Question about Video Game Consoles & Games
Ps3 is in hdmi1 and direct tv and wii has to share the video input because my tv doesn't have enough outlets so I have to switch cables every time . How can I get the wii to work ?
    New Friend:
What you could do is setup the PS3 to HDMI-1, DirectTV to HDMI-2(or whatever compatable) and setup the Wii to either a component cable(RGBWR) or a Composite cable (YWR).
I'm not sure you can support all 3 systems through 1 HDMI cable, Not unless there is a tree cable that you have to all three. And even then only one could be on at a time.
Posted on Nov 27, 2012
Heiny
  • 10 Answers
SOURCE: PS3 no longer communicating with TV
All: Try this -
P
erform the following steps to reset the Video Output Settings.
  1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
Posted on Dec 17, 2007
  • 6 Answers
The problem is with your PS3 itself.
If it's still under warranty, take it back.
Posted on May 30, 2009
SOURCE: A humming noise coming from tv when cable and ps3 are hooked up
I fixed mine by removing the cable wire from my tv. For some reason tv cable and the old PS3's cause a problem.
Posted on Jun 18, 2009
SOURCE: Black and White Video - Wii Component cable
put yellow in video red and white in audio and change source to av
Posted on Jul 08, 2009
fkuk
  • 311 Answers
SOURCE: hooking up wii and dvd to tv
does your tv have scart sockets?
if so you can buy this adapter that on one side is the scart socket and the other is the yellow red white sockets
something like this
http://cgi.ebay.co.uk/Switched-SCART-Adapter-Red-Black-Yellow-RCA-Socket_W0QQitemZ260520047480QQcmdZViewItemQQptZUK_Computing_CablesConnectors_RL?hash=item3ca8347378
Posted on Dec 31, 2009
How do I get the VIDEO input on my Sony TV?
Your set does not have a video input. However, if you check out the component connection instructions there should be something there about which input to use for just a straight video signal from older gear.
Oct 12, 2016 | Sony Televison & Video
My emerson tv say device control inactive
John, I've ran into this issue a couple of times myself. In most cases, there are easy fixes to the issue. #1, Does your TV have multiple HDMI inputs? They may be labeled HDMI1, or HDMI2, etc. I know this sounds strange, but many people don't realize that the signal source is important. #2, Connect the cord, from another device that you know works(laptop-monitor) to eliminate the possibility that your HDMI cord is bad. #3, (Probably most common) The PS3 is not the most stable platform when using the HDMI cord. Remember that the PS3 was one of the "pioneering" platforms using the HDMI connection.As such, the "auto-detect" feature is sometimes confused when switching between RCA inputs, and HDMI input. (Happens every time actually) To fix this, try a video reset on your PS3 system. It's fast, easy, and doesn't effect anything except the video/audio settings. I'll put in a link to get you started in that direction. It is the same with all models of PS3. Good luck! ^^
How To Reset PS3 Video Settings PS3
May 06, 2013 | Sony Playstation 3 (PS3) Console
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
I plugged in my PS3 using an HDMI cable and i get no feedback
If you just bought the PS3 use your composite cables that came with the system. Turn the PS3 on and go to the video settings, set up video input to HDMI. After you've done that plug your HDMI back into your PS3 and try turning it on. If that works go back to video settings and change the resolution to 1080p. If that doesn't work make sure your T.V. is on the same input that the HDMI cable is plugged in. If it is and still doesn't work try switching to a different HDMI port. If switching to a different HDMI port doesn't work try a new HDMI cable. If the new HDMI cable doesn't work then there is a problem with the port on the PS3 which would require a repair.
May 03, 2011 | Toshiba 50HP66 50 in. Plasma Television
Put my ps3 on hdmi cable and now cant get it back to av . tryed holding the on/off button on for the first and second dong but still not back to av HELP
Welcome to Fixya. If you're using a HDMI cable to connect your Ps3 to your TV you need to set the input to HDMI. Use the remote of the TV look for Source or Input Button then change the Input to HDMI1 or HDMI2.
Thanks for using Fixya.
Feb 25, 2011 | Sony Playstation 3 (PS3) Console
My ps3 is hooked up though HDMI to my emerson lc195emx. but the tv says its an unsupported format. why? is it because the tv only has 720p out put??
Try turning off the power to your console using the power switch in the back (first shut it down properly). Unplug the AV cables (if applicable) and the plug in the HDMI cable. Turn on the system and switch your input on your Television to HDMI. (Keep in mind that there may be a few inputs; HDMI1, HDMI2, etc.) The HDMI connection takes a few seconds so be patient. If that doesn't work, re post or ask to chat.
Feb 05, 2011 | Sony Playstation 3 (PS3) Console
Wont sow anything on tv
make sure your cables are properly put in the correct input, also check the plug that goes into your ps3, if it still don't work see if you are putting the right video input on your tv i.e: Video1, Video2/ HDMI1,HDMI2, if problem still occurs maybe the A/V Cable is broken
Apr 08, 2010 | Sony Playstation 3 (PS3) Console
No longer getting video feed through Home Theatre receiver
HDMI ports 5 and 6 on the back of tv no longer are working. (We had a series of thunder storms so don't know if that is how they got damaged or if it was something else) but moved HDMI input cable to HDMI port 4 on tv and everything is working again. Service call placed for warranty service on tv to repair bad ports.
Sep 14, 2009 | Sharp Televison & Video
Video Game Consoles & Games Logo
32 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
