The TV monitor won't turn on when connected - Televison & Video
    Problem Solver:
  • 5 Answers
Please make sure the signal going to the monitor is active. If possible, plug another monitor to the device to ensure that it is not the input device rather than the monitor. Also make sure the monitor is on the correct display mode.
Posted on Nov 27, 2012
Monitor standby won't stay on /pioneer 424mv
What is the source of the TV signal? I know many monitors have a "power-saving mode" that returns the unit to standby if there is no signal coming in.
Check that the signal cables are working (try swapping cables). Make sure the source is on before turning on the TV. Press the Input button to select a different source. Make sure that the source signal is not refreshing (or synching) at a rate that is incompatible with the TV. (If your source is a PC that was previously connected to a CRT monitor, the refresh rate should be reset to 60 Hz before connecting the computer the the Pioneer 424MV.)
I hope this helps.
(Pioneer TVs usually give a blink code if there is a hardware problem that prevents it from turning on.)
Mar 17, 2013 | Pioneer Televison & Video
Monitor won't turn on I have connected everything properly and still no signal
I didn't see whether the power strip where you have all devices plugged in was turned on. Plus, you only showed one side of the monitor. There should be an indicator light on the monitor which indicates that electricity is running through the unit. Lastly, did you read the owner's manual before putting this unit together? Check all options and let me know what happens.
Mar 06, 2013 | Computers & Internet
Compaq laptop prasario cq60 won't turn on yes it's plugged in yes outlet works yes I checked all electrical connections and outlets
have you tried to remove the battery and wait a couple of minutes then re-insert. make sure your battery charger is working, light flashes also indicates low power.
Mar 01, 2013 | Computers & Internet
S-video out to tv nvidia 9300 gforce won't work
obvious things first. have you tried the other input plugs on the TV? do you get the same problem with plugs 1 and 2?
you can try only having the TV connected to the Graphics card and turning on the PC see if it comes up as the primary display automatically.
have you tried configuring the Nvidia setting so ONLY the tv is a display instead of dual monitor?
doing these will rule out faulty cable or faulty S-video plug or Faulty TV input plug.
Dec 07, 2012 | Nvidia 64MB GeForce3 AGP Video Card with...
Hi, I've just purchased a Hanspree SV32AMUB for my Dell monitor. The TV doesn't pick up the signal even though the PC is connected to the HDMI-1 port, and I've set the input to HDMI-1. C
I assume HANSPREE SV32AMUB is an external monitor and you want to watch what is on your laptop PC transferred to your TV. If this is the case Toggle the Fn key on your laptop.
EXPLAIN IN DETAIL WHAT YOU HAVE AND WHAT YOU WON'T TO DO. I'M A LITTLE CONFUSED
Apr 07, 2012 | Computers & Internet
MONITOR WON'T STAY ON. not connected message then it goes off
Hook a spare monitor to the computer, if okay! problem in the original monitor, if both show the same symptom, it means the Video Graphics Card in the computer is defective. If possible change the video cord from the computer to the monitor, sometimes these cords fail.
Mar 13, 2012 | eMachines ET1641-02w (PT.NA60X.001) PC...
Samsung T220hd won't turn back on from standby
Power up issues on the T220HD monitor are caused by a failure of the capacitors on the IP-49135b power supply board that this unit uses. The repair is easy, you just need to replace the 7 failed capacitors and the unit should be as good as new. Here is a link to some information showing what needs to be replaced to repair the power supply board.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_33_68&products_id=217
I hope this helps.
Nov 21, 2011 | Samsung T220HD LCD Monitor
My computer won't read the new camera I've got. Even after installing all info from cd. Have tried camera and it works on tv. It won't let recognise the device on problem either. What can I do?
A camera that works connected to a TV without software is not the proper device to connect to a computer. Check again with your packaging and instructions.
Having a camera working on the computer and then porting the video signal to a TV monitor is the preferred arrangement.
Install the software, reboot, then connect a PC camera, it should be recognized and be testable on Skype, etc.
Sep 12, 2011 | Dell Dimension 3100 PC Desktop
COMPUTER WON,T YURN ON
first of all,is your power cable properly connected to your system unit.if it is not,connect it properly and turn the system unit on again
secondly,make sure your signal cable from the monitor to the system unit is properly connected
after following these instructions,reboot your computer again.
thank you for consulting fixya with your problems
Feb 14, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
