Question about Refrigerators
Where does the beverage rack go on the samsung french door frig?
SolutionGuy
  • 331 Answers
SOURCE: Freezing food in Frig especially lower compartments
Kathleen, you'll have to provide an accurate model number from the inside of your fridge for us to pull up any tech data on it. Open the door and look toward the ceiling of the fridge. But, from what you describe, it sounds like a thermister problem not a thermostat problem. A thermister is a small, temperature sensitive device that communicates with the computer to tell it what temperature its' location is at any given moment. The computer then adjusts air flow dampers, defrost cycles and cooling times accordingly. There can be many thermisters in any given refrigerator model line. These are inexpensive to purchase and easy to replace, but sometimes difficult to locate. They are usually hidden behind a small plastic shell, that looks completely unobtrusive. But they are easy to recognize for they have 2 white wires going into them that are tightly bonded together. To find them, you'll have to gut the fridge (food, shelves and all) and look closely. Focus your attention toward the area of the problem, the lower shelves/crispers. You may need to pull the rear panel out to find it, but when you do replace it. (UNPLUG YOUR FRIDGE FIRST!) Hope this gives you something to go on. If not, provide your full model number so we can assist further.
Posted on Sep 01, 2007
SOURCE: Water dispenser quit working on GE Profile French door 'frig.
The dispensers could be clogged with mineral deposits. If you look in your care manual it talks about a water vinegar solution that you pour into the top of the despenser, let sit, and then drain it through the back. I had a similar problem and it was because some of the water that was sitting in the top of the unit(where the gallon jug sits; under the black think) was full of frozen water which was blocking the water dispenser.
Posted on Jun 19, 2009
  • 363 Answers
SOURCE: maytag french door frig - Freezer works, frig warm
sounds like the freezer fan motor is worn out
Posted on Jul 22, 2009
  • 363 Answers
SOURCE: Loud compressor noise from lg frig...
The sound you hear is the Freezer Fan, this problem is hard to diagnose, because the fan spins but not fast enough to circulate chilled air thru the freezer and refrigerator. The minimum labor and material cost for the repair/replacement is around $300.00. But if you chose to make the repair yourself the motor alone costs around $80.00@appliancefactoryparts.com. But the repair is very labor because the electrical connection for this fan is at the rear of the unit
Posted on Jul 31, 2009
robmattie
SOURCE: GE French Door Frig control panel blinking temp #s
I had a very similar problem with our GE refrigerator. The main control board looked to be the culprit. I took out the board and did a visual inspection. Upon inspection I discovered that the (2) 470 micro farad capacitors were blown. I checked the power diode near these and it was still ok. I went to Radio Shack and picked up two 470 micro farad - 35V capacitors for and grand total of $2.60 and resoldered them myself. The refrigerator has been running great since. If you want to know more details email me and I will be happy to let you know what I know. I didn't want to pay $100 for a GE guy to replace a board either!
Posted on Aug 10, 2009
Samsung rfg297aa display for both the freezer and ref. temp.read 0f?
You frig is in Demo Mode. Hold your energy save anf freezer temp button for 3 seconds or until chimes and you should be good to go!!
Sep 15, 2010 | Samsung RFG297AA (285 cu ft) Bottom...
Sam Sung French Door Refrigerator RF267 After one month, water dispensing slow, small ice cubes, cloudy water. What is the solution?
It sounds like the water filter needs changed. Yes I see It's only been one month. Also make sure you have good water pressure to the frig.
I hope this helps.
Aug 23, 2010 | Samsung RF265AA Bottom Freezer French Door...
New Frig Won't Cool
Good day,
If it's brand new, it's under warranty. Have them fix it or replace it. They have no choice.
Apr 28, 2010 | Samsung RFG299AARS Stainless Steel (285 cu...
Why is my icemaker not working
My Samsung French-door frig had the same problem - try resetting ice maker - red button on the side of the ice maker. If that doesn't work call Samsung service - I had a bad circuit board which needed to be replaced by local Samsung repair service.
Apr 05, 2010 | Samsung RF265AA Bottom Freezer French Door...
I got a new french door frig and it wont make ice CUBES. It makes ice and even though the indicator says cubed ice, it comes out crushed. Is there a way to fix this easily. Otherwise i like the frig very...
Try removing the ice bucket and ensure that there is no obstruction (ice cubes stuck inside of metal blades). If no obstruction, then your problem may be in the electronic dispenser control board (if applicable) that distinguishes between cubed and crushed ice. If it appears that the problem is the board, then contact an appliance service company.
Feb 10, 2010 | Samsung RF265AA Bottom Freezer French Door...
My samsung frig suddenly started clicking (the bell that lets you know the frig door is opened.) checked to make sure all doors were closed but bell keeps ringing and now the temp. is rising inside. what's...
Can you pull the gasket back slightly (flat screwdriver or dull knife, don`t cut/rip the gasket) from the side of either fridge door and tell me if the cabinet light is on inside ? I need to know if the light is on without opening either door.
I`ll watch for your reply.
macmarkus :)
Feb 04, 2010 | Samsung RF265AA Bottom Freezer French Door...
Regarding GE french door model pfs221sbss, need
I would call your GE service company and give them the model number and serial number of your frig. They can look up which board fits your frig.
I hope this helps.
Feb 03, 2010 | GE PFS22SISSS Stainless Steel French Door...
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
