Question about Texas Instruments TI-85 Calculator
Characters & menus display incorrectly
Entires and results in the main screen show up with missing pixels, while the menu bar(s) at the bottom of the screen have additional pixels. i just noticed that the missing pixels blink when the cursor is in the far right column.
i originally thought this was a low battery issue, but new batteries didn't solve the problem.
thanks for any help!
My TI-85 after twelve years (!) will not light up its screen, even after replacing the proper lithium back-up battery and the proper fresh AA batteries. Could it be my metal contacts inside the battery chamber are a little rusty? Would that make that much of a difference as far as not functioning electrically?
    President:
  • 1,952 Answers
When changing screens/quitting menus. ... The fileselector display
Posted on Jan 10, 2009
  • mohammed marika thambi
    mohammed marika thambi Jan 10, 2009
    Please keep it clean and make sure the quality is considerably high:
    Spelling, grammar, overviews, descriptions, navigability, appearance,
    everything.
    Sergeant:
    Novelist:
  • 326 Answers
Tere are problems with your´s calculator display you need to take apart screws and carefull apart display, and then clean with isopropilic alcohol, arm display again and probe befor cover them, it´s ok close the cover if not repeat till the problem was solved
  • 15,935 Answers
My groundbreaking TI-81 developed the same symptoms when I purchased it in 1990 for $250.
I dropped mine, and a line was totally out and the pixels had jumped like yours.
I called TI, and they said the integrated circuitboard had to be replaced. Since everything resides on the main board, your only option is to send it to them for repair, or buy a new one.
They should be up to the TI-1000 by now!! LOL
    Sergeant:
    Scholar:
  • 199 Answers
If the screen is pressed od if the device is fall down some where this happens.
    President:
  • 2,110 Answers
Use a paperclip (tiny hole on back of caculator) and reset.
Move task bar to bottom of page
The desktop screenshot might need reducing
Click start "Control Panel."
Click "Display" and then select the Settings tab in the Display Properties window.
Use the slider bar under in the screen resolution section of the applet to change the resolution and click "Apply."
The screen repaints at the new resolution.
Click "Yes" to keep the resolution, or answer "No" at the prompt to revert to the original settings.
The taskbar is a central user interface component within the Microsoft Windows 2000 operating system.
Located along the bottom of the screen by default, it includes the "Start" button, provides one-click access to all open programs and contains a collection of utility icons and the system clock in a section called the Notification Area.
Windows 2000 gives you the ability to adjust the behavior of the taskbar in several ways.
After you know where to find the proper menu item, performing this task takes only a few clicks.
Right-click on an empty area of the taskbar and select "Properties."
Click the "General" tab located along the top of the resulting dialog box.
Check the Always on Top box if you want the taskbar to appear above all other items on your screen.
Check the Auto Hide box if you want the taskbar to disappear into the bottom of the screen when you move the cursor away from the taskbar.
Check the Show Small Icons in Start Menu box if you want to enable this behavior.
Check the Show Clock box to show the system clock within the Notification Area at the right edge of the taskbar.
Check the Personalized Menus box if you want the "Start" menu to show the items you use regularly and hide the items you don't.
Click "OK" to confirm your changes.
They take effect immediately.
Hope this helps
Nov 09, 2012 | Microsoft Windows 2000 Professional for PC
There's a blank bar that runs horizontal in the middle of my TI-84 plus that's about 16 pixels wide(high?). It's the same color as when the device is turned off. I've tried a memory reset and no results....
SPLIT SCREEN.
It sounds as if you might have split screen mode on. I've got a TI-83 as well as a TI-89 Titanium, both offer a split screen mode. The latter allows for choosing which applications are displayed on each half screen. I am presuming that you may have accidentally put your TI-84 in this mode.
So, if it is a split screen deal then all you have to do is go to the mode screen, find the option for switching from split screen to full screen, and switch it back to full.
I hope that helps. Give us your results!
Adios
Mar 11, 2011 | Texas Instruments TI-84 Plus Silver...
I have a ViewSonic19" VG930
Probably you have the incorrect settings. Go to your desktop and right click your mouse, display properties will show up, click on the settings tab and choose 1024x768, click apply and restart your computer. That will fix it.
If this was useful please vote.
Mar 01, 2011 | ViewSonic Computers & Internet
How do I change my computer monitor to 1680 x 1050?
First right-click on the desktop and then left click on Properties from the menu that appears.
The display properties dialogue box will appear as shown in fig. below, click on the settings tab at the top right of the box.
The areas worth noting are: google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); Screen Resolution
This slide bar is what you use to change the resolution, the options you have will depend on your graphics card and monitor, but the standard options are 800x600, 1024x768 and 1152x864.
Normally the default (in XP) is set to 800x600 which means the display will be 800 pixels wide and 600 pixels high.
Color Quality
This pull down box will contain the current colour options available, again this will depend on your grahics card and monitor, for best results select the highest option available.
Changing the ResolutionTo change your resolution simply slide the bar along to the resolution of your choice and then click the Apply button.
After clicking Apply your screen will resize to the new resolution and you will be presented with a confirm dialogue box, if you are happy with the way your screen looks then simply click Yes, if you would like to try a different resolution click No.
When you have finished simply close the Display properties box.
Jan 13, 2011 | Computers & Internet
Panasonic viera doesn't display computer correctly
I have had what is fundamentally the same problem. I have a desktop PC that I am plugging in to my Panasonic Viera TX-32LZD80. I am using DVI connection plugged in to HDMI port.
The solution is fairly simple; use the Menu button on the TV remote to get to the Main Menu for the TV and then select Setup which should be the fourth of four options. This will get you to the Setup Menu for the TV for the current channel. Look for the Picture Overscan option, it will very probably be set to On if you have the problem of %5 or so of display being missing on all sides.
Switch Picture Overscan to Off.
This immediately should solve your problem. A note of warning on this is that I suspected this was the problem but when I first looked at the Setup Menu I could not find the Picture Overscan option.
If you are unable to find the Picture Overscan option then trying fiddling with the Aspect settings. You will probably find it set to Auto. Switch it to 16:9 and you should find the Picture Overscan option will be available from the Setup Menu.
Hope it works for you.
Mar 03, 2009 | Televison & Video
Can't read boottom of the screen
right click on desktop left click on properties
go into display settings tab on the right
change the pixel setting to 1024 by sliding
the bar , you may have it set on something bigger,
Dec 17, 2008 | ASUS Eee 4G Notebook
Toshiba satellite m35x s149 displays red pixels for black pixels
if you have a warranty - have the manufacturer replace the lcd display unit.
Sep 26, 2008 | Toshiba Satellite 2250XCDS Notebook
Amilo A1650G laptop display problem.
ur display memory is corrupted. normally it is a shared memory or a part of the main memory unless u r using the graphics card.
try take out the RAM, clean it and put it back and switch on.
if not helped this, try with a good RAM.
good luck
Please don't forget to rate or accept the solution
Jun 18, 2008 | Siemens Computers & Internet
It is a display driver issue. You can buy a new one or get it repaired ($100).
Feb 10, 2008 | Texas Instruments TI-85 Calculator
Picture size too large
Did you try chaging the aspect ratio in the setup menus yet?
Feb 19, 2007 | Philips 46PP9302 46" Rear Projection...
Texas Instruments TI-85 Calculator Logo
47 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
