Question about Samsung HLM5065W 50" Rear Projection HDTV-Ready Television
When The TV is running it makes a high pitched whinning that seems to be coming from the projector
I had the bulb replaced and the picture came back, but every since the bulb first was going bad the projector has been making a high pitched whinning/buzzing whenever the TV is Running.
  • Dominick Rosario
    Dominick Rosario Nov 27, 2012
    Sadly, now the lamp has failed to warm up repeatedly. The noise still consists but now there is NO picture.
    Top Expert:
  • Samsung Master
  • 14,553 Answers
Its a bad color wheel and you may be able to replace it. You Tube has videos for this.
Look where the lamp faces and see if wheel missing segments or shattered.
When The TV is running it makes a high pitched whi - 12_22_2012_3_56_07_am.jpg
Posted on Dec 22, 2012
premtech
  • 934 Answers
SOURCE: 3 blinking lights and no picture
The whine or squealing you hear is either the color wheel or fan. To determine which, when the noise is heard from the set, turn it off and listen carefully. If squealing stops immediately then Tthe fault is the color wheel, not the fan. And sounds like that are generally the color wheel. A new color wheel is Samsung p/n# BP96-00250A for this model. Vance Baldwin carries them for $97.20 plus shipping. https://www.vancebaldwin.com Logon as guest, select parts and copy past the above part number in without any dashes. Good luck... Bill
Posted on Jun 08, 2007
  • 4234 Answers
SOURCE: TV Just Started Making a Humming/Buzzing sound
Replacing a flyback is not something I would suggest for anyone with no electronics experience. Second, lets see where the noise is coming from first. Take off the back and listen to the noise. The flyback will be at one end of the large red wires that go to the tubes. Sometimes the connection at the tube is not 100% and the noise comes from there. BE CAREFUL - there are high voltages going through this red wire that can be dangerous even with the set UNPLUGGED!! IF the noise is coming from the connection at the tube, with the set unplugged, carefully turn the rubber cap back and forth touching only the rubber part with one hand. Put the other hand in you pocket while doing this.
If the noise comes from the flyback side, if you can solder, again with the set unplugged, try resoldering the pins on the transformers. That may resolve the problem.
Keep me posted.
Dan
Posted on Feb 13, 2009
  • 1030 Answers
SOURCE: picture wont come on, makes noise like it is on, but no go
when u plug the set in does it make a whinning noise or a poping noise. this might be a lamp or a color wheel stalled.
Posted on Jun 17, 2009
video-tek
  • 150 Answers
SOURCE: when i turn the tv on ,sometimes i hear a high pitched fan noise.
Hi, bearings in color wheel are about to fail, get it fixed now before the wheel shatters the prisms all over the inside of the tv which of course will then cost you more to fix, video-tek
Posted on Jul 01, 2009
  • 160 Answers
SOURCE: samsung hlr5078wx DLP tv. rumbling noise and shaky picture
This is a color wheel problem.
I would recommend to use professional help because you can make more damage to the optical engine. Not to mention index delay have to be re-adjusted in special service menu after repair is complete.
Regards.
Russ.
Posted on Aug 12, 2010
50 " DLP makes a high pitch squilling sound and shuts off several times
Check and replace its color wheel. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 10, 2014 | Samsung DLP HL-P5663W 56" TV
Might the projector bulb still need replacement even if it lights up for 30 seconds
Possible but not real likely---do you hear any high pitched sound when set operates?
Mar 11, 2012 | Televison & Video
When trying to turn on my tv, the green light blinks a few times then the red light blinks a couple of times then automaticaly the tv shuts off. There is no picture at all. It makes a couple of sounds like...
sounds like the projection bulb went bad. change the bulb and it should work. sometimes they make a high pitch noise when they are trying to turn on. the bulbs seem to last about 2 years for me.
Jun 04, 2010 | Zenith E44W46LCD 44" Rear Projection...
Projector turns on but does not illuminate bulb is good
may be either the colorwheel or the ballast. if you hear the colorwheel spin up (high-pitched whir), replace the ballast. if you don't hear it, replace the colorwheel.
Dec 11, 2009 | Sharp XR-10S DLP Projector
When i turn the projector on i hear a noise...
it's the colorwheel. the bearings are wearing out due to excessive dust and heat. it will need to be replaced. unfortunately, dell doesn't sell parts, so you'll have to send it in for repair.
Dec 03, 2009 | Dell 2300MP Multimedia Projector
10-year-old 32" RCA PIP TV just blinked off one morning after about 30 minutes. It makes a continuous high pitch sound, and the on/off switch is completely unresponsive. I assume this is a picture tube and...
It's not the picture tube(especially if image was good b4 it went dead). The high pitch noise is the power supply whinning because it's shorted or overloaded. I just fixed one of these sets - replaced the horiz. o/p transistor and flyback estimate around $120.00-$160.00
Oct 24, 2009 | RCA F32650 32" TV
I have infocus lp70 model projector. i replaced the bulb and now it won't light. i put back in the old bulb and the light still wont come on...any ideas? You can tell that the projector wants to run and is...
if you don't hear a high-pitched whir, your colorwheel needs replacing. you can remove the lamp and see the colorwheel inside (colored glass wheel). if you turn it on without the lamp, the colorwheel should still spin. if it does, you have a ballast problem. if not, the colorwheel. you'd still need to send it in to an infocus authorized service center. try av solutions in ny. they're pretty good.
Oct 22, 2009 | InFocus LP70+ Multimedia Projector
Our Samsung HL-P4663W DLP is makes noise and shuts off
It is the color wheel, inside the light engine. The bearings get dirty and makes it harder for the wheel to spin causing that whin.
Jan 06, 2009 | Samsung DLP HL-P5663W 56" TV
Rca hd52w59
ok does the set show a picture durring this whinning
i have ran into this problems .. sometimes it has to do with a coil that is oscillating...ll037 or ll029...the fix for this is simple if it is the problem. dampen the coil with silicon.
Mar 26, 2008 | RCA HD52W59 HDTV Projection Television
Samsung HLM5065W 50" Rear Projection HDTV-Ready Television Logo
44 people viewed this question
Jerry Greenberg
Jerry Greenberg
