Question about Coleman Heating & Cooling
EVCON HEATER DGAA077BDTB
HEATER WONT COME ON THE GREEN LIGHT BLINKS 3TIME 3 TIMES 3TIMES WHAT IS WRONG
Therinnaiguy
  • 1420 Answers
SOURCE: GMP075-3 heater no igniter voltage
Check the venting for a restriction, check the condensate hose for blockage, check the pressure switch and hoses going to it. And make sure the small exhaust fan spins freely.
Posted on Nov 21, 2008
machtcl1
  • 61 Answers
SOURCE: heater wont start Goodman GMP075-3
Check the fuse on the board. It is a 3a automotive fuse. There may be a problem in the control wiring. If the fuse is blown, make sure to find the reason why it blew and repair it. Otherwise you will need a whole bunch of fuses.
Posted on Dec 31, 2008
SOURCE: Green light stays on, red light blinks along with a buzzing noise
colman uses the furnace to power the attic vent fan . Cheaper that way I guess. It just supplies your attic fan with power so it will vent thus keeping your home a little cooler in the summer.
not a big deal. you can shut the alarm with a switch ot cut power to the alarm.
Posted on May 10, 2009
  • 221 Answers
SOURCE: circuit board light blinks 3 times heater will not turn on
The error code refers to a defective combustion air switch. Coleman Evcons made around 2007 had defective pressure switches or as they call them "combustion air switch". Replace it and the problem is gone.
Posted on Dec 30, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: the led light blinks 3 times then pauses then
Pressure switch error code, Check the air filter for blockage, check the vent pipes for blockage or water, make sure the condensate drains are working and that there is no water in the hose(s) that go to the pressure switch(s).
Posted on Jan 06, 2010
I have a 2011 Toshiba 55 55SL417Uand the picture wont come on the green flashes 3 times pauses 3 flashes pause over and over
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jun 21, 2015 | Toshiba 55 55SL417U LCD TV
HEATER
ax fan may be going out
Nov 27, 2012 | AO Smith Evcon Draft Inducer Furnace...
Sony KDF-46E2000 green lights up then red light blinks 3 times no ricture blinks 3times again and again
be aware it means (3 blinks) lamp door is not closed properly------it is not the lamp door.
What happens here is the door becomes slightly warped from the heat from the lamp. When you remove the door you will if you look carefully see a small opening that lines up with a peg on the back of the door.
Inside the opening is a lever (very small) that is the safety switch-------if the door IS YOUR PROBLEM AND you engage the level with something not metal, the set will come on and function.
If this is the case hold the lamp door edgewise to examine it for bowing.
The door is available on the internet.
Contact me if you have questions.
SD TECH
Sep 17, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
Have a Evcon Coleman Furnace shows three green blinking lights but will not ignight what could be wrong
I have had the same problem with mine for the last 2 years. Remove the motor on the side of the furnace(usually held on by 3 screws) and turn the fan blades inside by hand. after sitting all summer it seems to get stuck. If it moves freely, replace the motor and try to start it again. This fixed mine the last 2 years! Hope this helped.
Sep 29, 2010 | Coleman Propane Forced Air Heater...
More problems
If it won't turn on (the green light blinks and it beeps 3 times) push and hold the 'power' button and the 'play' button at the same time for a few seconds - it worked for my S730. Good luck!
Aug 01, 2009 | Samsung S860 Digital Camera
Apr 19, 2009 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
51 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
