Speakers- model RTi12
One day, a tweeter on my right floor standing speaker went out. So I tested its integrity by switching my right side tweeters to my left side floor standing tweeters. Then as it was switched and turn on, i smelled burning and now both tweeters stop working. Ordered a new sets of tweeters from Polks audio for exact same model and replaced them both. It still does not work. Any solutions?
Benimur
  • 6966 Answers
SOURCE: karaoke speaker,no woofer or midrange working, only tweeter
Hi, it's probably that the 8" woofer and the midrange of the "amped" enclosure is open. One way to test is to remove just one wire from the inside of the enclosure to the woofer or midrange in question and with the use of a continuity tester (or a VOM), check for the resistance of the coil of each the 2 speakers. Both should read anywhere from 4-8 ohms, if there's no reading (VOM needle will not move) then the coil(s) are open. In the absence of a tester, a single AAA or AA battery would do (pls. some would argue that this is not a sound practice, however this should be enough for you to be able to determine the condition of the coil(s)). With the use of the battery and a single short length of electrical wire, apply power from the battery to the terminals of the speaker, if the cone moves, then chances are it is good, if they don't then you would have to replace it. Am not sure if available in your area, but there are some trained people who can rewind the coil should a replacement speaker be not readily available. Hope this be of help. Please let us know how things turn up. Regards.
Posted on Apr 15, 2007
  • 238 Answers
SOURCE: KLH tweeters stopped working
hi, have u first disconnected the tweeters and then checked, as if its on a cross over, the tweeter is in series with a capacitor,if u have a ohms meter or a continuety tester check the tweeter coil if its open,secondly you can have the coil replaced, check if u can get one before buying a new,let me know
Posted on Jan 12, 2008
SOURCE: Wharfedale Modus One
The tweeters are probably blown, i had the same problem.
You can test this by placing the cable on the dismanteled crossover at the back of the speaker. colour blue/yellow.
No high volume please.
See http://www.hometheatershack.com/forums/diy-speakers/4549-wharfedale-modus-one-six-crossover-pics.html
for pictures.
If the tweeter is blown it can be dismanteld with the aid of a screwdriver, horizontally.
Place it between the tweeterbowl and the ring which has the mark wharfedale on it. The tweeter comes loose. On second hand sites you can buy little speakers, like modus one or two's with the same tweeters for a good price and put them on your larger speakers.
This how i repaired 2 of my 4 modus eights.
good luck Danny Mol
the netherlands
Posted on Mar 11, 2008
robotek
  • 1512 Answers
SOURCE: woofer not working on new bx8a speaker
Hi ermo
Your new speakers are BiAmped, and if a woofer is not working then it is probably a fault in the amp or connection for that woofer, or the the woofer itself has a problem. If they are brand new, I suggest you take it back to purchase point to get sorted out. There is nothing that you can do that will NOT void your warranty. If you do not have a warranty, then get back to me here and we can work through the problem. Cheers
regards
Graeme
Posted on May 25, 2008
SOURCE: blown kef q55.2 tweeter, is replacement possible?
The tweater on my Q55.2 blew as well. I went into a shop in NYC and they tried to charge me $225 for a new tweater, so I took it home and called up Kef. They sent me out a new tweater for $35 and instructions on how to solder it in.
It took all of 10 mins to replace and they are working fine. I've never soldered anything before and it was simple.
Cheers
Martin
Posted on Sep 12, 2009
2014 dodge advenger radio wiring harness diagram
2014 Dodge Avenger Car Audio Wiring Diagram
Car Radio Battery Constant 12V+ Wire: Red/Brown
Car Radio Accessory Switched 12V+ Wire: N/A
Car Radio Ground Wire: Black
C
Car Radio Antenna Trigger Wire: Gray/Orange
Car Audio Front Tweeter Size: 2-1/2? Tweeters
Car Audio Front Tweeter Depth: 5?
Car Audio Front Speakers Size: 6? x 9? Speakers
Car Audio Front Speakers Depth: 4?
Left Rear Speaker Positive Wire (+): Dark Green/Tan
Left Rear Speaker Negative Wire (-): Dark Green/Gray
Right Rear Speaker Positive Wire (+): Dark Green/Brown
Right Rear Speaker Negative Wire (-): Yellow/Gray
Car Audio Rear Speakers Size: 6? x 9? Speakers
Car Audio Rear Speakers Depth: 4?
May 18, 2016 | Dodge Cars & Trucks
Only right side tweeter working
check you haven't got the wires on the back of the tweeter touching, Then check the rest of the wiring you may have touched. Jon
Dec 18, 2014 | Cars & Trucks
Tweeter no sound but speaker no problem
In the most general, basic sense, I would be assuming that this is just one speaker and not 2 with this problem, or 3 or more.
Only way to get the ball rolling is pull the tweeter from the cabinet, checking to make sure all wires are connected at the tweeter and inside the speaker.
If that is the case, then you would need to determine if this is the tweeters fault, or its crossover (thing that divides the sound into whats right for the woofer and what the tweeter wants).
If you have a multi-meter, you would disconnect the wires from the tweeter, set the meter to ohms and touch a probe to each speaker terminal. No action means burned out tweeter, 100% action means burned out tweeter, a reading slightly less than the rating on the back of the tweeter (for instance an 8 ohm tweeter would show anywhere from 6 to 8 ohms on the meter) means tweeter is good.
