Question about Cameras
My canon xs battery was charging for 3 hour with no light on. When I put it back in the camera nothing's improved. It's not turning on at all
Make sure the battery is securely in the charger.
If nothing changes you should try replacing the battery. It could be faulty. if that doesn't work, then the charger likely has an issue. Probably a loose wire or fizzled circuit
If you're feeling adventurous and know what youre doing you can take a look inside, but i wouldn't suggest it.
hopefully your warrenty covers the battery and charger. replacing them or returning the camera are essentially your only options at this point.
Posted on Nov 27, 2012
SOURCE: Camera is not turning on; no power
plug it into the computer. Thats what I did with my camera(even though its different).
Posted on Mar 31, 2008
futureloginn
  • 734 Answers
SOURCE: Canon powershot SD750 will not turn on.
Hi
There are several things that could cause this.
1- Check the battery door indicator switch under the battery door and beside the memory card slot. Is the little black switch damaged or missing? Try pressing down gently using a pen it with the door open and then press the power button. Does it turn on?
2- The fuse has blown and needs to be replaced. Offhand I don't recall where it is on the SD750 PCB or how hard it is to solder on a new one (depends on if its tricky to get at or not). Good thing is fuses are really cheap.
3- Other power problem with the PCB due to corrosion or impact damage. The PCB or 'motherboard' of the camera will need to be replaced.
Posted on Dec 04, 2008
jcdill
  • 121 Answers
SOURCE: Canon 40d won't turn on, LCD is blank.
There are several different things that can cause the camera to not start up. Refer to your user manual to check each of these items. If you don't have your user manual, you can download it here.
1) The battery is not properly installed in the camera. (p.26)
2) Make sure the battery compartment cover is closed. (p.26)
3) Make sure the CF card slot cover is closed. (p.28)
In addition, the battery may not have been properly recharged. Double check that the charger is plugged into a working outlet, and double check that it shows that the battery is fully charged.
If none of these fix the problem then you have a defective camera - one of the switches for the battery compartment or the CF card slot cover may be not properly indicating that the door is closed. If that's the case, you need to either return it to the place of purchase as defective, or send it in to Canon for warranty repair.
Posted on Dec 26, 2008
  • 1632 Answers
SOURCE: Won't turn on
Keep holding the power up button on untill it oppens up the lens I mean and light up the disoplay.
I hope you did not dropped it to a hard surface.
Vitally
Posted on Jun 02, 2009
mannforever
  • 23 Answers
SOURCE: Camera will not turn on. Battery fully charged;
You can give it to an expert for repair, he can repair it for less as there must be just a fuse problem, which can be fixed for a very less amount.
Posted on Aug 11, 2009
Canon rebel Xs/1000D fails to operate except for blue flashing light on WB button
Although I have seen this error before last week (or two weeks ago) it is not a known error in my list. Must be something serious wrong with your camera.
Perhaps Canon can tell more, but I think they will give you the advice to hand the camera in on a Canon Camera service centre.
The only thing I would do, before giving the camera out of my hands, is checking if every contact in and on the camera, included the connectors, if nothing is wrong, like dirty, bent or oxidised.
Success
Feb 19, 2014 | Canon Cameras
My rebel t3i wont turn on!
unless you put the battery in wrong There is a small diagram on the lid part or in side where the batteries go showing which way the batteries are put in.
May 06, 2013 | Canon PowerShot SD600 Digital Camera
I have a canon rebel xs, i took a few pics and then it stopped working. the battery had charged all day and says it is charged but it wont come on. I have had this battery for 2 years, could it be the...
The light at the bottom right is just telling you it's looking at the memory card. My canon batteries are about two years old and are due for replacement because they are not holding charge very well. Unfortunately all rechargeable batteries eventually lose their ability to hold charge
Jan 16, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
Canon Rebel XS has stopped recording images...
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS .
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Apr 11, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
My camera wont turn on. The battery is freshly charged, it is installed properly and the battery compartment door is shut correctly. At one point the flash would come up, but no display on the lcd and the...
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
I hope that helps.
Mar 25, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Screen wont work and when you shoot it says its "Busy"
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS.
I hope that helps.
Jan 21, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Canon Rebel XS displays busy signal after I take a
Is your card nearly full? Is your battery fully charged?
Dec 19, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Battery problem?
i have this excact same camera ... happened to me... it will work after a little bit, open battery door and let sit for 3 days, other wise turn screen off
Oct 21, 2009 | Canon PowerShot A430 Digital Camera
My Canon XS - Lens malfunction & won't turn on
Maybe lens needs adjustment. The info on this page may help. Copy and paste this link for more info.
http://www.fixya.com/PostAnswer.aspx?thid=1841738&prdid=447928&ctgid=67
Mar 22, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Cameras Logo
22 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
