Question about Acer Aspire 5003WLMi Notebook
Startup problem my computer wont start up. i accidentally interrupted the restore and it wont boot up. its saying windows could not start because the following file is missing or corrupt:\system32\ntoskrnl.exe. please re-install a copy of the above file. what do i do to start it up
  • 1 more comment
  • martin67 Feb 23, 2008
    Hi I've got a Compaq Presario (windows 95) and it does not boot up when I start. All I have is a flashing cursor in the top left hand corner. I have no discs available so am completely stuck to know what to do. Can anyone help please
  • shake1127 May 09, 2008
    My problem is the same. I interupted pc recvovery and now i cant start up my pc at all.
  • Karen Walker Pickin
    Karen Walker Pickin Jan 03, 2013
    Me to, n the windows xp wont boot up and repair it HELP !!!!
    Problem Solver:
  • 8 Answers
Wont let me press r and get that menu ?!!!!!!!!!
Posted on Jan 03, 2013
  • 196 Answers
From: http://www.computerhope.com/issues/ch000646.htm If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps. 1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue. 2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key. 3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console. 4. Select the operating system you wish to fix, and then enter the administrator password. 5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32 6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file. 7. Type exit to reboot the computer. If you only have a restore CD, this probably won't work. You should just start the restore all over again, if this is the case.
Posted on Jun 05, 2007
    Karen Walker Pickin Jan 05, 2013
    it wont let me press r, and just start loading then gives me an error BSOD 0x00000007b etc
2 Suggested Answers
SOURCE:
  • 883 Answers
SOURCE: startup problem
i had a similar case with a desktop. final solution was to get another hard drive and "start over". to recover your personal files, get a mini hard drive enclosure and connect to your newly-drived lap with USB and transfer them. There is another, cheaper solution, although I have not ever tried it. During startup, press the F6 or F8 key to see a list of possible startup options (or read your manual for mfg-specific keys). Look for one that hopefully says "abort restore operation".
My acer aspire one 722 wont boot startup repair wont fix it
This is a problem in your BIOS which is a common problem on acer aspire one laptop model. To fix that you need to flash your bios. Please watch this video for a step by step guide on how to do that.
Feb 15, 2013 | Acer Aspire One 722-0022 : 1.0GHz C-Series...
Brand new samsung notebook rv515 wont start up. start up repair keeps coming up
You can try getting to your boot menu to bypass this section of the startup, but you will probably be better off exchanging it for another one. You may have accidentally received a refurbished computer, or the computer didn't power down correctly after testing.
Jan 21, 2013 | Computers & Internet
Dell dimension 3100 wont load to main screen
You may need to roll back system with System Restore. Under Safe Mode (press F8 during boot and choose Safe Mode). Win 7 - Start > Search type System Restore. XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates. Uninstall last program(s) that was installed, again in safe mode.
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Nov 29, 2012 | Computers & Internet
Windows will not start up or launch start up repair
hi,
please insert your operating system disc in the drive and restart the computer .
Select the boot device as cd/dvd drive and save the settings in BIOS .
restart the system and boot it using the CD.
also, you can insert the disc restart the system in safe mode.
try to restore the computer using system restore.
May 21, 2012 | Dell Inspiron Mini 10v Netbook
I have accer 5570 Laptop when ever i start it up it gives me this message on and off and wont let me start the window here what it says" windwos Erro Recovery-windows failed to start. A recent Hardware or...
Tried starting normally & go int contol panel on the start menu,system tools & system restor to last good setting!
Hope that helps but if not get back to me!
Sep 22, 2009 | Acer Aspire One AOA150-1784 Netbook
My hp compaq c552uslaptop wont start all i get is a black screen with the following "windows error recovery" "windows failed to start a recent hardware or software change might be the cause if windows...
When you boot up your computer, press the F8 key until you get some choices such as Safe Mode and Command Prompt. There will be an option for Last Known Good Configuration. Select this and hopefully it will restore your computer settings to the way it was before this happened.
Mar 12, 2009 | Compaq Presario C552US Notebook PC
My presario 500 wont even turn on
try running it in safemode and if you have recently added any new hardware or software that may be causing your problem uninstall it while you are in safemode.
As the computer boots press F8 to enter safe mode. If this is successful then everything on the screen will look big, ignore that for now. uninstall anything that may be causing the problem. If you have not loaded anything lately, then while in safe mode restore your computer to an earlier date when you know that everything was working okay.
You can do this by going to Start>all programs>accessories>system tools>system restore. Then choose a date when you know that things were okay and press restore. You computer will restore to the date you selected and it will reboot. If asked to whether you want to start windows normally after the boot then select that option.
I hope this helps
Nov 14, 2008 | Compaq IDE CD-Rom Drive Presario 500...
Blank Monitor
Start pressing F8 at boot
When the Windows Startup menu appears, select ENABLE VGA MODE
This will boot the system in 640 x 480 resolution but the video driver will be installed. Once at the desktop, either reset the display to the normal resolution settings or reinstall the video driver.
Aug 06, 2008 | Relisys RLT1720 17" LCD Monitor
Startup problem
I would recommend you to boot your system and safe mode and do a system restore...To open your computer and safe mode hit the F8 button on your keyboad when the computer is booting up..click safe mode..and then once you get to safe mode its going to give you an option to restore your computer to another day..after the restore is finish, you should be able to use the computer without any problems...
Jan 31, 2008 | IBM ThinkPad G40 Notebook
Startup problem
Jun 05, 2007 | Acer Aspire 5003WLMi Notebook
Acer Aspire 5003WLMi Notebook Logo
312 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
