I need to set my typewriter back to typewriter mode
I bought this typewriter used it wont type it just types straight up and down lines how do i get it to typewriter mode
  • 3,594 Answers
You didn't ngive a make or model. SWome have a slide switch and some have a key marked TW/WP.
DickyO
Posted on Nov 30, 2012
JUSTOLDJIM
  • 478 Answers
SOURCE: paper advance
The paper release lever may be in the release mode. try holding the left platen knob and pulling lightly on the paper is should not allow the paper to move freely, if it is ok try holding the left knob and turning the right knob in the direction you would to turn the paper in it may have come loose if so turn it all the way back in do not over tighten it your machine does not click when the platen is turned it uses electronics to hold the platen on line.
Posted on Dec 17, 2007
POCBM
  • 121 Answers
SOURCE: Typewriter will only type straight lines
It sounds like you either don't have a printwheel in the T/W or the spokes are broken. What you are seeing is the hammer face.
DickyO
Posted on Mar 16, 2009
  • 13 Answers
SOURCE: Olympia 300 standard typewriter - the left margin
Clean and oil the shaft
Posted on Oct 09, 2009
Testimonial: "Thanks. I'll try it."
  • 20 Answers
SOURCE: Need to be able to get typewriter out of auto mode
Look for a delay print mode - probably a slide switch. If not, check out to see if there is a code or control button. Usually works by holding the code button in conjunction with another key. ie: Code and "D". Model # would be a help.
Posted on Oct 25, 2009
  • 3594 Answers
SOURCE: I have a wheelwriter 3000.
Hold the code this makes the index a micro index for fine spacing.
DickyO
Posted on Sep 09, 2010
I've hit a wrong key and now it won't print what I am typing it just moves along the line
Just hit the mode key until TYPE, on the display, is highlighted. There are 3 modes, TYPE (where the machine functions like a normal typewriter), L/L (Where what you are typing shows up in the display and then prints when you hit the "RETURN" button. You can make corrections, in this mode, before you print the line, which saves using your correction tape.) and STORE (which is used to store memory information, such as format and phrases.)
Sep 28, 2015 | Brother EM-430 Typewriter
How can I get my typewriter back to its intial settings
There is no keystroke pattern to reset the EM series typewriter. There are two methods to reset this typewriter.
1.You can reset the daisywheel and remain on the same line of type, simply lift the top cover and then close it back down. The carrier will move to the left, reset the daisywheel and return to the last space typed.
NOTE: This will not affect the format settings (bold, underline, etc)
2.If you want to abandon the current typing position; turn off the typewriter, wait 10 seconds for the power supply to reset and then turn the typewriter back on. The typewriter will reset and the carrier will return to the beginning of the current line.
NOTE: Turning off the power will restore the format settings to standard default settings (bold, underline, etc).
Mar 15, 2013 | Brother EM-630 Typewriter
When typing with my brother gx-6750 it types weird lingo is the type set messed up or can I reset them?
Your daisy wheel letters are bended not straight.
Switchoff just remove your daisy wheel & remove the daisy wheel from its cover & see all the letters should be straight.If any of them is bended jst make them straight by your fingers dont press too hard & then fix the daisy wheel back & switch on typewriter.
Jul 20, 2010 | Brother ML-100 Typewriter
How do you change the pitch or size of the type? The typewriter has 3 pitch settings, but we cannot figure out how to make the adjustment.
hold down "code" key and press 6 for 10 pitch. "code" key and press 7 for 12 pitch. "code" key and press 8 for 15 pitch. to change type size or style you have to replace the daisy wheel.
Nov 10, 2009 | Smith Corona Wordsmith 100 Typewriter
IBM Wheelwriter doesn't type until I hit return button.
On the R. side of the keyboard is a key that says print mode press this key and the dl print on the displaywill go out.
DickyO
Mar 17, 2009 | IBM Wheelwriter 30 Typewriter
DickyO
Mar 16, 2009 | Swintec 7040 Typewriter
File? 12345678
Is the typewriter a Smith Corona SD 250? If so, you have entered the "memory" mode by mistake. Over on the left side of the typewriter is a switch marked "MEM", "LINE", and "TYPE". Move the switch down to "LINE" or "TYPE" to resume normal typing. DO NOT PRESS ANY NUMBER BUTTONS ON "MEM" MODE! Does this information fix your problem?
I just got this typewriter a few days ago so I don't know everything about it yet... But I believe that this is one way to fix your problem.
Best of luck to you!
Feb 23, 2009 | Smith Corona Wordsmith 200 Typewriter
Changed Ribbon
Have you pressed the
'spider web' key (asterix in a circle) and + //
May 30, 2008 | Brother GX-6750 Typewriter
Why doesn't my typewriter type when I'm typing
I had this problem once with another brand. One mode actually waits for you to complete an entire line of type before printing it onto the page allowing you to make error corrections without wasting alot of "correction tape". Change the mode back to typing on the fly.
Mar 14, 2008 | Brother SX-4000 Typewriter
63 people viewed this question
k24674
jasbo
jasbo
