Question about Kyocera FS1128MFP AllInOne Laser Printer
Kyocera fs-1128mfp replace process unit error
4 Suggested Answers
  • 241 Answers
SOURCE: I have a kyocera FS-2000D with error code: Call fo...
Error code 0150 is an engine EEPROM communication error. The engine board might need to be replaced. I have heard that sometimes a defective developer unit could cause this same error code. I would try swaping a develper from a working FS-2000D first.
Posted on Jun 09, 2010
destom
  • 126 Answers
SOURCE: kyocera fs-2020d doesnt do multiple copies of documents
This message often shows up when the memory is full from one document (normally a large file) to fix it you have to add external memory
Posted on Nov 09, 2010
SOURCE: WHERE IS WASTE TONER IN
Inside the drum unit.
To get the drum unit out, you need to first remove the developer unit (which the toner is installed inside) then look inside the printer and put your fingers inside and pull the two green loops out.
Onc you've got it out, look for the side which has a silver sticker on. IF you use a flat headed screwdriver where one of the arrows points to a grey sponge, you will be able to lever off the cap and then empty the waste toner.
This is a mucky job.
Kerridge0
Posted on Dec 06, 2010
Instructions required to replace the maintence kit
Please advise machine make/model.
You may also need to know how to reset counter
after fitting.
Jul 24, 2015 | Kyocera Ecosys Fs-1128mfp 30ppm All-in-one...
Error type: connect
smb scanning? check to make sure host ip is conrrect as well as long in info and path to folder /email make sure smtp server address is correct along with login info and try port 587 if its set on 25 comcast tends to block 25 for smtp scanning
Jul 09, 2014 | Kyocera FS-1128MFP FS-1128MFP...
Kyocera FS-1128MFP C4000
lsu (laser scanner unit) failure or main board
Jun 30, 2014 | Kyocera FS-1128MFP FS-1128MFP...
Drum make a noice
unfortunately I don't think there is a way to fix the noise from the drum other then replacement if the machine is under warrenty rma the drum
May 28, 2014 | Kyocera Ecosys Fs-1128mfp 30ppm All-in-one...
Waiste toner box full.....how do I clean or change this? Looked through owners manual and can't find anything about it.
The waste toner sensor has detected
that the waste toner reservoir (drum unit)
is full.
FS 1128 has drum and developer as separate unit, waste toner gets collected in the drum unit . Right or left side of the drum unit has a cap fasted with screw, open it and remove the waste toner.Refix the drum and this will solve the probelm
Oct 08, 2013 | Kyocera Ecosys Fs-1128mfp 30ppm All-in-one...
How do I print double sided with this copier
pick print on both sides (flip long edge or flip short edge) in the print driver. go to kyocera support to download latest kx driver if the options are not found in your current driver
Apr 04, 2013 | Kyocera Ecosys Fs-1128mfp 30ppm All-in-one...
FS1128 whats the setup for dev on this?... is it like the CS2550 ? U130
1-5-5 Developing section
(1) Detaching and refitting the developing unit
Procedure
1. Open the front cover.
2. Remove the developing unit.
3. Check or replace the developing unit and
refit all the removed parts.
NOTE:
When the periodic maintenance (replacing
the maintenance kit, see page 2-4-4), perform following maintenance modes.
1. U251 Clearing the maintenance count (see
page 1-3-39)
2. U111 Clearing the drum drive time (see
page 1-3-33)
3. U130 Initial setting for the developing unit
(see page 1-3-34)
Jan 28, 2013 | Kyocera Ecosys Fs-1128mfp 30ppm All-in-one...
Machine showing machine failure call service
The waste box is integrated into the drum unit housing. DIRTY JOB without a toner vac. There are two ports (one one each side). The covers pry off. The service manual doesn't cover this because they want you to replace the drum.
Jan 05, 2013 | Kyocera Ecosys Fs-1128mfp 30ppm All-in-one...
Kyocera FS1128MFP AllInOne Laser Printer Logo
1,059 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
