Question about Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super Capacity Plus Gas Dryer - White-on-White
My whirlpool duet gas dryer (model ggw9200lw1) is taking too long
We cleaned out all vents and pipes, there were no clogs. The cycle shuts off before the clothes are dry. The dryer does not seem to get hot enough
  • Thomas Malailua
    Thomas Malailua May 11, 2010
    have you tried drying a load with out the venting[it wont hurt a think]and it will definnetly tell you if its venting or the dryer.many a customer i went to cleaned their own venting/or a pro.but it was still not clean enough.thats why i say dry a load with out venting
    Genius:
  • 1,198 Answers
There is a rare chance that the gas supply is clogged. Dealing with gas pipes is dangerous business, don't fool with it unless you are experienced with plumbing. After checking a gas pipe, do a bubble check for leaks with dish soap from a sponge or sprayer. There are small filters and traps placed here and there in the plumbing of some units. They are similar to the ones on a washing machine hose, but smaller.
Posted on Jan 10, 2009
Why wont whirlpool duet dryer model WED8300SW1 heat?
Is the dryer gas or electric? But you can also try cleaning the vent tube the pipe that goes outside also the pipe that goes into the dryer it's a good chance it's full of lint.
May 07, 2014 | Whirlpool Dryers
Dryer does not dry clothes completely
If your machine is taking that long to dry. You either have a clogged vent to the outside or your gas valve coils are bad. You can check to see if it is your vent by disconnecting it for one cycle. If the unit drys in time then clean your vent. Click Here to see what a clogged vent can do. Click here to see gas valve coils.
Apr 01, 2013 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a whirlpool Duet gas dryer, model ggw9200lw0. It will glow then heat up but switches off right away.
It sounds to me like your flame is not getting enough air. Make sure that ur screen is clean then clean your dryer vent. The easiest way to see if it is your dryer vent is to take the vent off the back of the dryer. If it runs good without it then you need to clean it. If the dryer heats up a couple times then wont heat up after that then you need to replace the coils
Aug 26, 2012 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
I have the duet whirlpool gas dryer - model #GGW9200LW1 and the barrel is making a lot of noise. It seems like one of the inside little cap is loose and the clothes aren't drying. Its taking too many...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Dec 29, 2010 | Dryers
Duet gas dryer flame does not stay lite
The flame should cycle on and off in response to the thermostat2.gif. If it is going out and not coming back on several minutes later then the exhaust vent may be clogged. Check the lint filter and exhaust vent all the way to the vent outlet to make sure they are not clogged.
Dec 08, 2009 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Duet gas dryer shuts off after 15 min
I cleaned out the vent that was clogged pretty good, put dryer back together (a solution I read in this blog), and now it is working fine. I was testing with bottom open.
Mar 21, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Duet front loader dryer
Check the lint trap and the vent. If the vent is clogged or crushed in anyway then replace it with a new dryer vent.
There reasons why a dryer will not dry clothes:
Clogged Lint Trap
Crushed or clogged vent
Last but not your issue, not getting and heat to the unit due to glow ignitor bad or no gas supply or bad gas valve.
So check what I told you and this should fix the problem right away
Feb 09, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Gas Dryer - takes to long to dry
Friend,
huuum At your service!
Sometimes this can happen when the vent line is clogged.
1. Check if the lint filter is full and needs to be cleaned.
Try this first.If the vent line is kinked or blocked
2. Then check if the outside screen covering the exhaust vent if this is even half blocked
with lint there will be no heat! This screen is to keep small animals out!
Try checking this and if it is clogged or the spring loaded door is stuck closed.
Try to clean the lint out of the corners of the flap door,
and or remove the screen permanently!
NO ANIMALS LIKE TO GET BURNT,IT'S HOT IN THAT TUBE!
Take the vent line off the rear of the dryer and try if it works. If it does you know it's the vent line and not the dryer that's the problem the dryer.
You will be fine
Bless You huuum
Feb 01, 2009 | Whirlpool LGR3624JQ Gas Dryer
My whirlpool duet dryer is taking 3 cycles to dry????
have you checked your lint trap to make sure that it is clean after every load? Also the lint vent to the outside may be clogged and will not let the dryer vent like it should. This is dangerous. So check and replace if needed.
Dec 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super Capacity Plus Gas Dryer - White-on-White Logo
968 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
