Question about Echo Garden
What size chain for echo chainsaw farm ace 510
SOURCE: need true chain/bar size for my husqvarna Model 254 chainsaw
Maximum bar size of 20" but would recommend 18", if it is running sluggish, check compression, if low replace the piston, if it is 135psi or more then make sure the airfilter is clean and then tune the carb and make sure you get good revs and throttle response throughout the rev range, use the typical carb adjustments from the owners manual from the Husky web site. This is a 5hp saw and is capable of cutting some big lumps of hardwood so no excuses on the power front
Posted on Mar 16, 2009
  • 398 Answers
SOURCE: need to know oil to gas ratio mix for echo 510 evl chain saw
50:1 or of its old 100:1
Posted on Mar 20, 2009
agent91
  • 2100 Answers
SOURCE: what size file do i use for a Ryobi chainsaw model pcn4545
The standard chain file should fit it. It is about 3/16 dia. I found the dremel to work 10 times better, they have a little stone bit just for chains. Eventually, you have to take it in for sharpening, it will set all the teeth the same.
Posted on Feb 25, 2010
  • 4088 Answers
SOURCE: Chain brake jammed on Echo CS400 chainsaw
You will need to release the brake by applying a very heavy screwdriver to the + shaped part of the brake coupling. Check the action of the brake handle and duplicate it at the the +. Hope this helps!
Posted on Jun 26, 2010
  • 122 Answers
SOURCE: I am searching for the the saw chain size for a Mc...
That is a MACCAT Super 18, find your saw in this link:
http://www.mymowerparts.com/pdf/McCulloch_Parts_Service_Repair_Manuals/Gas_Powered_Chain_Saws/
Posted on Feb 08, 2011
How do i clean oiler for chain on stihl farm boss?
The filter could be stuffed with sawdust, but depending on the model of saw, the problem could also be the oil pump drive system.
First of all though, empty out the chain oil and then part fill the chain oil tank with petrol, replace the cap and with the saw switched off, shake the saw violently for 10 secs. Remove the cap and empty out the tank and then refill with chain oil and try out the saw, revving it and check if any oil is flowing onto the chain.
If that has not solved the problem, let me know what the model of the saw is, Farm Boss is not enough, it could be an 038 an 041 and a few more as the farm boss name is used as well as the number.
We can then check a few other points which could be causing the problem.
Sep 16, 2014 | Stihl Farm Boss Chainsaw 16"
Fuel mix
The oil ratio is 50:1
Here is the website: http://homeguides.sfgate.com/oil-fuel-mixture-farm-tough-husqvarna-chainsaw-83933.html What Is the Oil Fuel Mixture for Farm Tough Husqvarna Chainsaw
Aug 19, 2014 | Husqvarna Chain Saw Handle Models 362 365...
Size file sharpen poulan 18
Take your saw to a shop that repairs chainsaws. They will be able to get you the right file for the size of chain on your saw.
Dec 18, 2013 | Echo CS600P Gas Chainsaw 20 Inch
How to clean carburettor on Echo Farm Ace chainsaw. starts and runs fine, but gutless when actually cutting timber.
It may not be your carb, but that your piston rings are worn out and the engine is no longer getting enough compression under load.
Mar 20, 2010 | Garden
The oil cap for my chainsaw is missing and is needed for the blade. Where will i be able to get hold of 1?
most home and farm stores like farm and fleet, mill's fleet and farm have a universal cap for this use
Oct 25, 2009 | Poulan Pro Chain Saw 46cc 20"
Echo sc 4400 Chainsaw blade turns constantly
If lowering idle speed does not stop chain broken clutch springs will cause chain to not stop
Jun 10, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Garden Logo
225 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
