Question about Invacare Supply Group Invacare Pronto M91 Electric Wheelchair
M91 power chair replacement seat
Replacement Chair Seat and arms for my M-91 400 lb capasity
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 99 Answers
READY MEDICAL & MOBILITY in Carencro, Louisiana 70520 - 337-565-6784.
Posted on Dec 18, 2012
5 Suggested Answers
  • 56 Answers
SOURCE: Change Batteries in Pronto M91 with swivel seat.
Turned out to be a "doh!" moment. Use the lever on the side of the seat to permit swivel. Unplug Controls connector. Lift seat off unit. Remove battery compartment cover by loosening 2 Philips-head screws on the Charger cover at the rear. Disconnect cable to Electronic Controller at front of front battery. Disconnect the Red and Black battery connectors, the ones that join the 2 batteries. Lift out batteries. Transfer battery connections to new batteries. Reverse the above process to reassemble.
Solved this without any help from outsiders, including FixYa, who wanted to charge me for the solution.
Posted on Jun 13, 2009
my-mobility
  • 9 Answers
SOURCE: Can't charge Pronto M91.
Hi Bob. Unfortunately in most cases this means that the batteries have gone so flat that they cannot be “revived”. The best thing to do is take the batteries to a local battery dealer and have them checked. You may need to replace them. Another possibility is that because the batteries are so flat, the charging circuit hit a wobbly trying to resuscitate them and popped a fuse button. A simple reset may help. Happy scooting. Regards Chris… info@mymobility.co.nz
Posted on Jun 22, 2009
wcdoc1953
  • 280 Answers
SOURCE: have a Pronto m91 power chair. Suddenly stopped
Sounds like you are on the right track with your problem solving. Unfortunately you cannot determine an electronic fault by visual inspection of the components. You can see cuts, nicks, broken wires and burnt components, but this only works sometimes.
I look at the current fault code with a hand held programmer (HHP). With a HHP you can read the fault log and check out all the stored codes to get an overall idea of the history of chair problems. The 7 flash code is definitely a remote fault. You can also get this fault with a bad connecting cable between the joystick (remote) and the controller (in the base). Check this connecting cable for breaks, cuts, loose pins or connections and check the connections at both ends. You can do continuity and component checks of the remote with a digital voltmeter, but this is out of the realm of most end users.
I am assuming you have MK5 or MK6 electronics in this discussion.
The easiest test is to swap out the joystick with a known good one that either a tech has brought to your home or you have brought the joystick in to a service center for testing. The better test is with a HHP that will give you the current problem and stored information of past problems.
Weak batteries or loose battery connections can also give a myriad of electronic faults. For this reason I always check the batteries and battery connections first.
The joystick can be rebuilt, but I recommend replacement as a more cost effective solution. I always replace the joystick to controller cable too. Labor charge for this work is under 1 hour.
I can provide further information if needed. Hope this helps.
Posted on Dec 03, 2010
  • 68 Answers
SOURCE: one red light three green flash when turned on
Your chair has a motor problem. The code does not tell which side it is. Make sure both motors have the brakes in the drive position before turning on the chair. Also check that both motors are plugged into the main control module in the base of the chair.
Posted on May 01, 2011
Can I buy parts for a DK-400FS arm chair
Only from the maker of the chair, and in many cases they only sell paper like the motor for powered chairs like lift out ones.. Call a local retailer of the chair and they can give you the info to contact the manufacturer.
Nov 11, 2016 | Seat Cars & Trucks
Can I get a replacement cushion?
look at wayfair .com for replacement items for your chair
Mar 14, 2014 | Madison Park Briarcliff Accent Chair -...
"serta executive chair # 21779363 replacement arm
Have a Serta Office Chair Big and tall ex chair, one of the arms broke where can I get a replacement
Sep 11, 2013 | Serta Executive High-Back Chair
M91 power chair replacement seat 400 lb capasity
call your insurance provider most pay for repair
Nov 27, 2012 | Health & Beauty
I can't remove the seat from an Invacare Pronto M91 VA chair with elevating seat.
single post, lift handle to rotate then pull up very hard!!! four poster lock is between knees release tilt back and remove
Oct 28, 2012 | Health & Beauty
CAN'T LIFT OFF SEAT OF JET3 POWER CHAIR? batteries
Richard The seat is probably rusted on the seat post It will take alot of turning and pulling upward at the same time to get it off. Try spraying a penetrant on the post just below the seat to see if that will help with the turning and pulling just keep at it. It can be a tedious task and frustrating Hope this helps
Mar 16, 2011 | Jet 3 Ultra Power Chair
The Pronto will not keep a charge so I replaced the batteries. Now the red and green light flash while charging and there is no power to the chair
Mckinzie the lights will flash when charging because of the inhibit mode. After you unplug the charger and turn the chair on do you get any lights at all on the battery indicators? If not lift up the seat and check your battery cable connections the neg cable from the rear battery should be connectd to the positve side of the front battery and the rear neg should plug into the small connector of the other cable. Make sure then that the large double plug is connected to the double plug going to the controller. while the seat is up then turn the chair on to see if all the lights come on. If not check that all your connections at the battery posts are tight. Also check under the two red positve battery post covers the two fuse links to make sure they are not blown. If all of this checks out the chair should come on and operate correctly Hope this helps
Aug 28, 2010 | Invacare Supply Group Invacare Pronto M91...
My speed indicator lights are constintly flashing- the chair works fine though
You don't say what sort of chair you have, but if it has tilt or power seating system, the speed lights flashing could be a power-limiting warning, which means you have the seat tilted or raised too high for full power so it is limited to going slow. Lower seat and then try to drive it an normal speed. If the seat isn't tilted or raised and lights are flashing, then the switch on the chair that senses the height or the tile is probably faulty and would require replacement. Do NOT disable or bypass the switch as it is a safety device to prevent unsafe operation.
May 23, 2010 | Jet 3 Ultra Power Chair
Removal of tray on Safety 1st high chair
go and chek the mainual of the chair
Mar 12, 2009 | Baby Gear
Invacare Supply Group Invacare Pronto M91 Electric Wheelchair Logo
96 people viewed this question
Top Invacare Supply Group Health & Beauty Experts
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Are you an Invacare Supply Group Health and Beauty Expert? Answer questions, earn points and help others
