Question about Dahle Office Equipment & Supplies
Paper full sign lights even though basket is empty
Remove basket and door sign is on, replace empty basket, paper full light comes on
  • 35 Answers
SOURCE: Basket full light on
without seeing the product, there are 2 (two) things to check.
First, unplug the shredder and go underneath where the bin full flap is. Sometimes paper debris gets stuck between the flap and switch. Check to ensure the switch is not out of adjustment. you'll have to remove the top cover to perform this. Otherwise, your PC Board is defective.
Posted on Mar 03, 2009
  • 105 Answers
SOURCE: Full basket light keeps coming on even though basket is not full
you need to clean or replace bin full sensors.
Posted on Jun 02, 2009
SOURCE: Fellowes S8-*5c
If this is actually an SB-15C I posted a solution elsewhere and will repeat it:
I called the toll free number for Fellowes Help Line, 800.955.0959, and spoke to John who was most familiar with the SB-15c. I indicated that the "bin full" LED was bad (actually the transmit bulb). After John ascertained that I had indeed cleaned the bulbs, he made available a replacement part, MasterCard or VISA required. Replacement of these bulbs is not for everyone. A level of technical ability and some tools will be required.
I have never had this level of technical support available on the first call. Kudos for Fellowes.
Posted on Jul 07, 2009
  • 41 Answers
SOURCE: the basket full light comes on even when the
needs bag full retorfit kit available from fellowes if under warranty or we have the part for sale if not under warranty cooksmobileshred@bellsouth.net
Posted on May 10, 2010
  • 41 Answers
SOURCE: the basket full light comes on even when the basket is empty
it needs retrofit kit fellowes will replace if under warranty if not you may purchase the kit from cooksmobileshred@bellsouth.net 901-565-8188
Posted on May 11, 2010
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Aug 19, 2014 | Dehumidifiers
We have a CR220 fellowes shredder. It will shred 1/2 of a peice of paper, then the basket full light comes on even tho the basket is empty.
you can try cleaning the "bin- full" sensors. they are located on the inside of cabinet, on the bottom of the shredder "head". one will be to the left side of basket and one to the right. they kind of look like little glass eyes mounted inside of black rubber casings. paper dust on these will do this sometimes. if that doesn't do it then it sounds like your "bin-full" sensors are bad. a known problem with these shredders. fellowes has come out with modified sensors. if it was purchased within 2 years, it should still be under warranty.
hth,
razors
Mar 10, 2011 | Fellowes Office Equipment & Supplies
How to empty full royal vf1000mx shredder. No, the basket does not pull off.
You may have the basket completely full and jammed with paper which is why it won't come out easily.....you will just have to try to slightly lift the basket and pull forwards to remove it.
Jun 24, 2010 | Royal Office Equipment & Supplies
The basket full light comes on even when the basket is empty. if you hold the shred button down it will shred as long as it is pressed
Mar 19, 2010 | Fellowes Powershred 220CC Shredder
I have an Ativa AT120DC. It won't operate
I have an Ativa AT120DC Shredder. When it is switched to auto there is dim green light and it doesn't start. If I feed paper in it makes no difference. For some time it always started up when you switched it to auto and didn't wait for paper to be fed through. If you remove the basket the Door Open light comes on. can you help?
Mar 18, 2010 | Office Equipment & Supplies
Just got a px1000mx & the paper basket is full. How the heck do you open it? Did not see the answer in the instructions - it's gotta be easy, right?
You have probably got the bin so full it is stuck/jammed full of paper and you now can't remove it...this is a "consumer" model machine and to keep cost low they do not provide a "bag-full" light on the panel...you should regularly empty the bin so that the shredded paper does not totally jam the bin and in extreme cases then get caught back up into the cutting machanism and blow the pcb inside the machine...check your "users" instructions to remove the bin.
Dec 15, 2009 | Royal Office Equipment & Supplies
The empty basket light stays on all the time
Try cleaning the bin full sensors. located on both sides of your machine, inside the bin,under the cutter head. If that does not solve problem, you need to replace bin full sensors.
May 04, 2009 | Fellowes Powershred 320 Shredder
Mar 02, 2009 | Fellowes 2200 Cross-Cut Shredder
Top Dahle Office Equipment & Supplies Experts
jhnolson
Dennis Key
Dennis Key
Are you a Dahle Office Equipment and Supply Expert? Answer questions, earn points and help others
