Question about Kenmore Microwave Ovens
401.85053010 broken door latch - Kenmore Microwave Ovens
Replace broken door latch
Click on this link to get to a web page from which you can E-mail Panasonic your question.
http://eng-na.faq.panasonic.com/
Nov 08, 2014 | Panasonic NNSN657S Microwave Oven
Viking Microwave door latch
Try pushing in on the door while pressing the door release latch;
Also, try pushing the door latch and reach under the front edge of the door and slightly pull as the latch is depressed.
Third option is use a suction cup, maybe from a GPS device on the glass portion of the door, pulling on it while you depress the door latch....let me know any problems or if I can help anymore.
Jul 27, 2014 | Viking VMOC205 Convection/Microwave Oven
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
Door Spring
Door Latch
Door Hook
Button Spring
Button
Handle Actuator
Apr 02, 2013 | Microwave Ovens
Door doesn't latch
Can you move the latch in the door? This is spring loaded, maybe the spring is broken
Mar 09, 2013 | Maytag MMV1153A Microwave Oven
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Neff H7871 oven door does not stay closed. Catches do not appear to be working
The door latch is either cracked or broken.The door when gets closed the door latches clicks.But if the door latch is loose or cracked it will not click and door will not close.The door needs to be disassembled and the door latch has to be replaced, if the latch is cracked.Also to check the latch from inside the door needs to be removed.-------- This will help.thanks.Helpmech.
Jun 29, 2011 | Neff Microwave Ovens
My Kitchenaid khms155lss-2 has a problem latching completely. Once finally latched the microwave would start and then stop during the cooking time because the door became unlatched. I have to stand by the...
Ok.Agreed,latch is not cracked or worn out.But check the grip of latch.Open the door.The hold the latch in your hand and see,if its loose or tight.It should be tight.Press the latch towards down and move it left/right slowly --- slowly.And inspect the latch.It will move,there will be a moment but the position of the latch in the door frame should be tight.If you feel that latch is got very loose,then the door frame needs to be disassembled and latch assembly has to be repositioned and fitted.In most of the cases this latch breaks/cracks and it needs replacement.But in your case,its different,you mentioned that if you keep your oven door pressed then latch remains closed..So if latch is broken/cracked it will not get closed properly.So as per that i think,you will have to check the opposite side of the door frame,where this latch gets into.On that side,there is a interlock type part.Which holds this latch.That part is operated by spring.If in-case that interlock type part or the spring,any of this is got loose then latch will get released after few minutes.--------------- But first as regular troubleshooting,you inspect the latch.Do you feel its loose or getting very easily moved,then open the door frame and check the latch.----------- For that you will required door disassembly diagram:--- Click the link,see part number 3 is door latch.-------- http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/W0505176-00002.png -------------- If the latch is properly positioned and intact then ,you will need to disassemble the opposite side cabinet to check the internal part,which hold the latch.For that you will require complete disassembly:---Click this link for complete disassembly:-- http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Microwave-Parts/Model-KHMS155LSS2/0593/0123370?pathTaken=&prst=0&shdMod=KHMS155LSS2 -------------- The door latch itself or other parts holding the door latch,none of the part is costly then $10.The cost of part is under $10.---------It just require you to figure out,either is cracked /broken part or just loose misaligned part.-------- This will help.Thanks.Helpmech.
Feb 10, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Samsung microwave door popped open and now won't close. What happened?
The spring attachment to the moving latch has broken off either replace the latch or drill a small hole in the latch body and attach some heavy steel wire to make a new attach point for the spring. the inside trim easily pops off and the latch just slides off.
Jan 26, 2011 | Samsung Microwave Ovens
Door Doesn't latch shut
Usually it's not thespring but instead the "latch head", which has a little loop on the backside to hold the spring. The loop breaks off.
The latch head is the long plastic piece with two protruding hooks which activate the hidden door switches.
The door will need to be taken apart (but not removed from the oven!) to get to the latch head. See the attached example photo.
If you or a friend decide to look into it, we have critical safety and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
We appreciate your thoughtful rating of our answer.
Nov 17, 2007 | Sharp R-1480 Microwave Oven
Microwave Ovens Logo
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
