Question about Kenmore 98702 Stacked Washer/Dryer
Clunking dryer on Kenmore 417 94702300
The dryer has ejected 2 of the 3 small screws in the middle of the inside back of the tumbler. I managed to get them back in, but dryer still clunks loudly like something has slipped (gear, belt?)behind the tumbler. Can I safely take off the back? Is there anything user serviceable back there? What might be causing the thunk/clunk?
  • pjalcan Apr 19, 2009
    the screws are out and I can't get them back in. Behind the back wall of the dryer there is a metal ring that has slipped down and I would like to know how to get it back in place so I can get the screws back in. Can the back be taken off to accomodate this or do I need to get a service man hired to fix it?
I have this very same dryer and had the same problem. #1 those screws are just inadequately small and will snap off if not ejected. I took the dryer apart (not an easy task) and removed the bearing plate. Took it to a machine shop and had them drill bigger holes and weld some nuts to keep the bolts in place. This should make it better on the long run.
Posted on Apr 05, 2009
    New Friend:
  • 88 Answers
The back of this unit can not be opened . everything it through the front it could be the seal or the bearing in the back were you put the screws back.
Posted on Jan 11, 2009
Getting to the drum by taking the back off
you have to take top off first then , usually two screws and slide top forward , then about ten screws on back panel and lift up and that should give you access
Jan 16, 2012 | Maytag Dryers
I bought it in 2003 neptune dryer and the 3 bar inside the dryer broke and the dryer is not working right . we have to dry them 3 time before they are all dry
Instructions
Things You'll Need:
* Phillips-head screwdriver
* Replacement belt
1. Disconnect the power cord of the Maytag Neptune dryer from the dryer electrical outlet.
2. Open the dryer door, and locate the four screws on the inside lip of the door opening. Use a Phillips-head screwdriver to remove the four screws. This will disconnect the front panel from the shroud assembly.
3. Grab the front panel on each side with your hands. Lift up on the front panel to unhook it from the retaining tabs on the side panels. Remove the front panel, and set it out of your way.
4. Use a Phillips-head screwdriver to remove the four outside perimeter screws that secure the shroud and tumbler front to the dryer cabinet. Pull the shroud and tumbler front away from the tumbler while lifting the top panel partially up.
5. Reach both of your hands underneath each side of the tumbler. Use your left hand to grasp the idler pulley, and pull it to the left while using your right hand to slip the belt off the motor pulley. Pulling the idler pulley to the left releases tension on the belt. You can now slip the belt off the back of the tumbler.
6. Take the old belt with you along with the model number of your dryer to purchase a new belt. Most appliance repair shops will have replacement belts in stock. Make sure that the new belt matches the old one by comparing the two.
7. Slide the new belt over the rear of the tumbler with the ribbed side pointed to the inside. Using both hands under the tumbler, route the belt around the motor pulley and idler pulley. Pull the idler pulley to the left while routing the belt, and carefully allow the idler pulley back to the right to apply tension.
8. Reattach the tumbler front and shroud to the front of the cabinet using the retaining screws. Place the front panel over the side retaining tabs, and push it down to lock it in place.
9. Open the dryer door, and secure the front panel to the shroud using the retaining screws. Close the dryer door, and plug the power cord back into the dryer electrical outlet.
Feb 28, 2011 | Maytag Neptune MDE5500AY Electric Dryer
I have a Kenmore dryer. The fins are real loose, make alot of noise, catch socks, etc. How can I fix it.?
If the first three digits of the model number are "110." remove the lint filter from the top and remove the two exposed screws. Then you can insert a putty knife or similar tool into the gap between the front panel and top, about 2-1/2 inches in from the sides, and push in on the retaining clips. While pushing on a clip, simultaneously lift on that corresponding top corner, and the top will release to swing up.
This will expose the outside of the tumbler. As you spin the tumbler, each spot where a baffle is attached will come into view. After making sure there are no items inside the baffles (coins, pins, etc.), tighten the holding screws.
