Question about Coffee Makers & Espresso Machines
Why when I try to make some coffe show er2 er3 coffe maker 169164 ge
freetek
  • 5568 Answers
SOURCE: GE Cofee MAker Model: 169164
Most failures of coffee makers are related to thermal fuses which have opened and interrupted the current flow to the heating element.
Often, they failed for no particular reason but replacing the fuses would probably cost as much as tossing the whole machine.
Yeah, I know, I don't like it either.
Before retirement, I earned my living fixing stuff we can now buy cheaper new.
Posted on May 21, 2008
Wasprey
SOURCE: GE 169164 coffee maker problem
*** HOW TO RESET THE GE 169164 COFFEE MAKER ***
After endless online searches yielding the same results (nothing useful), I figured out how to reset this coffee maker.
While coffee maker is plugged in and the evil little blue light is mocking you relentlessly, press and hold the 1-4 button and the TSB button simultaneously for 3 seconds or so. This will cause the device to exit it's error status and allow normal use of it.
Posted on Dec 28, 2008
SOURCE: new charcoal filter for GE COFFEEE-MAKER MODEL NUMBER 169164
Call your local Wal Mart Stores..... even if you have to call 2 or 3 stores..... after several attempts to call the customer support phone number (what a joke) I did not want to waste my time on hold.
I decided to call all of the local Wal Mart Stores in my ares.and I found the filters for the 12 cup digital coffee maker model number 169164.......... (they come in a pack of 2) at the Wal Mart store in West York PA.....
I may end up purchasing 2 packs.........
I hope this email with help you with your search.............Good luck. They are out there, it just takes alittle searching and with no thanks to our wonderful GE help line.
Barb
Posted on Feb 07, 2009
  • 4 Answers
SOURCE: looking for a Carafe replacement for my GE coffee maker
Try to find the replacement coffee pot at walmart it is by the other coffee makers
Posted on Mar 09, 2009
  • 4 Answers
SOURCE: how do i use cleaning cycle on ge self cleaning coffee pot
You can find the instructions in this pdf file the link is http://www.gehousewares.com/products/200836153329360.pdf
Broke glass carraffe, need to replace model 169164
I replaced my broken carafe on model: 169164 by purchasing a RIVAL 12 cup coffee maker PIL-HC08104 from WalMart for $10.24 and simply put my black handles on the new pot whaic had white handles. The pot appear to be exactly the same.
Nov 01, 2009 | GE 106591 Coffee Maker
I have a kenmore 12cup coffe maker. The carafe
I had the same thing happen when my carafe broke. Mine is 238.69328 which is the black coffee maker. The simple solution is to head to Walmart and buy the GE replacement carafe. It's the 12 cup capacity one #169164. The box has 169180 on the bottom and it works like the old one and looks just as good no matter what color your coffee pot is.
Jun 14, 2009 | Kenmore KBC12 Coffee Maker
Replacement Part - GE Coffee Maker 169164
Need spare parts or accessories, please call our Customer Assistance number.
1-877-207-0923 (U.S.) or 1-877-556-0973 (Canada)
Just give them that part number, and they can order it for you
Mar 16, 2009 | Coffee Makers & Espresso Machines
Ge 169164 put in 12 cup water stop at 4cups
I have the same problem the water filter is on too tight try lifting the filter a Little bet high or twist the filter or your filter might need to be change hope this answer works for you.
Jan 27, 2009 | GE 106591 Coffee Maker
Past 2 mornings, coffee maker only brewed 10 out of 12 cups.
It's probably time for a good cleaning. Follow the procedure in the manual, or get some commercially available coffee maker cleaner. When the minerals build up enough, the water flow and heating is reduced enough to keep it all from passing through.
Please take a moment to rate this solution if it's what you needed, and thanks for asking here!
Looking for a Carafe replacement for my GE coffee maker
I've replaced my coffee pot from my local Ace Hardware!
I'd call first!
Good Luck!
Jan 18, 2009 | Coffee Makers & Espresso Machines
Coffee maker clicks but does not brew
This information is for the GE model number 169164 12 cup digital coffee maker.
The Micro fuse is shorted open. There are two underneath the housing. They are made by MICROTEMP® and are the G400 series rated at 216 Degrees Centigrade.
You can check these with a Ohm meter to see if you have continuity. Checking across the leads of each one they should show infinity. If not you've identified the bad one. You can pick up a new thermal fuse at Radio Shack. The closest one to the specs of the Microtemp is a Radio Shack part number 270-1321 rated at 228 Degrees Centigrade. Before removing the old one notice which way the hat end faces.
Use a heat sink when soldering the new thermal fuse in place by using alligator clips or a pair of pliers.Reassemble and your back in business as a Barista.
Note: There are four Phillips head screws under the rubber pads. The three unusual screw heads may be removed/installed with a small screwdriver installed in just one of the slots.
Nov 16, 2008 | GE 106591 Coffee Maker
GE Model 169164 Paper Filter Size?
# 4 coffee filters made by militta. I have the same maker and i hate all the coffee grinds in the pot
Oct 20, 2008 | GE 106591 Coffee Maker
Coffee Makers & Espresso Machines Logo
37 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
