Question about Maytag Dual Cool 25 cu. ft. Side-by-Side Refrigerator MSD2556
Ice maker is overfilling - Maytag Dual Cool 25 cu. ft. Side-by-Side Refrigerator MSD2556
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Here is the service manual for that ice maker. Look at page 26 for the water volume information.
Posted on Nov 27, 2012
GE Profile Model PSS26LGSC Ice maker not working
Did the ice buildup appear to resemble the water overfilling the top of the ice maker? The only thing that I believe that may work is removing the ice maker, clean the excess ice buildup.dry and reinstall the ice maker and see it works. If the ice is above the normal level the ice can cause the motor that pushes the ice out of its slots to strain more than the gears or motor can handle stripping the gear or damaging the motor beyond repair, When harvest takes place the first thing that happens is a heater below the ice maker warms the cubes a little just enough to allow them to slide out of their slots and fall into the ice bin. The ice make for your model does not have replaceable parts and if bad or damaged it is less expensive and time consuming to by a new ice maker. If the water fills above the top of the ice maker it is usually the fault of the water control valve not closing all the way once it fills the ice maker after each harvest. Did water refill the ice maker when you cleaned it? Did the water overfill after you cleaned out the ice maker? What I am asking is water over filling ice maker again after you cleaned out the excess ice? If the water continues to flow from the WR57X10032 Water Inlet Valve
Apr 07, 2013 | GE Refrigerators
Have Amana side-by-side about 14 yrs old. The icemaker overfills ice tray by about 8oz of water? Please help!
Unless someone has made a water level adjustment there is,
Only one repair. Replace the ice maker.
If someone has made a water level adjustment you can try this.
Remove the ice maker plastic cover. Locate the water level screw adjust it to a minimum setting and try it there.
If that does not correct the problem, replace the ice maker.
May 26, 2009 | Amana SXD524VW Side by Side Refrigerator
Ice maker overfill
The metal off/on arm may be disconnected. A full bin should keep the arm in the up position and shut off the ice maker.
Remove, then re-insert the metal arm in the back of the ice maker control head.
Make sure that a full bin of ice activates the control arm.
You may need to buy a replacement arm that is longer so that the ice catches on the arm.
May 20, 2009 | Jenn-Air JCD2295KES Stainless Steel
Ice Maker overfilling with water
you may have abad water valve or icemaker
Apr 02, 2009 | Admiral 26 cu. ft. Side-By-Side...
Ice bucket/bin frozen in place
mine was overfilling because the ice was getting stuck on the way out. So some stayed in the tray and when the water would refil, it would overfil and go over the stuk cubes. leaving it to overflow to the bottom and freeze like yours.
Sep 09, 2008 | U-Line Icemaker
Ice maker leaks water into Ice bend. When it cycles I can watch it drip water from the ice maker.
not familuar with the brand but sounds like one of 2 issues
if it is overfilling making ice cubes larger than normal, adjust the ice maker fill time if it is possible
icemaker fills and cuts off but water valve seeps water after the fill causing the water overfill
one of the 2
Jun 23, 2008 | U-Line Icemaker
Ice Maker
Pressure difference between the two water supply systems is the cause of the overfill condition. You may have to install a water pressure regulator in line to the ice maker water supply. Or you can try to control the flow by throttling the supply valve to the refrigerator.
Jun 12, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice Maker overflow
my icemaker overfill can you help
Oct 31, 2007 | Refrigerators
Refrigerators Logo
52 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
