Question about Amana ATB1935HR Top Freezer Refrigerator
Model drs2660bw refrigerator- does the water supply come into the main water valve at the back or into one of the selenoid
Just purchased the frig and did not have water lines attached
    Top Expert:
  • Amana Master
  • 9,472 Answers
The water comes into the valve on the back and then to the ice maker and the water dispenser, if it has one.
Posted on Nov 27, 2012
SOURCE: We ordered a new water
Your specialist helped us and we have solved our issue. Thank you again. I did write a review.
Posted on Jul 11, 2009
SOURCE: Amana free o frost refrigerator
My fridge makes a loud rattling noise when turning off and on
Posted on Dec 29, 2009
  • 2183 Answers
SOURCE: The water supply tube in the back of the refrig
if you think it's clogged it's probbaly iced up,use a hair dryer and melt it out,see if you can put a hose clamp around the hose to hold it in place,does any water make it into the ice maker?see if you can stick a straw oonto the piece the tube slides onto and see if you can blow through it to see if it's clogged or it's just the water pressure blowing the line off,might just need to be attached better
Posted on Jan 30, 2010
e-Guru
  • 3917 Answers
SOURCE: I found water under my
Hi
Look on the ceiling in the back by the compressor do you see a small hose on the ceiling. There's an access panel at the lower right corner. That's where it is ,there's a drain pan just under the hose remove that panel its right there.
Also check this link to have a detailed idea:-
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itleaks
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Apr 01, 2011
imufo2
  • 3773 Answers
SOURCE: ny refrigerator is leaking on the frig side and it
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Posted on Aug 13, 2011
I have a side by side whirlpool, water was coming out fine then replaced with new filter and a month went by the water started to come out very slowly I thought the filter may be plugged so put anothe
Cut water supply off to frig disconnect water supply line to frig water inlet valve turn water back on to make sure you are getting good water supplied to water inlet valve some times water cut off gets stopped up. If you are getting good water flow to water inlet valve then check to make water valve is opening up all the way. if not then replace valve.
Oct 27, 2014 | Whirlpool Refrigerators
Leaking pure source 2 ice and water filter
Hi-
Three things
  • Water supply valve may not be completely open.
    Open valve completely.
  • Water supply valve may be blocked by foreign material or may not be large enough.
    Supply valve must have a 1/4" opening for water to fully supply ice maker. Many self-piercing valves do not have this big of an opening. Replace water supply valve with one that has a 1/4" opening.
  • Water filter may need changing.
    If equipped with a water filter, replace filter canister or cartridge.
Hope this help
Thanks for using Fixya!
Jul 14, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Why water is not coming out of the line to the freg
First check to make sure the water valve from th water supply is on (usually under your sink), Second, hold the water despenser switch ON. You should hear a "Hum" sound, that's the Electric water valve in the "open" position. The air will have to be purged through the water line, Filter, And the water collection tank inside the frig. The water tank keeps about agallon of water Cold for the water despenser, and will supply cold water to the ice maker, so the ice maker can freeze the cold water much faster for your ice. When holding the Water despenser, and you do NOT hear the hum sound, there is NOT power to the water selenoid. Check the connections to be ure they are tight and secure. A volt meter can also be used to check the voltage. WARNING the voltage is around 120 volts A.C., Do NOT TOUCH with bare hands!
Jun 20, 2014 | KitchenAid KSCS25FKSS Side by Side...
Location of water selenoid on Ge side by side
it is locatored on the back bottom of frig behind the bottom panel-mike
Jan 25, 2010 | GE Refrigerators
My kenmore refrigerator 106.56166500 quit dispensing water. Icemaker works fine. I disconnected the water line at the bottom of the front door via the quick disconnect and I get water from the supply side...
The line inside the freezer door is frozen . Turn the temp in the freezer , to warmer for a few days , and it should thaw . A dispensor heater is available , pt # WR49X10173 . Instructions come with the part .
Nov 11, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The ice dispensor and water dispensor on my GE Profle side by side refrigerator quit working.
Did you check the filter ? If it has been a few years, the filter can be clogged. Also, the water line connection valve may be internally blocked. If it is a tap-valve I suggest you turn it fully closed and then reopen it; this may break free any deposits that have built-up and clog the small opening. But before you reopen the valve, disconnect the line where it attaches to frig and let the first quart of water flow into a container to fluch away any particles before allowing it to flow into frig system.Can also be that the inlet selenoid valve or its wiring connections and switches are not working. You must hear a click sound when you touch the dispensor handle for water. Good luck, Macgivor
Oct 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser will not work when lever is pressed. we had an intermittent problem with it before it stopped working altogather.I was going to look at it but was afraid to pop off the trim on the outside...
This could be a bad water valve in the frig. This frig has a double water valves. One for the ice maker and one for the water dispenser. It should be in the lower back. Where the water line goes in. You can check this valve easily. Find the double water valve on the frig. Turn off water supply to frig first. Swap the plastic water lines going from the water valve into the frig. Turn water supply on. Then see if the water dispenser works. Sometimes you will have to operate the water dispenser for a little while to get the air out of the line. If it works now then the problem is in the water valve solenoid and needs to be replaced.
Nov 08, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice maker not getting water from water valve
you will need to replace the water inlet valve on the lower back of frig.easy,let me know how you do-mike
Oct 11, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice maker not working
the water valve soleniod on the lower back of frig. is bad,get the model number out of the frig. top right and replace,let me know-mike
Sep 21, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice maker freezing up
If it is only the fill tube that is freezing up, or getting full of ice, than your water valve is leaking (letting drops of water thru to your ice maker and filling the icemaker fill tube up and freezing). If this is the case, replace the dual water valve (part # 1071263) located in the back of the refrigerator, just follow the water line from your wall into the refrigerator. Make sure you turn off the water to the refrigerator and also unplug it. The dual water valve is the one that has two water lines, one going to the icemaker and one going to the water dispenser. On this model, I think you only have one water valve. On some you have two, the primary water valve and a secondary water valve (the dual valve). If this is your case, I would highly recommend you replace both. As far as the Refrigerator side freezing things up, I think that is a whole different issue. Please post back.
Oct 16, 2006 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana ATB1935HR Top Freezer Refrigerator Logo
61 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
