Question about Hardware & Accessories
GE 6 outlet model 58170LO - Hardware & Accessories
  • 5,245 Answers
Copy following link for GE timers and all brands power-strip timers:
http://waterheatertimer.org/GE-timers-and-manuals.html#powerstrip
For more outdoor timers:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
If you do not have timer, add comment and describe product in detail
Posted on Nov 27, 2012
Jasco Ge 8HR Mechanical Blk Timer 2 Outlet Grnd
1) Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/GE-timers-and-manuals.html#outdoor
2) Add a comment and describe timer in detail.
Dec 18, 2012 | Jasco Ge 8HR Mechanical Blk Timer 2 Outlet...
How to set the timer on a ge 58170LO
Timer is not fully identified;
Copy following links to help identify timer and read instructions:
http://waterheatertimer.org/How-to-set-timers.html
Dec 07, 2011 | GE Home
How do I wire a double pole double throw 240 volt ge intermatic timer to 4 240 volt plugs?
You posted under GE timer, but added the brand name Intermatic.
GE and Intermatic timers are totally different.
Wiring below is for GE and will not apply to Intermatic.
Step 1) lets cover basic GE timer wiring for 240Volt load.
Be sure to set dip switches BEFORE applying power.
Step by step illustrations show on following link.
http://waterheatertimer.org/How-to-wire-GE-15207-timer.html
Step 2) Load wires exit GE timer.
There are two Hot wires and 1 bare ground wire.
Step 3) Wire the outlets: You have 4 240Volt plugs.
This could mean a receptacle-type outlet like a clothes dryer outlet or air conditioner outlet.
Or it could be a twist-lock receptacle or extension-cord-type stage plug.
In all cases, look at screw color on device.
Connect Hot wires to brass colored screws.
Connect ground wire to green screw.
Step 4) Calculate total Load
Manual appears below: Look at Normally Open contacts. These contacts turn ON when timer turns ON.
http://waterheatertimer.org/15087-15207-56922-Manual-eng.pdf
Total load on all 4 plugs cannot exceed 2 HP
Generally, a 30 amp timer is rated for max 24 Amps or 6 amps per each of the 4 plugs.
Volts x amps = watts.
Take total watts and divide by 240Volts to get amps.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 20, 2011 | General Electric GE 56941 24-Hour Outdoor...
How do I reset Jasco Ge 24HR Timer 6 Outlet Grounded Yard Stake? It was working fine then shorted out and now won't receive power
Open link below to confirm this is your yard stake.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59730
1) I tested this timer, and there is no reset.
2) Check that circuit has power. Plug timer into another outlet and see if there is problem with outlet.
3) Buy another GE yard stake at Home Depot and then return defective one.
4) This timer is for 'temporary' outdoor use like seasonal lights.
If timer was buried in snow or got real wet, it might not perform
5) Maximum load for all outlets is 1200 watts.
This timer is not heavy enough for motor loads because motor draw a lot of amps when starting.
For pumps up to 1/4HP use GE15117, or Intermatic HB88RC
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-24
For pumps over 1/4HP, use box timer like GE15207, or Intermatic T101.
http://waterheatertimer.org/GE-timers-and-manuals.html#15207
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Dec 27, 2010 | Jasco Ge 24HR Timer 6 Outlet Grounded Yard...
I've lost the instructions for my Holiday Living #10243 6-outlet outdoor yard sake with digital easy set timer. How do I program the yard stake? thanks!
I think the Holiday Living yard stake is made by Woods.
GE sells identical 6-outlet yard stake for which I have a manual with clear instructions and images:
http://waterheatertimer.org/pdf/GE-15107-outdoor-timer-manual.pdf
Add a comment to help me identify your timer so others will be helped also.
If manual shown above is incorrect, open link below to view general list of yard stakes with manuals:
http://waterheatertimer.org/Woods-timers-and-manuals.html#yard-stake
Dec 11, 2010 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
I have a holiday living 6 outlet yard timer and i lost my directions....Model # lx28006
Woods brands sells timers that are packaged and sold under various names and numbers.
For example GE sells same yard stake under their brand.
Woods 6-outlet yard stake manual:
Add a comment and say if this is your timer manual.
Dec 05, 2010 | Hardware & Accessories
Model jvm131h002 Stopped working. no power or
yes, at the back of the microwave there are 4 or 6 screws, take them out and then pull the cover follow the cable( the one you connect to the outlet) going to the inside of the microwave inside you will see the fuse change it with the same size, it is a slow burn fuse
Aug 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Counter top microwave GE lost all power
As an owner of a GE WES model might want to look at this blog post.
GE Customer Service is here.
Good luck.
Dec 16, 2008 | GE Microwave Ovens
Hardware & Accessories Logo
862 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