If you have no meter then take the tweeter from the good speaker and swap in place of the bad one, making sure you respect + and - connections.Its a little risky this way,since if there is something wrong in the speaker it may hurt the good tweeter..(the meter is the safer bet). If it works, then you need a replacement tweeter, if not the problem is either wire connections inside the speaker, or something is wrong with the crossover.
Nov 03, 2014 | Audio Players & Recorders
I lost the treble on both Alesis Monitor 1 speakers. The treble is good on the amp output toward the speakers. I'm thinking they went out one at a time and I didn't realize it until I lost the...
It's probably blown tweeters. But if you want to spend the money on a hipshot guess, try to find the the crossovers somewhere first; then find the readily available tweeters if/when that doesn't work out. Google "alesis monitor one MK2 tweeter".
You could test the tweeters by just removing one non-functional tweeter and wiring it directly to the speaker leads and with REALLY LOW volume containing NO BASS see if it makes any sound, which would prove it does/does not work.
Going forward, if the speakers sound stressed at high volume - THEY ARE. Too much power or too much distortion (overdriven amplifier) will kill speakers.
Sep 16, 2011 | Alesis Monitor One Mk2 Speaker
Hi....I need a wiring diagram for the stock amp in my grand am gt...its a 2003
Monsoon System Pinouts
Pin Wire Color Function
E1 LT GRN Right Front Speaker Output (+)
E2 TAN Left Front Speaker Output (+)
E3 GRY Left Front Speaker Output (-)
E4 LT BLU Right Rear Speaker Output (-)
E5 DK BLU Right Rear Speaker Output (+)
E6 BRN Left Rear Speaker Output (+)
E7 YEL Left Rear Speaker Output (-)
E8 BLK Ground
E9 BLK Ground
E10 DK GRN Antenna Relay Coil Supply Voltage
E11 ORN Battery Positive Voltage
E13 BLK Left Front Tweeter Speaker Output (+)
E14 YEL Left Front Tweeter Speaker Output (-)
E15 DK BLU Left Front Midrange Speaker Output (+)
E16 LT BLU Left Front Midrange Speaker Output (-)
F1 DK GRN Right Front Speaker Output (-)
F2 LT GRN Right Front Speaker Tweeter Output (+)
F3 PPL Right Front Speaker Tweeter Output (-)
F4 PPL Left Rear Tweeter Speaker Output (-)
F5 RED Left Rear Tweeter Speaker Output (+)
F6 DK GRN Right Front Midrange Speaker Output (-)
F7 ORN Right Front Midrange Speaker Output (+)
F8 PPL Gain Control Signal
F9 -- Not Used
F10 YEL Right Rear Tweeter Speaker Output (-)
F11 WHT Right Rear Tweeter Speaker Output (+)
F12 -- Not Used
F13 LT BLU/BLK Right Subwoofer Speaker Output (-)
F14 DK GRN Right Subwoofer Speaker Output (+)
F15 DK BLU/WHT Left Subwoofer Speaker Outlet (+)
F16 LT GRN/BLK Left Subwoofer Speaker Outlet (-)
or it is here 3rd one down
http://www.grandamgt.com/forum/forumdisplay.php?f=76
May 08, 2011 | Audio Players & Recorders
Tweeter not working. Replaced it, but still doesn't work.
When you replaced the tweeter you should also check if there is any damage to the crross over network. It is possible that the capacitor , inductive circuit could have opened up. Remove and check. Check seperately with a good multimeter or use a 1.5 volt AA cell for testing the speakers. You can connect the speaker cabinet line to the battery and ccheck for voltage at the tweeter branch. Othere check the nettwrok and resolder or reconnect or replace. Hope this helps. Good day
Jul 20, 2010 | JBL SP5 Main / Stereo Speaker
Paradigm Monitor 9 v4 tweeter not working.
speaker is must likely blown. check to see if another tweeter works at that connection.
Feb 14, 2010 | Paradigm Monitor 9 Speaker
I have a kenwwod AX-7 home theatre systems. the right side top speaker (tweeter) on one side does not work. i'm thinking there is a fualt with the amplifier on the right side.
If the only problem is the tweeter, and the woofer is still working, you do not have a problem in the amplifier. The problem is the speaker. The tweeter is blown or you have a problem in the cross over network in the speaker.
You can always switch the speakers and connect them to the opposite channel. You can do this very easy at the back of the receiver where the speaker wires are at. Put the left speaker wires on the right speaker and the right speaker wires on the left speaker. If the same speaker still has no tweeter you know that the speaker is the problem.
The only way this could be a problem in the amplifier is if you have two different sets of inputs for each speaker, one being the low end for the woofer and the other being the high end for the mid range and tweeter. That would mean you have two sets of speaker wires going to each speaker. Each set of speaker wires would have a positive wire and a negative wire for a total of 4 wires going to each speaker. I don't remember this system being set up that way, but I could be wrong.
I hope this was helpful, you should be able to get the speaker fixed at an authorized Kenwood repair center in your area for a reasonable price. As a guide, my shop only charges $25 for the labor plus the cost of the tweeter to replace a tweeter. Any other shop should be similar. Kenwood does sell replacement drivers for almost all of their speakers.
Jun 21, 2008 | Kenwood Audio Players & Recorders
for pictures.
good luck Danny Mol
the netherlands
Jan 15, 2008 | Wharfedale Modus One-Six Speaker
53 people viewed this question
 Grubhead
Grubhead
