Question about Philips 42FD9954 42 in. Plasma HDTV
No lights and wont turn on. cord is good. 120v all the way through into the circuit board
    Top Expert:
  • Philips Master
  • 75,178 Answers
The main switching power supply section circuit [SMPS] is faulty. Check and replace it.
Posted on Nov 27, 2012
My TV is dead. What boards should i replace?
have you checked the DC side of TV LOOK FOR ANY CAPACITORS with holes blown in them and are a of a burnt appearance , and also look for any breaks in circuit board also look for holes in circuit solder . I know this might sound silly have you checked the fuse in the MAINS PLUG ....
Dec 28, 2015 | Televison & Video
I have a frigidaire electric stove,model # 316433603 there is power to the stove the only working is the clock
General answer for all electric stoves: Electric stoves are usually 220V in the USA. The clock is 120V. My first "guess" is that you have 120v to your clock and maybe light if the stove has one. You should have a separate 220v power cable ( see photo attached) that will power the range itself. The cord may be missing ( simple to unbolt), the cord my be unplugged, or the 220 circuit may be turned off at the fuse box or circuit breaker.
Mar 02, 2015 | Stoves Ovens
Everything works except the heat. Light on oven temp adjustment not coming on. Circuit boards look good. No burnt or overheated wiring. Transformer looks good, not certain how to test heat coil.
Is it 220v??? If so make sure u have correct voltage. All the oven lights and circuit boards are ram off 120v. The element probably requires 220v to operate.
Also take multimeter and check continuity across element. Should make meter beep or display will read 0.00.
Dec 28, 2012 | Ovens
LG Washer WM2277HW wont turn on what can I do?
I would try plugging it into a different self dedicated outlet. It also might be the internal plug connection. Use a heavy duty extension cord to see if it works off a different circuit.
Jan 23, 2012 | LG WM-2277HW Front Load Washer
SONY KP-65WS510 WONT TURN ON RED LIGHT BLINKS 4TIMES AND THEN OFF THEN 4 TIMES AND OFF ETC ETC
Hi, My guess is that you don't have adequate power for your flat panel. By all means do not use long extension cords. Try a different wall plug. You must have 120V ac to work. Read your manual that came with it. Good luck
Jun 08, 2011 | Televison & Video
Push button washer wont come on. has 120v going
check an see if you got the volt down to motor if this is a real old washer it might have a start relay above the motor that good be bad
Apr 24, 2010 | GE WWRE5240D Top Load Washer
Dometic RM2652 RV Refrigerator trips GFCI
Hi!!
Right beside the circuit panel, there is a grill, remove the 4 screws to gain access to the transformer/battery charger. You'll see a double power outlet, one cord is from fridge, the other is from the transformer. UNPLUG Transformer cord and reset breaker.
It will take a couple of minutes for the fridge to change to AC if you have it in AUTO. If everything works fine, REPAIR OR REPLACE TRANSFORMER/BATTERY CHARGER.
Don't forget to rate this answer, Good Luck!!!
Apr 19, 2010 | Dometic RM2652 Refrigerator
Have no stdby lite and wont turnon fuse is good have
This is a commaon problem. It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 22, 2010 | Sylvania LC320SL8 Television
I need a 120v power supply circuit board
purchase a AC to DC adaptor and use the 12volt power cord plugged into it.. these are commercially available, just make sure you purchase an adaptor that can handle the power used by the fridge which is on the back of the unit.
May 30, 2009 | Sharper Image (SI714SL2) Compact...
Philips 42FD9954 42 in. Plasma HDTV Logo
27 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
