Question about Maytag LAT3600A Top Load Washer
MY whirlpool WASHER MACHINE FILLS WITH WATER BUT DOES NOT WORK AFTER THAT. IT DOES MAKE SMALL NOISE LIKE MOTOR BUT DOES NOT WORK.
    Sergeant:
  • 198 Answers
1 Points
Posted on Nov 27, 2012
4 Suggested Answers
  • 1314 Answers
SOURCE: I hear motor but machine won't wash or spin.
http://maytag.com/support/manuals_literature.jsp try here for warrenty
Posted on Jan 16, 2008
SOURCE: MY GE WASHER MACHINE FILLS WITH WATER BUT DOES NOT
it is not a maytag washer machine it is G.E it fills fine with water it also drains and spins but does not agitate.
Posted on Apr 11, 2009
  • 58 Answers
SOURCE: Washer stopped at begin of wash cycle
The problem seems to lie in the rubber backed mat. If the rubber has begun to peel of the mat it often-times get stuck in the drain pump. The best thing to do at this point is to disconnect the electrical cord, open up the machine, drain out the water as best as possible disconnect the power cord to the drain and the hoses. Clean out the drain pump. reassemble. You should be good to go., Unless the drain pump is burned out (left running plugged up too long) if thats the case, replacement of the pump may be neccessary.... Hope this helps...Good luck!.... Bill
Posted on May 18, 2009
Washer is filled with water and will not drain
if the motor is running your drain is probably plugged where it enters the pump if the motor does not run or make a humming noise the lid switch may not be working or the pin that presses it may be broken some times it is worn and by gently pressing it a little farther with a small pen will cause it to work long enough to drain the machine till you replace it.
Mar 08, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a Whirlpool Model LXR9245EZ2 top load washer. Yesterday I put a load it, it filled normally, but wouldn't start agitating/washing the load after it filled. Instead, it made an unusual noise. It...
Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Here is the part you will need. Here is a video to walk you thru the repair process.
Dec 05, 2010 | Whirlpool Washing Machines
Whirlpool type 111 model LSQ9200LQ3 washer not
I have a whirpool model:lsq9200lq3, and recently it has stopped working. when ever you turn it on, its fine and the water fills up normally and right before it gets to the spinning cycle the machine makes a grinding noise like if something is stopping the motor from spinning, and it dosent spin inside the washer. if anybody has any suggestion It would be great thank you.
Jan 30, 2010 | Whirlpool Washing Machines
Whirlpool top load washer makes noise on filling
Its mainly caused by back pressure when the inlet valve suddenly shuts off the water to the machine. The pressure causes your plumbing pipe work to shake inside the walls.
You can turn down the pressure by closing your water tap and only having it slightly open. Or you can get pressure limiters which join on the hose.
Regards
Ash
Oct 26, 2009 | Whirlpool Washing Machines
MY GE WASHER MACHINE FILLS WITH WATER BUT DOES NOT WORK AFTER THAT. IT DOES MAKE SMALL NOISE LIKE MOTOR BUT DOES NOT WORK.
Apr 09, 2009 | Maytag LAT3600A Top Load Washer
Machine will not agitate, but it allows the water to drain.
soundsas if you have possibly broken youor motor coupling( this machines "belt") easy repair, yo can see video as to how to replaceit by searching you tube for whirlpool motor coupling
Mar 16, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool washer fills up; makes LOUD whine/click metal noise
sounds as if you have a bad mootor coupling, part number 285753, easy enough part to change, easier to search on the you tube site for whirlpool motor coupling repair, fo rthe video, then try to explain procedure, but definalty easy enough repair for home owner
Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Our Whirlpool washer won't drain
this machine has the pump directly atached to the pump assy, so if the motor is runnning your pump will drain water. more likely is that when you put the unit back together perhaps you didnt plug the lid switch assembly bak in. if there is no lid switch detected the unit will not drain or spin and when it gets to that mode it will simply stall out. no noise or anything. will fill, agitate but not spin and/or drain/ check the lid switch!
Nov 11, 2008 | Whirlpool Ultimate Care II GSQ9669L Top...
Whirlpool noise
Ok can you take the front panel of the washer off easily?
If you can look for the motor pump assembly. Start the washer with no load, turn the water level down to the small and fill with water when it goes into agitation does it make the noise? if not turn timer to spin and see if motor makes the noise.
One other thought, maybe the smell is coming from the dryer?
Let me know. I wont be on line again until Friday Sorry
May 26, 2008 | Whirlpool LTE5243D Top Load Stacked...
Machine wont wash
needs a new motor coupler. small round rubber piece between the motor and transmission. easy to replace
Oct 29, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag LAT3600A Top Load Washer Logo
116 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
