Question about HTC Touch Diamond2 Smartphone
Recoverymode malfunction wifi error and recovery mode stuck in android logo
  • 166 Answers
I hope you have bricked up your phone. Just use ODIN, download stock rom zip packages, put phone in download mode, plus USB, load rom files in ODIN, flash the update and then it will work. (Actually it worked for me).
Posted on Nov 27, 2012
My Galaxy is stuck on Samsung logo. Why won't it switch on?
Samsung Galaxy Android Smartphone: Stuck on Samsung Logo (booting up)
Hello.. I'm assuming that you did not try to install a ROM or update the firmware in any way.. doing so and interrupting the process or if on a bad connection with WiFi, or downloading a corrupt install file can break your phone causing problems.
For whatever reason this happened try the following instructions:
  • pull your battery out
  • then re-insert after 30 seconds
  • boot into recovery mode (see attached video) [Press at same time: Power button, Volume up, and Home button.. when you see the blue words at top take finger off Power while still holding other buttons down until you get into Recovery Mode (you will see a bunch of lines of text.. if you see a little green robot says "installing system update" let it do it while taking fingers off all buttons.. it may say "error" = ignore this.. then you will see all the text]
  • wipe date, wipe cache, reboot [*be extra careful what you select: use your down volume key to scroll to wipe cache partition" use the power button to select this [you do not want to select "wipe data/factory reset" unless there is no other hope of getting back into your phone]
  • it takes less than a second to wipe the cache partition, then use the power key to select "reboot system now"
If the phone reboots fine you are done..
>> If the phone refuses to reboot, and hangs again at the Samsung Logo, then you know you have to go back into Recovery Mode and select "wipe data/factory reset" = after which you should be able to get back into your phone but it will wipe all of your data/everything clean from your phone. Your phone will be as if you just bought the phone with nothing of yours on it. You will have to setup your phone all over again.
Jan 30, 2016 | Samsung Cell Phones
Rooted Huawei Vitria is boot stuck on metro logo screen. need recovery flash
Try searching XDA or AndroidAuthority for the recovery image you need. I assume you rooted it, but if not: To flash the recovery you need to enter recovery mode, usually this is done by holding "Volume Down" & "Power" at the same time until the logo appears, then release the "Volume Down" button. Once in recovery if it's not a touch recovery, you use the volume keys to navigate up and down, and the power button to accept your selection. Just click the option that says to install from zip, then choose your zip file for the recovery and you're golden.
Mar 30, 2014 | Android Huawei
Sync problem with Tab 3
I suggest a hard reset.
  • Ensure that the Samsung tablet is powered off.
  • Press the Power and the Volume Up button together till the device displays the start-up logo.
  • Once the logo is displayed, release the buttons and wait till the device enters the Android system recovery mode.
  • On the displayed screen, use Volume Down button to go to the wipe data/factory resetoption (Volume Up and Volume Down buttons are used to highlight the displayed options on the Android system recovery screen).
  • Once the option is highlighted, press the Power button to select the option. (Pressing thePower button in Android system recovery mode selects the highlighted option.)
  • On the next screen, press the Volume Down button multiple times till the Yes -- delete all user data option is highlighted.
  • Press the Power button to hard reset the Samsung tablet device while clearing the dalvik cache along with the process.
Feb 01, 2014 | Samsung Galaxy Tab Tablet PC
Help me please
Is the Boot loader unlocked? Did u try installing a custom firmware? 7_3_2013_1_55_01_am.png
Jul 02, 2013 | Android Apps
My hl & rich tablet is stuck on the android silver logo and does not start up.
I found this somewhere. I hope this will help you:
that picture you're showing seems bad, but actually THAT IS the recovery mode! android-smile.png
Just wait 5~10mins and it should be fixed!
Also, for easier removal of Unlock Patterns on Android, use the Uberizer!
HcH
Jan 02, 2013 | Google Android
Tablets wont boot up just shows arnova on screen and shuts down
I had same problem looping startup just showing Aenova screen, i tried the pin thing ended up doing a factory reset IT WORKED WAHEY!!
How can I do a Factory Reset on my tablet? If your tablet freezes often or if you get error messages during the start up of your tablet, you can use the recovery mode to reset your tablet to its factory settings, removing all installed applications as well as any data or content.
Your tablet must be up to date with the latest firmware - downloadable from the downloads area of this website.
To access Recovery mode on the ARNOVA 10bG3
To access to the recovery mode:
1. Hold down the volume button + and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button +.
The ANDROID green robot is displayed.
3. Once the ANDROID green robot is displayed, press simultaneously the volume button + and the ON/OFF button.
The Android system recovery screen is displayed.
a. Use the volume buttons to navigate
b. Use the ON/OFF button to select an option
To restore the default parameters of your tablet:
1. In the Android system recovery, select Wipe data/factory reset;
2. Select Yes -delete all user data.
3. Select Reboot system now.
Your tablet reboots. Redefine your parameters through the wizard.
Your tablet is restored to its default settings.
To access Recovery mode on the ARNOVA 9G3
1. Hold down the Home button and press the ON/OFF button.
2. Once the ARNOVA boot logo is displayed, release the Home button.
To access Recovery mode on the ARNOVA 8cG3/8bG3
1. Hold down the volume button - and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button -.
Sep 16, 2012 | Tablets & eReaders
IPad shows blank black screen & won't turn off ~ how do I fix?
Try reseting the iPad by holding the home and power buttons simultaneously until the iPad completely shuts down and the Apple logo appears.
Once the Apple logo appears you can release the buttons. If this does not work, you may need to connect your iPad to your computer and do a factory restore using iTunes.
Jul 16, 2012 | Apple iPad Tablets & eReaders
Android vimicro logo stuck on screen
ANDROID Tablet Freezes at Android startup screen
For Superpad VI - 10.1" Android Version 4.03, this worked for me!
1. Press & hold START button
2. When "VIMICRO" appears, Then Press & Hold the MENU button
3. The Android System Recovery <3e> Menu should appear
4. Scroll down using the Volume Key to "wipe data/factory reset"
5. Press HOME Button
6. Scroll down to "Yes - delete all user data"
7. Press the HOME Button
At this point the system will do a recovery and hard start, and will be on "reboot system now
8.Press the HOME Button
Your system should reboot normally, but you will need to enter all new data, as it has been wiped clean.
Apr 03, 2012 | Tablets & eReaders
HTC Touch Diamond2 Smartphone Logo
184 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
