Question about Epson TM-U220 Matrix Printer
Printing is too slow
There are only 2 resolution available..160x144 and 80x72 if i use the first one it is clear but print slowly,,if i use the second one..print fast but i cannot read it...maybe there is a problem in my font? what font is preferred by this i use arial narrow
4 Suggested Answers
Rain041304
  • 63 Answers
SOURCE: PDF printing with DFX 9000
Actually, the issue that your having is a software issue. You need to check the settings of the reader. Try to contact Adobe and ask help for its settings. They're phone number is 1-800-945-9120.
Posted on Feb 07, 2008
printech
  • 159 Answers
SOURCE: Epson LX-300+II, the font problem
yes you can change the font tray to print the printer internal setting tray that press and hold any key by tarn the printer off then on after you tarn the printer on release the key
Posted on Sep 06, 2008
have you check the white cable? (from the printer head to the
mainboard) .If the white cable is ok and you confirm that the
printer head is fine, then the problem is at the mainboard.
most problems like this that i had encountered is at the transistor
at the mainboard. Try to check it out using a multitester.
Posted on Sep 08, 2008
Printer is printing very slow
hi,
issue # 1: if this printer is connected using USB, one of the reasons why this printer is printing slow because of the quality of your graphics.
resolution: if you are printing a very large file "picture" I suggest to change the resolution of the image
issue # 2: Most often than not, operating system take major factor on the slowness of the procedure or a task.
resolution: - restart PC/laptop - Resolution: clear up some space from your PC/laptop "disk cleanup utility" - close unused programs
issue # 3: anti virus protection "firewall"
resolution: - turn off firewall - turn off auto scan process
issue # 4: the printer itself - relocate usb cable to another port then restart printer
reply from again and answer this question so that I could assist you better:
1. what is operation system? 2. what are you trying to print? 3. does it happens on all you printing jobs? 4. what is your anti virus system? 5. does your printing got stuck in the printer spooler?
Jun 04, 2011 | HP Photosmart C6380 All-In-One InkJet...
Printing in color on my Lexmark printer is very slow. This is a wireless printer and is not so slow on black and white printing.
Printing in color is always slow vs. printing in B/W. If your printing color with the highest resolution setting, it will print really slow. You can adjust the resolution settings in Printer Properties for the Lexmark. If you want faster print, select a lower resolution.
Mar 03, 2011 | Lexmark X7675 Wireless All-in-One Printer
Prints too slowly
check your paper settings and resolution.
If you have a heavy paper type set, or highest print quality, the printer will slow down to accomodate the features.
Dec 12, 2010 | HP DeskJet 3650 InkJet Printer
In any mode he is printing to slow. 2 pages per a min. Its lexmark 650n
If the printer resolution is set very high, this can slow printing. So can high resolution input. Is the printer showing any sign of memory loss? Try a test print--it should come out quickly. Good luck!
Sep 18, 2010 | Lexmark T650n Laser Printer
The printer prints very slowly all of a sudden. It took over an hour to print out 4 pages. I've unplugged everything. I've cleared the print ques. Same thing is happening when I copy. Help!
If the output quality has improved greatly, you may have selected the "High" quality instead of "Normal". The front panel should give you a clue as to how to adjust.
Jun 11, 2009 | HP PSC 2410 All-In-One InkJet Printer
Prints extremely slow
It seems that you are trying to Print High Resolution Pics. Thats why you are getting prints slowly.
Try reducing the Resolution of the Pic or setting the quality of print to Normal in the Print Preferences and your speed will increase for sure.
Apr 24, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Canon 3300i prints / process very slow
These machines can print slowly for a varity of reasons. First and foremost is using the incorrect driver. The correct driver can be downloaded here:
http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2275&modelid=6349
Also slow printing can be a symtom of a hard drive about to fail (e602 codes).
Fastest printing speeds can be achieved using the following basic assumptions:
1) The copier is printing thru a standard cat5 cable; not thru the parallel port.
2) The network the copier is on is healthy and operating normally.
3) The network settings on the copier are configured correctly.
I am a Canon trained authorized tech on these machines and have been working in the field on the ImageRunner 3300 series since their release. I'm not sure if a ram upgrade is available but I haven't installed one in the six plus years of servicing this machine to fix a slow print problem.
Nov 09, 2008 | Canon imageRUNNER 3300i Printer
I want to know if there is a way to clear the memory on a 4350
If the printer is processing jobs slow,  especially for PDF's before they come out of the printer  it's probably a printer memory issue. To test, send the print job at a lower resolution. If that works then you can just print jobs at that resolution or install more memory.  If the print jobs are coming out of the printer slow then your printer settings may be set to the highest resolution of pro res instead of the default fast res which cuts the printer speed in about half.
Oct 22, 2008 | HP LaserJet 4350 Printer
Datamax M-4206 printing too slow
The way you can do this is to use Datamax fonts in your LabelMatrix program instead of truetype fonts like arial or times new roman. After making this change, do a test print and see if print improves. Another possible solution is use USB instead of Parallel cable (if you're not using it already).
Aug 25, 2008 | Datamax M-Class Thermal Printer
Slow printing of large pdfs
Sounds like you are just bogging down the Printer's memory.
Your best option is to upgrade the memory.
May 21, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Epson TM-U220 Matrix Printer Logo
64 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
