Question about Refrigerators
Rattle, buzzing noise all the time. Nudging it helps for a minute or two, then it starts up again.
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the model number of your unit? Where is the noise coming from? The compressor area?
Posted on Nov 27, 2012
2005 Honda Accord sunvisor buzz or rattle
has the visor got a slider for the mirror,if so, close it when not in use if not change it for a solid tinted plexiglass visor(no mirror) sorry but females will need to use central mirror for makeup..i am not a sexist by the way .........
Feb 11, 2010 | 2008 Honda Accord
Every time my sub hits it makes a buzzing
There may be any of several problems.
If you send high pitch signals to a speaker designed for lows, it can cause waves to propagate outward causing a buzzing. Look up the specs on the speaker and verify that your crossover cuts off well below the high end frequency for this speaker.
Another problem can be due to the mounting which can resonate. This should be mounted on at least plywood that is 1/2 inch or more thick. It needs to be wood as plastic or metal will rattle and buzz.
Another problem can be the wiring near this can rattle and buzz.
Check out these possibilities.
Dec 22, 2009 | Kicker 01C8VR4 Car Subwoofer
My air conditioner is on but not blowing cold air and buzzes
The compressor is not starting. The buzzing noise you hear is the compressor trying to start and then the thermal overload trips. When it cools it will try to start again. Could be a bad capacitor or the compressor is bad. These two units need to be tested to see which one is bad. A capacitor is inexpensive. If it's the compressor it will be cheaper to buy a new AC.
Aug 21, 2009 | Heating & Cooling
My new Kenmore window unit 76081 makes loud rattle
If it does not make the noise when the fan is ruunin you may ahve abroken sping in the compressor. Make sure you Window unit is level. If not the compressor will knock on the inside. Rusty
Jun 12, 2009 | Kenmore 76081 Wall/Window Air Conditioner
My central ac unit is blowing air that is cool but not cold
Ek chiz sukha ho to 2kg gila ho to 1kg and jal jaye to 3kg its urgent please
May 18, 2009 | Heating & Cooling
Noise & Clicking at regular intervals on working Kenmore 72214
yea that is the compressor relay, you will start to notice your food to thaw out and get bad. try to unplug for about an hour. if then it still does that call www.whirlpoolpartssurplus.com and get a relay kit.
May 06, 2009 | Kenmore 72212 / 72214 / 72219 Bottom...
Engine noise at cold start-up.
Sounds like your oil pump inside the engine is not pumping oil fast enough when you start your vehicle its common problem for mitsubishi motors my car does the same thing.
good luck
Nov 04, 2008 | 2002 Mitsubishi Montero
Buzzing and low temps
sound like a compresser relay/overload ,uplug the refigerator remove back cover, remove relay that is on the compressor and check it by shaking it , it should not rattle. if it does replace it..
Aug 10, 2008 | Frigidaire FRS26R4A Side by Side...
Refrigerator buzzing for 10 seconds every 4 or 5 minutes
Buzzing is usually a fan, like one in the freezer, or back bottom - for cooling the freon. The compressor over-heat usually will make a single click (off) and a few minutes later a click (on). If the fan in the freezer stops working well, the freezer will frost up and the fridge section will not be cold enough.
Apr 20, 2008 | Refrigerators
HL-r6167w wont start up (HELP)
it sound like the color wheel is bad
Nov 26, 2007 | Samsung HL-R6167W 61" HDTV
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
