Question about Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1
I have vanguard 16 hp and just change the oil and both filters oil and air and now just run fine but after like five minutes is very hot
  • 708 Answers
The engine is not getting enough fuel. Lean burn=overhot engine.
Posted on Nov 18, 2017
  • 3 Answers
SOURCE: oil in air breather
sounds like you have too much oil in the engine (should normally be around 500-600ml when there is too much oil, it gets past the piston rings and pushes it through to the head.
Posted on Jul 09, 2009
SOURCE: engine runs at full speed all the time
adjust gov. tangs
Posted on Oct 13, 2009
1fastbob
  • 301 Answers
SOURCE: Our Vanguard 14 hp was idling and stopped. It
If this engine has been sitting for awhile I would guess the carb. is gummed up and need a good cleaning. First thing I would do is try a fresh spark plug. Just because the plug looks good doesn't mean it is. If you have a fuel filter check this also. If it is getting fuel into the carb and has spark and compression I would remove the carb and clean it.
Hope this helps
Bob
Posted on Oct 28, 2009
  • 5 Answers
SOURCE: i am looking for a wiring diagram on a vanguard
i will try to help. here is a website http://www.cartpartsplus.com/club-car-engine-upgrade-kit-18-hp.html and the forum http://forums.cartpartsplus.com/index.php. the forum will be your best bet.
Posted on Jan 06, 2010
  • 66 Answers
SOURCE: I have a B & S vanguard 20 H.P. vert. shaft, 8
Anti-foul plug adapters might be a temporary solution (treats the symptom and not the cause).
Personally, I would take it to a good, reputable, small engine repair shop that has verifiable references, and have them repair it.
Posted on Aug 03, 2010
Vanguard briggs and stratton 14 hp engine blowing oil out of the air filter what can it be? did change the head gasket.
broken oil ring compression ring ok just broken oil ring letting oil pass to blow out intake should have light smoke to coming out
Sep 23, 2014 | Briggs & Stratton Garden
Oil issue
try running the engine for 10 minutes then remove the drain plug. The sump oil is burnt to almost tar from lack of service or badly worn rings allowing combustion fire into the sump
Jun 01, 2013 | Tools & Hardware - Others
Blow by coming from the dip stick seal oil on Briggs & Stratton Vanguard 16 HP v-twin
2 options--- replace the dusted motor (faulty air filtering system) or re-ring the engine. Go for the new engine as the dust will have worn the piston and bearings.
Mar 22, 2013 | Cars & Trucks
Husqvarna model 450 will not start when hot
1 view piston. To do this, remove the muffler. 2 to change seals on crankshaft.
May 31, 2012 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a B & S vanguard 20 H.P. vert. shaft, 8 years old on Simplicty tractor. Keeps fouling plugs. Clean or replace plugs and it runs fine for about 1/2 an hour then starts to miss, blacksmoke, and...
Aug 03, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Hi i have a wr400 99model and have just done an oil filter n oil change then i started my bike it all seemed fine until five minutes of the bike running the header pipe started to glow red i drained the...
All the wrf's,250 426 400 etc. WILL heat up and boil if they are left running without being ridden.They need air to be flowing over the radiator.1 minute can be enough to get them hot if the choke is used.You wrote that this happened after an oil change.Did you previously let the bike sit and run?.Check your air filter is clean as this can enrich the fuel/air ratio and create extra heat.Main thing is ,shut the bike down if you are stopping for more then a very short time.To satisfy yourself,take the bike for a slow ride as it is warming up.It can take up to 1 mile to get proper temp. into the entire motor.Hope this helps
Apr 24, 2010 | 2000 Yamaha WR 400 F
Oil in air cleaner
Run it minus an air filter until all the oil is off your piston head, you can also try keeping the plug out and ejecting the oil via that access by pulling the cord. It seems like you've already solved the problem, now you're just cleaning up.
Apr 21, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Have a compressor that is powered by a vanguard 16 hp v twin manual engine that runs perfectly but only for ten minutes at a time, any ideas
The vanguard engine has full pressure lubrication and a spin on filter..
if the oil is low, lost its weight, (Thin) it will shut off. Also depending on what carburetor this engine has (Walboro, nikki,makuni) it may also have a fuel shutoff solenoid located on the bottom of the carburetor.
This has a history of sticking, especially if the unit sat with fuel in it,
To test if its the oil pressure shutting down the engine, make sure you have the correct oil in engine (10w-30 or 30hd) look on the engine where the oil filter is located. There is a single wire (some have more) that leads to the pressure switch that is screwed into the oil filter housing. Unplug the wire and start the engine.
If it runs and does not shut off, its either the oil is too thin or a defective oil switch. If the engine shut off, then reconnect the wire.
The problem will be fuel carburetion or both.
To see if its the crburetor, remove the air cleaner and remove the air filter. Take a can of carburetor cleaner and restart the engine.. as the engine starts to die, spray carb spray into the engine. Did it continue to run? If so its fuel.. if not its carburetion..
getting to the carburetor will be a task. you have to remove the air shroud. If you need more info e mail me direct and I will give you links to briggs and stratton on how to tear the unit down to get to the carburetor and whats involved.. Or let a ocal shop look at it for you.
ke4tud@juno.com
Nov 07, 2009 | Air Tools & Compressors
Oil in air breather
May 20, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Husqvarna chain saw starts and runs for 20 minutes then stops.
two things could be happening.......first is vapor lock......make sure you breather tube is clear and working........next is ....it could have a bad ignition coil on it.....after the coil gets hot the spark can become irratic or just not work any more.....
Feb 21, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1 Logo
130 people viewed this question
Top Briggs & Stratton Tools & Hardware - Others Experts
Randy Schumann
Randy Schumann
Bill Boyd
Daryl Gleaton
Are you a Briggs & Stratton Tool and Hardware - Other Expert? Answer questions, earn points and help others
