Question about Crown Jeep Cherokee 96 95 94 93 92 91 90 89 88 87 86 85 84 Comanche Car Auto Parts
87 jeep cherokee turnsignals not working, where can i find a diagram?
Replaced switches in steering colum, as well as relays,
    Problem Solver:
  • 17 Answers
Did you check for a blowin fuse? Or do you need a diagram to figure out allso where the fuse block is in your vehicle all so. What do you people do with the owner manuals for your vehicle,? Feed them to your dogs.
Posted on Nov 27, 2012
How put back together the steering wheel colume
get the FSM, factory service manual
or
alldata.com
login
read how to remove ignition switch, bingo.
Feb 24, 2015 | 1990 Jeep Cherokee Limited
1987 ford ranger turn signals keep blowing fuses. have changed flasher fuse and switch on column. just keeps blowing?
first thing i guess to understand what is going on here ,is a little back to basics on how turnsignals work , first item you have is power fuse then it's off to flasher module than it goes to the turnsignal switch on colum ,of course anywhere on it way to there the power could got to ground and cause the fuse to trip, now the power depending on Left or right selection , is directed to lights on both front and back of truck,thankfully rangers don't have em on the side) now any place in this pathway the wire could go to ground and blow the fuse, now to troubleshoot and narrow down the area that fault is located , (1) replace fuse with correct size and ck for proper fit in fusebox and start and operate truck for a few minutes DO not use turnsignals, ck fuse is it still good if so go to step 2 if not stop and ck wire conditions in steering colum and switch(2) start truck and try right hand turn signal only verify lights working ,Ok yes/no if not replace fuse and try left side same way, Ok yes /no if right or left side only blows fuses take ALL bulbS OUT of lights and try again , if fuse still blows then look for wire fault on that side of truck if fuse is still good then look carefull at light bulb sockets for rust and powered corrosion (ill bet an 87 has some ) you may need to replace bulb sockets , they do sell em in autoparts stores .
Jun 30, 2014 | 1987 Ford Ranger
Left turn signal stops working
Had simular problem with wife 2000 Jeep Cherookee.
My signal light were not working at all.Check flasher relay under steering colum
Nov 28, 2012 | 2000 Jeep Grand Cherokee
2005 jeep grand cherokee brake lights stopped working. left, right, and top. Any ideas? I looked in the manual and I can't find the fuse for it.
hi
theres 2 fuse boxes on the grand cherokee, 1 below steering colum ant the kick panel and 1 in the engine compartment beside the battery. check all fuses and if they are ok check the brake light switch above the brake pedel.
hope this helps
Feb 18, 2010 | 2005 Jeep Grand Cherokee
Headlights do not work.Have 2002 Jeep Wrangler,replaced multi switch on colum,checked fuses and headlight bulbs,still do not work.
if you checked the fuses for the headlights,pull back on turnsignal handle to see if you have high beam over ride,
if you do i would think it was the headlight switch
Nov 24, 2009 | 2002 Jeep Grand Cherokee
Where is the turnsignal flasher & hazard flasher on this jeep
I believe both are located on the fuse block, driver side of steering column.
Apr 22, 2009 | 1997 Jeep Grand Cherokee
1997 jeep grand cherokee laredo - no turn signals.
Check your fuses the turn signal fuse could be blown.
Mar 10, 2009 | 1997 Jeep Grand Cherokee
2000 Jeep Cherokee Windshield Washer
You have a motor for the front and rear washer. Check the fuses. If the intermitted wipers does not work, there is a relay under the dash near the steering colum that needs to be replaced.
Jan 01, 2009 | 2000 Jeep Grand Cherokee
Crown Jeep Cherokee 96 95 94 93 92 91 90 89 88 87 86 85 84 Comanche Car Auto Parts Logo
96 people viewed this question
Top Crown Car Audio & Video Experts
Dennis Key
Dennis Key
Lawrence Oravetz
John
John
Are you a Crown Car Audio and Video Expert? Answer questions, earn points and help others