Dec 30, 2010 | Kenmore Dryers
Tumbler belt came off
  • Unplug your dryer from the electrical outlet. Remove the lint trap by lifting its cover and sliding it out. Use a screwdriver to unscrew the two screws that hold in the housing of the lint trap.Lift up the top panel of the dryer and take off the holder for the door switch wire. Look for the screws that hold in the front panel of the dryer, located on top of the front panel, and unscrew them. Take the panel off the dryer by lifting it off.Look inside the dryer, find the broken dryer belt, and before taking it off, note the way it is routed around the pulleys, then take it off. Install a new Whirlpool dryer belt by slipping it around the tumbler with the grooves facing the surface of the tumbler. Ask an assistant to hold up the tumbler while you move the belt into the proper place, aligned with the black line around the width of the tumbler.Wrap the new dryer belt around the pulleys as noted in Step 3. If you don't remember how, or the old belt was snapped and not aligned properly, look at the dryer belt diagram in your user's manual.Align the front panel of the dryer with the tumbler. Put back in the two screws that hold the panel in place. Open the door of your dryer and with your hand, turn the spinner one time counterclockwise. Reconnect the holder for the door switch wire, being careful that it doesn't touch any moving parts.Use the screwdriver to carefully position the rubber seal along the back of the tumbler. Make sure the seal is on the outside of the tumbler and that none of it sticks to the inside of the tumbler.Slide the lint filter and housing back into place, and screw in the two screws that hold it in. Plug the cord of the dryer back into the electrical outlet and check that it spins properly.
  • Oct 11, 2010 | Whirlpool Dryers
    I have a electric Kenmore Dryer, the Tumbler is off the tracks, but I can not seem to open the housing. No screws, just (2) plastic clips between the Top and Base Housing. How to open?
    two screws at the bottom of the front panel, the lid will lift off when you pry the front up with a large screw driver screws or clips on the inside
    Jun 18, 2009 | Kenmore 63942 Dryer
    One of the 3 tumblers inside the dryer fell off.
    you actually open the top first if you look between the front and the top you will see two clips. push these in with a small screwdriver to lift the top. then there is two screws holding on the front to get it off.
    May 21, 2009 | Dryers
    I have a Kenmore 70 Series gas dryer, model 76712691. The dryer has 3 plastic ''tumblers'' inside the dryer, to help the clothes tumble. Two of the tumblers have fallen off inside, leaving big holes inside...
    Pull the dryer away from the wall, there is no bottom on the dryer, so the screws should be on the floor.
    You can then pop the lid up from the front and fold it back. When you do, you will see the drum. Roll the drum around until you see the holes and reattach the tumblers.
    You can also access the drum from below. Tip the dryer on its back and you can see the drum from the bottom.
    Good luck.
    Regards,
    May 15, 2009 | Kenmore Dryers
    My kenmore series dryer is making noise as it runs. It heats but makes a noise as if coins are in the dryer. I cannot see anything from inside the dryer, is there a way to remove the front face of the...
    there's 2 basic ways to removing the front panel. First is 2 screws at the very bottom of the front panel, when removed the panel can be lifted and un-hinged from the top. The other is by using a flat screw driver and prying the top up at the edges on the front side the removing 2 screws or hex screws located inside the front panel toward the top. make sure you undo door swich wires before completely removing the front panel. then in the middle of the drum on the inside of it either 1-3 screws hold the drum to the back. Remove belt first then screws then pull drum straight out. The noise may be from your rear drum bearing or coins have gotten in the paddles of the drum(inside) paddles can be removed. I had coins in one of my paddles, made 60some cents lol at same time found perfctly round lint balls. Good Luck
    Mar 02, 2009 | Kenmore 63942 Dryer
    Clothes roll into a ball on kenmore gas dryer #11062202101
    Just get the filter out and remove the 2 phillips screw init's housing on top. Then use a putty knife to press against the spring clips that hold down the top Then just roll the drum around to the top where the holes are to reattach the baffle, get some screws and put it back.87656db.jpg
    Dec 15, 2008 | Kenmore 63942 Dryer
    How do I replace belt on kenmore dryer 66512?
    under the lint screen on the top of the dryer there are 2 screws. remove these screws. aong the edge where the front of the top of the dryer meet the top of the front of the dryer there are 2 clips. press in the clips with a putty knife to raise the top. look inside you will see 2 screws that go into the front of the dryer. remove thoughs screws and the front will lean forward and lift off. there you will be able to put belt around the drum, tension pulley and motor pulley
    Nov 27, 2007 | Kenmore 65924 Electric Dryer
    Kenmore 98702 Stacked Washer/Dryer Logo
    188 people viewed this question
    Sal De
    fordexpert
    Robert Rankin
