvRepairKits.com . Their kits include step by step color instruction guide as well as the correct parts to fix this issue.
Posted on Apr 18, 2010
I have a Mitsubishi WD 60738 and the stand by light on the front of the tv was staying on and was orange. I removed the power supply and blew out all the dust and reinstalled the power supply and now the...
Hello Jeff;
If the TV does not turn on or off, does not respond to the remote
control or the control panel buttons, or has audio but no video:
1.) Press and hold the POWER button on the control panel for ten seconds. The TV will turn off.
2.) Power on the TV and the green LED will flash quickly for about one minute. The changes you made most recently, before using SYSTEM RESET, may be lost.
If the TV does not respond to the remote control or to the control-panel buttons and TV will not power on or off.
• Unplug the AC power cord for 10 seconds.
• Press and hold the POWER button on the control panel for 10
seconds to perform a system reset.
If the TV turned itself off and the light on the front panel started to flash:
• Momentary power fluctuation can cause the TV to turn off to prevent damage. Wait for the green light to stop flashing and turn the TV on again.
• If the TV does not stay on, press the POWER button on the
control panel for ten seconds to perform a System Reset. If this happens frequently, obtain an AC line power conditioner/surge protector.
• An unusual digital signal may have been received, triggering a
protection circuit. Wait for the light to stop flashing and turn TV
on.
If the TV will not power off, press the POWER button on the control panel for ten seconds to perform a System Reset.
Should you still have problems, call for assistance at 1(800) 332-2119
I would not recommend using compressed air or any other method that would blow dust around- since the dust could make its way into the set's circuitry via the grille or vents and cause problems. Use a vacuum cleaner with a brush attachment instead.
Mar 12, 2015 | Mitsubishi Televison & Video
Off and Ten Red Blinks?
ALL MY TVS ARE SONY.4 YEARS AGO I HAD SIMILLAR PROBLEM AND I JUST CALLED THE SONY CENTER HERE IN GREECE!I TOLD THEM THE FLASHES AND TOLD ME TO DO 3 THINGS.FORTUNATELLY THE 2ND WORKED AND RUNNING SMOOTH SINCE THEN.SO JUST MAKE THE CALL TO SONY NO OTHER REPAIR MEN!U NEVER KNOW!!
May 19, 2014 | Sony Televison & Video
Sony TV model KDL-46Z4100, standby light flashes 14 times, no picture, no sound
14 blinks to Sony Brand LCDs indicates a 'Backend error'. It means that, the main board to this TV should be checked for fault. In most cases the main board might need replacement, and a software update too. If you wish to know more details about this blinking code, check this link. It has details of blinking codes to several brands of TVs including Sony. Actually the work is a skilled one, need experience.
Jan 20, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Tv is dead
To even know if I can help I would need to know brand and model number.
Nov 27, 2012 | Televison & Video
Orange light flashes 5 times then green flashes once then repeat Can't get printer to do anything else. Have unpluged it for ten minutes no luck Have removed print head and replaced it, no luck....
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.For printer
Mar 22, 2011 | Canon BubbleJet i560 InkJet Printer
I have a legacy item (Roadmate 800). The battery was dead so I ordered a new one. The new battery powers on the unit but when I plug in ac charger I don't get a solid orange light, but a flashing green...
This is very common problem with this and many model of magellans.
Try the car charger.
Make sure
green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
The following Magellan 2000, 2200t, 2500, 3000, 3100, 3140, 3000, 3050, 4000, 4040, 4050, 5310 and the 6000 are known to have faulty dc connectors...if your Magellan
gps is not charging or will not power up, its most likely the dc power port...
You can
buy the port or get it repaired, HERE
if the links dont work or If you need further help, just let me know.
Feb 07, 2010 | Magellan RoadMate 800 GPS Receiver
DS lite green light comes on, top screen flash,then switches off
Check L2 near the power switch on your DS mobo. That part usually get loosen or taken out when you drop your DS. And usually you can recover it when dismantling your DS.
Jun 16, 2009 | Nintendo DS Lite Console
Green television screen on a princess tlevision
can you clarify that are you seeing white bright lines on screen & is there faint picture with green color?
Sep 16, 2007 | Televison & Video
Satellite receiver
dont need factory to reflash.
turn of set at plug.press and hold backup on set(keep pressed)
turn on at plug.keep backup pressed for about 15 seconds.all lights on set will flash.if you have tv tuned to set screen will display updating system.dont turn off.when lights on set go off(about 10min later)set is reset(flashed)Press power on remote sky will restart like new.
Sep 03, 2007 | Panasonic CR-SRF100 SIRIUS Radio Receiver
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
