How do I change resolution from 480i to 720 on RCA Scenium HDLP50W151
I was watching the TV and I think I hit a button on the DirecTV remote. Next thing, I lost the picture but still have sound. Resolution seems to have been reset to 480i somehow and can't seem to reset it. Any thoughts? Thanks in advance
  • 87 Answers
SOURCE: RCA Scenium HDLP50W151
Color wheel bad #212184
Approx $400 by an authorized RCA shop
Posted on Jan 03, 2008
  • 62 Answers
SOURCE: changing resolution settings
Change the resolution through your Cable / Satellite box - Go into the menu. Most of the Akai tv sets do not have an option to change the resolution.
Posted on Mar 30, 2008
  • 157 Answers
SOURCE: i replaced the lamp in my rca scenium hdlp50w151
Replace color wheel-part number 212184
Posted on Sep 02, 2009
tvtek
  • 1284 Answers
SOURCE: HAVE RCA SCENIUM 50
The noise you are hearing is due to the fact the color wheel is failing. It may go on several more months like that or not. The bearings in it are where the noise is coming from. The part number for the color wheel is 212184 and is no longer available. You can however purchase from people on ebay or do a google search for this part. Its not that tough to replace but advisable to have a technician do it once you purchase one. Please take a moment to rate my answer. Thanks...
Posted on Nov 23, 2009
Testimonial: "Information was very helpful and accurate. I was told by a local technician in the town where I live the exact same thing."
  • 1030 Answers
SOURCE: My RCA Scenium HDLP50W151 TV has no picture. It
do you here a whining sound when you plug it up. when these units are first plug up there is a part called the color wheel that spins during boot process. if it doesnt reach speed then the lamp never fires. It is a motor and anything that moves evientally stops moving. it would have to be replace if you can get the part
Posted on Dec 10, 2009
How do I change my resolution on my 32 inch flat screen from 480 to 720
Assuming your TV will support 720p signals, check how you have the TV connected to the Playstation 3. Change your video cable to component video or HDMI, depending on the TV. (The Composite input is limited to 480i (SD) pictures. The same is true for a SCART connection.) Put the TV to the new input by pressing the Input Source button on the TV Remote or through the menu depending on your TV.
You may have to do the first of these steps before changing your cables and the TV input source (I'm not sure). On the Playstation, select Settings and then Display Settings.Choose your video output (component or HDMI). Next select all resolution that the TV can use. (Most 32" TVs only do 720p. There are some that can do 1080i or 1080p.) Confirm the video connection works. Then Save your settings.
For screen captures of the steps, see: http://manuals.playstation.net/document/en/ps3/3_15/settings/videooutput.html . You should always turn off the TV and the Playstation before swapping the cables. (So you may need to stop and save after setting the output to component video. Then return to the Display Settings menu.)
I hope this helps.
Mar 14, 2013 | Televison & Video
How do i change from 480i to 1080i on a sharp 52"
You don't. The TV picture will be fuzzy when watching a program in 480. If you have a lot of video in 480 or 720 you can get an up scaler. They are expensive, but that is the only way you'll ever get a Hi def picture from a low resolution signal
May 28, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
My tv made a pop noise and no has no picture just sound
Sounds like your bulb poped, They are easy to change, there should be an access panel on the back, here is a link to the bulb for your model.
http://www.allprojectorlamps.com/RCA-ScEnIUM-HDLP50W151-COMPLETE-LAMP-MODULE--HYBRID-BRAND_p_38779.html
Sep 15, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
Need to change resolution to 720 on Vega 55 LCD. Hate 1080i
U can't change any air tv programs show on over the air resolution.Resolution are set by the tv stations set their programs by airing itself like 480i,720i and 1080i.U get what u get,the only thing is the tv programs air resolution air,the tv u got can get that resolution,that it.
Jul 06, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
How do you change the resolution of the TV from 480i to 720, ect.
i also have a toshiba and there are settings that you can change within the menu button on the remote, when you select the menu you should see where you can change the picture settings if all else fails refer to the owners manual! good luck!
Dec 18, 2009 | Toshiba 32HL67 32 in. LCD Television
Dec 10, 2009 | RCA Televison & Video
480i is displayed on the 62HM95 even when I play my Sony BluRay
I called toshiba (the television manufacturer) and they told me that the tv recognized the devices and then adjusts to the resolution according to the device of where its receiving the signal (HDMI).In this case my blu ray was not set to the 1080i resolution. Yesterday I set it up and BAM there it was.
Dec 03, 2008 | Toshiba 62HM95 62" HDTV
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
